Question about Whirlpool Duet GHW9150P Front Load Washer
Door Lock How do I change the door lock
    Genius:
  • 1,028 Answers
Remove spring around door seal ..roll seal back into door opening remove 2 screws on outer frame holding lock in place ..pull lock through opening remove wires reinstall in reverse..are you sure lock is broke if you hear a clicking noise when lock should be closing suspect loose connection on main control bd ..remove top control is gray box on rear rail..try wiggling connections toward center of control if lock energizes and works suspect control ..may be able to shim plug in place but sure fix would be new control
Posted on Aug 04, 2008
2 Suggested Answers
  • 1294 Answers
SOURCE: door lock on westinghouse mastermind 708 washing machine
To Manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened.
Posted on Apr 13, 2009
Door lock dont always work
What door lock doesn't always work ? One or all of them . This is a complex set up for these door locks ! The switch is an input to the BCM - body control module . There is logic involved in the microprocessor , there are relays built in to the BCM ! Could have a DTC - diagnostic trouble code stored in the BCM ! Could be a bad connection at the BCM or master window switch ! A bad ground !
The power door lock system consists of the following components:
Body control module (BCM)
DOOR LKS fuse
Driver door lock actuator
Driver door lock switch
GMLAN serial data link
Keyless entry transmitter
Passenger door lock actuator
Passenger door lock switch
Remote control door lock receiver (RCDLR)
The DR LCK fuse supplies battery voltage to the body control module (BCM) for the power door lock system. The BCM supplies and monitors a reference voltage to the driver and passenger door lock switches through the door lock switch lock/unlock signal circuit. Each door lock switch receives ground at G300 which is also the ground for the door lock and unlock relays located in the BCM. When a door lock switch is placed in the lock position, the reference voltage is switched to ground and the BCM senses 0.0 volts on the door lock/unlock signal circuit. When a door lock switch is placed in the unlock position, the reference voltage is switched to ground through a 1.5k ohm resistor that is internal to each of the door lock switches and the BCM senses approximately 2.9 volts on the door lock/unlock signal circuit. The BCM interprets what position the activated door lock switch was placed in based on the voltage drop.
The BCM, upon receipt of a lock or unlock switch signal, will switch the appropriate door lock/unlock relay coil control circuit to ground causing the appropriate door lock/unlock relay to energize. With the relay energized, voltage is applied to the door lock actuator control circuit causing the door to either lock, or unlock depending on what command was received from the power door lock switch or remote control door lock receiver (RCDLR). When a power door lock/unlock relay is not energized, the switch contacts are normally grounded through the BCM which provides ground to the appropriate door lock actuator for the lock/unlock function being performed. The power door lock/unlock functions are performed by reversing the flow of voltage through the door lock actuator control circuits. The BCM has three internal drivers for the power door lock system. Driver door unlock, passenger door unlock and all door lock. This is done to isolate the driver door lock actuator so it can be unlocked separately from the passenger door. For additional information concerning keyless entry, refer to Keyless Entry System Description and Operation.
This is one you may want to take to dealer or some other ASE certified repair shop ! To do this right you need a Tech 2 scan tool !
Ignition ON, observe the scan tool Door Lock Switch parameter while using the driver and passenger door lock switches. The parameter should change from Idle to Lock and Unlock.
If the value does not change, refer to Door Lock Switch Malfunction.
Command the doors to LOCK and UNLOCK with the scan tool, the door lock actuators should LOCK and UNLOCK when changing between the commanded states.
If one or more doors do not LOCK or UNLOCK, refer to Door Lock Malfunction.
Aug 12, 2015 | 2009 Pontiac Solstice Convertible
What causes a malfunction in power locks?
The power door locks are controlled by the BCM -body control module ! The door lock switch is an input to the BCM .
The BCM, upon receipt of a door lock switch lock or unlock signal, will switch the appropriate door lock actuator control circuits to battery positive voltage. The opposing side of the door lock actuators are connected to ground internally within the BCM through the other door lock actuator control circuit and the doors will lock or unlock appropriately.
First thing to do would be check power an ground circuits at the BCM ! Do you have any other systems not working -power windows etc...
The DR/LCK fuse supplies battery positive voltage to the I/P fuse block for the door lock system. The body control module (BCM) supplies and monitors a reference voltage to the door lock switch through the door lock switch lock/unlock signal circuit. The door lock switch also receives a constant ground source. If a door lock switch is placed in the lock position or unlock position, the reference voltage is taken directly to ground and the BCM detects the voltage drop on the signal circuit.
Should have BCM checked for stored DTC'S - diagnostic trouble codes !
Ignition ON, observe the scan tool Driver Door Lock Sw, Psgr Door Lock Sw, Driver Door Unlock Sw and Psgr Door Unlock Sw parameters while using the driver and passenger door lock switches. The parameters should change between Active and Inactive.
If the values does not change between the commanded states, refer to Door Lock Switch Malfunction.
Command the driver door and passenger door lock actuators to LOCK and UNLOCK with the scan tool, the doors should LOCK and UNLOCK when changing between commanded states.
If a door lock actuator does not perform the LOCK and UNLOCK functions, refer to Door Lock Malfunction
DTC B3130 00: All Door Unlock Circuit
DTC B3135 00: All Door Lock Circuit
Aug 09, 2015 | 2010 Chevrolet Impala
Driver door lock will not lock car door
No you need to replace the driver door lock.
Jun 27, 2014 | 2001 Citroen Xsara Picasso
2004 chevy malibu driver and passenger door lock problems
The locks on your vehicle are electronically controlled by the BCM - body control module . The driver an passenger door switche's are input's to the BCM . Do you know anything about automotive electronic's ? anti theft alarm remote, could this be part of the problem , No it's just a key less entry remote , nothing to do with the anti-theft .
Door Lock System Components
The Power Door Lock System consists of the following components:
• Body control module (BCM)
• Driver door lock switch
• Front passenger door lock switch
• Door lock actuators in each of the doors
• IBCM (PWR) 15-amp fuse
Door Lock System Controls
The Power Door Lock System is controlled by the body control module (BCM) and can be activated by any one of the following:
• A door lock switch Lock or Unlock actuation
• A keyless entry transmitter actuation
• An automatic door lock actuation
• An automatic door unlock actuation
• A last door closed locking (LDCL) actuation
Driver and Passenger Door Unlock Operation w/o Keyless Entry
When the body control module (BCM) detects a transition of either of the door lock switches to the Unlock position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the driver passenger door lock actuators transition to the Unlock position.
Your best bet , take your vehicle to a qualified repair shop ! Need special tool to diagnose .
Power Door Locks Inoperative
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With a scan tool, observe the door lock switch parameter in the Doors data list.
Does the scan tool display Idle?
YES - Go to Step 4
NO - Go to Step 8
Activate the driver door lock switch to the LOCK and UNLOCK positions.
YES - Go to Step 9
NO - Go to Step 5
5
Activate the front passenger door lock switch to the LOCK and UNLOCK positions.
YES - Go to Step 9
NO - Go to Step 6
6
With a scan tool, observe the driver door lock actuator command and the passenger door lock actuator command parameters in the Doors data list.
Activate a door lock switch to the LOCK and UNLOCK positions.
Dec 24, 2017 | 2009 Chevrolet Malibu
Door locks
You can change auto door locks option in personal settings on the dash tacho button. If you don't have that option you can change them manually by getting in the car and closing all doors, put key into ignition and turn key from "lock" to "on" four times ending in the lock position, then press the power door lock button on drivers side door and then you should hear a chime to confirm the change.
Nov 14, 2012 | 2008 Dodge Caliber
I have power to the door lock switches on the drivers door but the locks do not work nor does the back hatch or the switch at the back hatch that controls all the locks in the vehicle. Do the locks g
Power Door Locks Circuit Description
The power door lock system incorporates door lock switches on both front doors and on the RH D-pillar, door lock motors in all passenger doors and in the RR cargo door, a door lock relay and a door lock control module.
Power for the door lock switches and the door lock control module is supplied from the CIG LTR fuse 13 through CKT 640 (ORN). Power for the door lock relay is supplied from the PWR ACCY circuit breaker through CKT 540 (ORN). Ground for the door lock relay is supplied from G202 through CKT 150 (BLK) and ground for the door lock control module is supplied from G400 through CKT 150 (BLK).
The door lock motors are reversible and both sides are connected to the normally closed contacts of the door lock relay. Those contacts of the relay are connected to G202. When any of the door lock switches are placed in the lock position, voltage is supplied through CKT 195 (LT BLU) to the relay lock coil. Since the other side of the lock coil is connected to ground, the coil is energized and it pulls the lock contacts closed. Voltage is then supplied through CKT 295 (GRY) to all the door lock motors and the doors lock. The unlock function operates in much the same manner except that when any of the switches are placed in the unlock position, voltage is supplied through CKT 194 (WHT) to the unlock coil of the relay and CKT 294 (TAN) supplies voltage to the apposite side of the door lock motor and the doors unlock.
Door Lock Control Module Description
The door lock control module is used on vehicles equipped with cargo doors. The purpose of the module is to lock the cargo doors after a lock cycle has been commanded from any of the door lock switches with the cargo doors open. When the RH cargo door is open, the module receives a ground signal from the closed contacts of the rear door jamb switch on CKT 1897 (ORN/BLK) to G400. When a lock command is received, the module retains this input until it receives an open input from the rear door jamb switch. Then the module sends a lock command through CKT 194 (WHT) to the door lock relay and the doors lock.
Rear Cargo Doors Description
The power door lock motor will not operate unless the rear cargo doors are fully closed. The power door lock motor is in the right cargo door. The contactors are on the rear cargo door opening on the body and on the right cargo door.
May 23, 2017 | 1997 GMC Yukon
Left hand power door lock on huyndai 2002 accent 4 door broken?
It sounds like the classic "someome brushed up against the lock on the door and changed the position to the locked position" ordeal. Try changing the position of the lock in the door. You should be able to look at the lock before you change it and see that it is in the wrong position and can not mate with the receiver (or nader pin). It is classic tha the door won't close when this is the case.
Dec 29, 2009 | 2002 Hyundai Accent
Door lock won't function
If you cannot lock/unlock any doors at all, change the battery on your remote. If all the other doors work, but not the driver's door, there's a malfunctioning magnetic switch on the door.
Dec 05, 2009 | 2006 Scion tC
Door open!
i had the same prob..and the cure was to change the bushes on the motor.its been fine since
Oct 28, 2008 | Whirlpool AWM6100 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
263 people viewed this question
Dan Webster
Dan Webster
Sal De
