Question about KitchenAid KTT261 Ultra Power Plus 2-Slice Toaster
Only one side heats up when in toasting cycle.
  • 2 more comments
  • rgeeve Mar 25, 2011
    The toaster light is lit, the bagel function is not selected.
    Is this a part I could order and replace myself? If so, where can I get price and part number to order?
    I now know what I need to know to either repair the toaster or replace the toaster.
    Thank you for your timely responses.
  • floyd herdrich Apr 11, 2012
    Love my toaster -- a few days ago I was watching it do it's thing, when a point on the heating coil went bright red, then burned through. Therefore, only working on one side. Not so bad, if I don't mind turning over the toast, but I suspect it may overload something if i keep up. My next fix attempt will be to call 1-800- in hopes of getting a new coil.
  • 794 Answers
Hi rgeeve,
If only one side heats up during the toasting cycle you might want to consider checking the Bagel function. Please make sure that this (Bagel) is not selected. If toaster is on this function it will only toast one side of the bread and will keep the other side warm.To ensure that Bagel function is not selected, LED for this should not lit up.
Hope it helps.
Thanks you for using Fixya.
Posted on Mar 25, 2011
  • Jemalyn Labaguis Mar 25, 2011
    Hi rgreeve,
    If you you are not using the setting for bagels, then one of your toasting elements is already burned out. You may contact a local tech to have it repaired but replacement is cheaper.
    Hope it helps.
    Thank you for using Fixya.
    Hi rgreeve,
    This part is something that you can replace and you may contact Kitchenaid's toll free number to inquire about how you can order and ask the price. If your machine is still under warranty you may also request a service call with them. Here's their number: 1-800-541-6390. You can call them from Monday to Friday 8:00 am - 8:00 pm EST.
Toast is dark on one side and white on the other
The heating element on the white side probably is burned out.
Dec 21, 2014 | Cuisinart Kitchen Appliances - Others
Black & Decker Toaster Oven - elements cycle on and off, which makes for a SLOW cook.
Oven has three modes: 1) oven mode cycles elements on and off to maintain a specific temp setting for up to 60 min. 2) toast should keep all elements on for a few min. 3) broil mode top elements only always on, up to 60 min. Make sure you have dials in correct position and use the toast timer.
Apr 17, 2014 | Toaster Ovens
I have a three slice dualit toaster. Two slots toast on both sides but the third only toasts on one side - is that how it was designed or is there a fault?
No you need to replace the heater of the second center since it heats only in one side, you can buy on ebay and they have instructions o how to replace it
Jun 22, 2011 | Dualit 31213 3Slice Toaster
Toast cooks corrctly on one side and hardly at all on the oher. I have cleared all the crumbs out. It is the same whichever opening I use.
it means the other side has no heat to toast the bread!
The heating element might have been disconnected already, worst of all it is already burned!
try to contact the manufacturer to get the HEATiNG ELEMENT part or repair and replace the said part!
That'll solved ur probs!
Dec 01, 2010 | Prestige Appliances 50973 Toaster
The heating element doesn't work in two of the slots.
If its a Dualit model then you should be able to get it repaired. Generally replacing parts on a Dualit is not easy but spares are usually available thanks to the fact that its one of the most well known commercial toasters on the market. Google and see if there's a repairer in your area.
Apr 05, 2009 | Dualit CTS4E 4-Slice Toaster
Toast Master Toaster TP409
if you mean the toast itself doesn't toast on one side, check that both heating elements have about the same resistance value. One could be twice as conductive as the other and not heat as much as the other side.
If you mean the other two slots don't toast, the problem could be in the switch or in the elements themselves. check carefully the continuity of the toaster across the (unplugged) ac power connector while you push the toaster load handle down on each side. If the resistance is significantly larger on the problem side, the problem is either the switch or the elements. The problem is usually with the switch becoming corroded or oxidized. The switch is supposed to be self-cleaning, that is, it wipes itself as contact is made to help remove buildup. Sandpaper both contacts until they shine copper colored. Otherwise look at the elements while toasting. dark areas mean lower wattage is being dissipated and the element may be bad near a dark spot.
Nov 26, 2007 | Toastmaster TP409 4-Slice Toaster
Left side dont work
The holder is a bimetallic strip that heats up and opens when it reaches a preset temperature based on the darkness setting. It should latch onto the toast loading mechanism when cold and then snap open when it reaches a certain temperature. The darkness setting knob adjusts the point at which it opens. Probably either the release mechanism is broken or bent or the setting knob is broken. You can disassemble it when unplugged by removing the screws on the bottom and prying off the toast loading knobs by placing a ruler wrapped in cloth against the housing and prying the knobs off with a large screwdriver carefully going back and forth from side to side. If the knobs break or won't go back on use a high temperature epoxy to reassemble. You have a good side to compare the bad side to. Look for differences from one side to the other as the toast loader lever goes down and as the darkness knob is rotated. You may just have something blocking the mechanism. After working on it, plug it in outside to a ground-fault protected outlet on a fireproof surface before attempting to use it.
Oct 25, 2007 | Waring WCT708 4-Slice Toaster
Open Questions:
Very hard to remove the plastic cover from the toaster - Must Release Circuit Card First To my fellow owners of a KTT261. We have enjoyed using our KitchenAid toaster for many years but it eventually got so gummed up we could no longer reliably push the handle down to make toast AND it would also fail to latch or stay latched until the toasting cycle was completed. Not wanting to throw it out I wanted to try repairing it, but there was little info available online. So if you ever need to remove the plastic cover for maintenance here are a few tips. Of course UN-PLUG THE TOASTER COMPLETELY AND LET IT COOL DOWN TO ROOM TEMP!!! Remove the 4 screws on the bottom, two on each narrow side holding the top plastic cover to the bottom and pull off the plastic handle on the right which drops the bread down into the toaster cavity. That is the only obvious task. You will now notice that the cover still can't be removed because something on the right side near the front control panel isn't letting the cover detach from the base. That something is the control panel itself mounted into a white plastic holder glued to the cover and it's very short ribbon cable joining the two electronic circuit cards on the right near the handle which are mounted to the base. What to do. Using a long pair of needle nose pliers, or very small fingers and a long narrow screwdriver -or- all of the above and a second pair of hands, you must release the credit card sized front control panel electronic circuit card from the white plastic holder glued to the blue plastic toaster cover. This is not easy, but ultimately I was able to do it with my wife's help and repaired the toaster nicely. The control panel circuit card is held into the holder by a plastic latch at the top middle of the card. The latch protrudes thru a hole in the card. The bottom of the circuit card fits into 3 finger grooves on the holder. So the task is to release the upper plastic latch by moving it upward, while pushing the card away from the white plastic holder glued to the toaster cover then it will lift out of the bottom groove and be free of the cover. Then you can remove the cover completely, examine and fix the latching mechanism ...etc. IMPORTANT - Remember to study how it was held in originally, what orientation the parts were to each other, because the even harder part for us later after fixing the toaster latching mechanism was to reverse these steps and re-insert the control panel circuit card back into the holder...oye! There is just barely, ...barely, enough length in the ribbon cable connecting the control panel card to the base electronics to do this. Putting it back together was made difficult, because the upper plastic latch on the white plastic holder which secures the control panel circuit card to the cover against it's membrane switches required an enormous force to get the circuit card to latch. I thought I was going to break the card itself, but it did snap into place, barely. Good Luck, "I'm pullin for ya, we're all in this together" (Red-Green)
Jan 18, 2012 | KitchenAid KTT261 Ultra Power Plus 2-Slice...
See all KitchenAid KTT261 Ultra Power Plus 2-Slice Toaster Questions
KitchenAid KTT261 Ultra Power Plus 2-Slice Toaster Logo
246 people viewed this question
Top KitchenAid Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Appliances - Other Expert? Answer questions, earn points and help others
