How long is the burner heat cycle supposed to be for a 2007 kenmore dryer
    Brigadier General:
  • 4,736 Answers
"How long is the burner heat cycle supposed to be for a 2007 Kenmore dryer?"
That would depend on which dryer setting (permanent press, cottons, delicate, etc) you had it set on and the amount of time you had it set to dry. The time setting is really what determines how long the cycle will be. The other setting determines the amount of heat that will be needed for that selection..
Hope this helps ....
Posted on Mar 25, 2011
I paid to have jahn27 solve my problem with kenmore model 70172 dryer (burner cycles such that clothes don't dry. he recommended replace of both burner coils which i did but burner still cycles). how do i...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 11, 2010 | Dryers
Dryer wgd5300, takes a long time to dry. seems
The burner is supposed to05245ec.jpg cycle on and off all through the drying cycle. Over time the operator coils 279834 get weak and quit. They are really easy to replace. This short video show a normal Burst of heat from a dry and the normal length of time it fires off
May 19, 2010 | Whirlpool WGD5300S Dryer
I just bought a gas dryer - takes forever to dry clothes
check the high limit switch/thermostat on the burner housing and if they are weak they will cycle the heat off too soon and it wont build the heat you have it set for,just bypass it with a jumper wire to test it,if this is the problem,dont leave it bypassed,replace it as it is a safety feature to prevent a fire
May 09, 2010 | Kenmore 95087 Gas Dryer
Kenmore dryer heats at first but then stays cool.
Check that the air entry and exit passages to and from the burner are clear of lint or a stray sock.
Aug 23, 2009 | LG DLG5932W Gas Dryer
Gas dryer won't heat
sounds like your igniter went bad
Jun 11, 2009 | Kenmore 64852 Electric Dryer
Kenmore model #78702895 78702 front load natgas dryer : ignites and heats at beginning of cycle, then cools cycle continues without heat
replaced both the black coils on gas burner they will sometimes go bad after first heat cycle
Dec 05, 2008 | Dryers
Dryer heats for 3 minutes, flame quits
the flame is suppose to cycle on and off. If the flame ran continously you would have a fire. And please don't use the top of it for anything such as clothes piles. Dryers need to be free of clutter on top. I know it may be hard to do but do it and your dryer will last you. Good Luck. Whatever you jumpered reverse it ok!
Oct 26, 2008 | Kenmore 73932 Gas Dryer
Gas dryer
be sure burner is firing off every time it is supposed to if ignitor glows then shuts off without burner firing replace the coils on burner (2 black round things) if burner ok remove rear vent hose and try load without connected if works ok suspect flattened hose behind dryer or line to outside restricted
Jul 16, 2008 | Whirlpool LGR5636PQ Gas Dryer
Fuse keep blowing
I would check temp out of dryer should be 140 - 160
Is your cycling themostate good, cutting off when suppose too?  and Hi limit on burner good?
THe cycling themostate control drum temp, hi limit on heater is a back up and the hi limit fuse on burner backs up it all
Oct 16, 2007 | Dryers
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
