Question about Sony Wireless Controller for PS3
Controller is in default mode but when you look it isn't in default mode. the look part is backwards.does this make sense to anyone?
    Scholar:
  • 84 Answers
Sounds like the game you're playing uses an inverted look controller scheme. If the change allows it, you should be able to change it in the game settings.
Load up your Game menu and look for something that'll let you adjust your controller layout. Specifically, you want some to turn inverted look off. That should restore your controller layout to what you're used to.
Posted on Mar 25, 2011
Pontiac grand prix 2007 car shutting off, with Start disabled throttle control module.
It doesn't say module , Starting Disabled Due To Electronic Throttle Control !
The throttle actuator control (TAC) system delivers improved throttle response and greater reliability and eliminates the need for mechanical cable. The TAC system performs the following functions:
• Accelerator pedal position (APP) sensing
• Throttle positioning to meet driver and engine demands
• Throttle position sensing
• Internal diagnostics
• Cruise control functions
• Manage TAC electrical power consumption
The TAC system includes the following components:
• The APP sensors
• The throttle body assembly
• The powertrain control module (PCM)
Normal Mode
During the operation of the throttle actuator control (TAC) system, several modes or functions are considered normal. The following modes may be entered during normal operation:
• Minimum pedal value--At key-up, the powertrain control module (PCM) updates the learned minimum pedal value.
• Minimum throttle position (TP) values--At key-up, the PCM updates the learned minimum throttle position value. In order to learn the minimum throttle position value, the throttle blade is moved to the closed position.
• Ice break mode--If the throttle is not able to reach a predetermined minimum throttle position, the ice break mode is entered. During the ice break mode, the PCM commands the maximum pulse width several times to the throttle actuator motor in the closing direction.
• Battery saver mode--After a predetermined time without engine RPM, the PCM commands the battery saver mode. During the battery saver mode, the TAC module removes the voltage from the motor control circuits, which removes the current draw used to maintain the idle position and allows the throttle to return to the spring loaded default position.
Reduced Engine Power Mode
When the PCM detects a condition with the TAC system, the PCM may enter a reduced engine power mode. Reduced engine power may cause one or more of the following conditions:
• Acceleration limiting--The PCM will continue to use the accelerator pedal for throttle control, however the vehicle acceleration is limited.
• Limited throttle mode--The PCM will continue to use the accelerator pedal for throttle control however the maximum throttle opening is limited.
• Throttle default mode--The PCM will turn off the throttle actuator motor and the throttle will return to the spring loaded default position.
• Forced idle mode--The PCM will perform the following actions:
- Limit engine speed to idle by positioning the throttle, or by controlling the fuel and spark if the throttle is turned off.
- Ignore the accelerator pedal input.
• Engine shutdown mode--The PCM will disable fuel and de-energize the throttle actuator.
DTC P2101
DTC P2107
DTC P2108
DTC P2119
DTC P2120
DTC P2125
DTC P2135
DTC P2138 You need to see which of these codes
Nov 16, 2016 | 2007 Pontiac Grand Prix
Climate Control A/C that constantly blows on windshield after coolant hose steaming leak.
You probably disconnected a vacuum hose that didn't get reconnected. The mode doors are controlled by vacuum and the default id the defrost mode.
Mar 08, 2015 | 1991 Cadillac Fleetwood
GEW9878PW! electric dryer, evidently it isn't going into cool down mode
On the late models with electronic controls you either have a bad control OR a bad thermistor. The thermister mounts on the blower housing and the control measure the resistance drop on it as them clothes get dryer. That along with a pair of sensors that detect moisture inside the drum. As the clothes get dryer the less moisture is sensed until the control advances over to cooldown and finally off. So if the thermister is not working correct the temp would be off. The control is way more money than the thermister. I would clean it up first and make sure no air restrictions are causing overheating.
SERVICE MANUAL FOR DUET DRYER IF ON MY MANUAL PAGE AND FREE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 30, 2012 | Whirlpool GEW9878LW Electric Dryer
Where is the elertic vacume pump
your defrost door motor is in the default setting the mode conrtol door is bad replace it and the system will be ok it goes to default when it senses a problem in the mode motor . its very hard to change!
Jul 29, 2012 | Ford Cars & Trucks
How do you remove the battery from an htc sense
There isn't a phone called the HTC Sense.
But, I'll give you basic instructions for pretty much any HTC phone.
On the top or bottom of your device, there will be a small notch that if big enough for you fingernail, slowly pull that notch away from the phone and the battery door should come off. Then remove the battery.
Dec 24, 2011 | AT&T Cell Phones
The reduced engine power light is on in my 2005 Chevy Cobalt. In addition, it's sounds as though it's barely running. Any idea what it can be? The check engine light is on also, however I addressed...
The check engine light being on now is a different problem , Have DTC'S - diagnostic trouble codes checked ,will have something to do with electronic throttle control . That is what reduced engine power is about . It's in a reduced power mode.
When the ECM detects a condition with the TAC system, the ECM may enter a reduced engine power mode. Reduced engine power may cause one or more of the following conditions:
• Acceleration limiting--The ECM will continue to use the accelerator pedal for throttle control; however, the vehicle acceleration is limited.
• Limited throttle mode--The ECM will continue to use the accelerator pedal for throttle control; however, the maximum throttle opening is limited.
• Throttle default mode--The ECM will turn off the throttle actuator motor and the throttle will return to the spring loaded default position.
• Forced idle mode--The ECM will perform the following actions:
- Limit engine speed to idle by positioning the throttle position, or by controlling the fuel and spark if the throttle is turned off.
• Engine shutdown mode--The ECM will disable fuel and de-energize the throttle actuator.
Do you know what electronic throttle control is ?
Throttle Actuator Control (TAC) System Description
• Accelerator pedal position sensing
• The accelerator pedal position (APP) sensors
• The engine control module (ECM)
Your best bet , take it to a qualified repair shop .
Dec 24, 2017 | 2005 Chevrolet Cobalt
Command mode change disabled remote
According to Sony, if you turn the power on and hold the Enter key and the #1 key down together for at least 3 seconds, everything will default back to factory settings.
Mike
Feb 01, 2009 | Sony RDR-VX515 DVD Recorder/VCR
Printing documents backwards
You must have set it to be a mirror copy in the print settings.
Oct 23, 2008 | HP PSC 1315 All-In-One InkJet Printer
After alignmentment, scope points backwards
If you can RESET the hand controller do it-- then re-enter TIME, DATE, and SITE. Make sure you are in ALT AZ Mode and NOT Polar Mode if you do not have a wedge.
This is probably the issue-- you are in POLAR MODE by mistake.
www.telescopeman.org
www.telescopeman.us
www.telescopeman.info
Mar 29, 2008 | Celestron Ultima 2000 -- 8 Telescope
Dryer stuck in sensing mode
Since no help was available without premium assistance, I actually contacted a repairman. He performed all the tests again and told me the problem was the control board. Then wanted $600 to fix. I found the part online for $150 and fixed it myself in about an hour. Instructions were easy.
Sep 08, 2007 | Hoover HDC6 Electric Dryer
Sony Wireless Controller for PS3 Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
