Hi i have a Sharp Toploading ES-FG55 washing machine but i dont know its buttons language pls help me how i can set its timer start pause or stop
  • 6 Answers
SOURCE: top loading Maytag washing machine is overflowing
water level switch is bad
Posted on Mar 30, 2009
  • 3 Answers
SOURCE: GE washing macine stops during the wash cycle
This is exactly what my machine was doing, as well. I fixed it by cleaning out the filter in front of the water pump.
Searching here, I found that you can remove the lower front panel (three screws along the bottom edge is all it takes) to get to the filter. With the panel removed, you'll see a round white plastic cover (about 3-4 inches diameter) that screws out. Get a bucket under the cover to catch the water that's in it (could be 2 quarts or more) and unscrew the cover.
The cover pulls out, revealing that is actually a screw-in plastic strainer. I found tons of coins, broken pens, paper clips, etc. in mine when I did this. A lot will be deep inside the black rubber hose that connects this filter housing to the washer drum. You can rake the stuff out with a bent wire clothes hanger. Shaking the black hose will help hurry the junk along and out of your machine. Screw the cover back on after the clean out and your machine should go back to normal.
Thinking about it, front loaders will have lots of small items flushed into the pump compared to top loaders. Coins you alway found in the bottom of the drum in a top loader, they all wind up in the filter of a front loader. And once it slow the drainage to a crawl the machine will shut down multiple times when it can't drain the water out completely, and it will never step up to it's max spin speed with all that water still in the drum.
Posted on Nov 30, 2009
SOURCE: My instruction manual of Sharp ES-S701X washing
I have a copy, can scan and email to you,let me know, kumanan1950@yahoo.com
Posted on Mar 08, 2010
  • 59 Answers
SOURCE: hello sir ineed assistence with
yes but what is the problem?
Posted on Aug 30, 2010
blueextc3221
  • 15935 Answers
SOURCE: Sprays water during the final spin leaving wet clothes
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 15, 2010
Unlocking sharp
These machines are set that way. Once started, even if you stop it you have to wait for a timer to unlock it which takes about 3 minutes.
Jun 30, 2013 | Washing Machines
Hi, I'm using Panasonic Aquabeat NA-F130T1.(13kg),Fuzzylogic,Toploading. It stops at end of wash mode before rinse and blinks U12 code. Pls advise? Thanks.
Hi there, I'm using Panasonoic F130T1 washing machine.
my problem is,the washing did'nt complete n the water remains in the machine.
Pls advice as how i could solve this problem,tq.
Azhari.
Jan 11, 2013 | Washing Machines
Aquacycle 1000 will not operate the 30 minute short programme. Advice please
i think there might be some programming fault .
so set the timer again or
start pause button
after having selected the required programme press this button to start the machine the corressponding pilot light stop falshig.
to interrupt the programme which is running depress the start/ pause button the corresponding light start to flash.
to restart the programme from the point at which it was interupteed
press the start/puase bitton again.
Jan 14, 2012 | Washing Machines
Door lock is on and dont know what button to make it go off
If you can't pause the machine by hitting start and have it unlocked, turn the washer off then try unplugging the power cord, waiting a few minutes, and then plugging it back in. It should reset the lock timer.
Apr 18, 2011 | Frigidaire Washing Machines
I have an Electrolux EWD1477. I have been away for four months and I'm having problems with it. I set to do the quickwash30 program and press start, you hear the clicks, it might put some water in then...
My EWD1477 was doing this a year ago and I fixed it. Then it started doing it again a month ago and I seem to have cleared it again.
Firstly, remove the drain hose from where it is inserted into a laundry sink hole to make sure it is not blocked or sealed in with sludge.
Secondly, make sure the machine is empty of water and clothes and then turn the machine to off with the Program Selector Dial. Then turn off the power at the socket and remove the power plug and leave for five minutes.
Step 1: put the plug back in and turn the power back on.
Step 2: turn the selector switch to the right (Whites/Intensive). The green light of the Start/Pause button should be flashing and the green lights on for Prewash/wash, Rinses and Spinning. Don't press any other buttons or change any other settings.
Step 3: press the Start/Pause button and wait for the machine to empty any excess water. Press it again immediately after you hear water flowing into the machine OR two audible clicks. The machine is now in pause mode with the green light of the Start/Pause button flashing. Only the green light on the Prewash/Wash button should be on. Leave it in pause mode for 30 minutes and then press the Start/Pause button to recommence the cycle.
Step 4: If the Start/Pause button begins flashing, water stops flowing into the machine and the three green lights mentioned above are back on, turn the Program Selector Dial back to off, wait 10 seconds, and repeat the process above.
Step 5: If when you then turn the Program Selector Dial to Whites/Intensive and hear the two audible clicks, immediately press the Start/Pause button to set the machine in pause mode. Wait 30 minutes. Then press the Start/Pause button to recommence the cycle.
Hopefully the cycle will run without a problem.
Mar 26, 2011 | Electrolux Washing Machines
The start/pause button is flashing
timer is failed. replace the ECU.
Jul 10, 2009 | Electrolux EW1000i Front Load Washer
Indesit W1A111 starts cycle when selector set to "off"
many indesits have a memory on board, set the timer to off position, turn on the mains press start let the machine finish what it is doing, and it will reset normally, turn off at mains for a few minutes can also do the trick, it sounds like one of the option buttons was pressed and you didn't let the timer finish its course,
Aug 29, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
65 people viewed this question
Top Washing Machines Experts
