Question about Sony DSCW320 Digital Camera
My camera lens doesn't opens - Sony DSCW320 Digital Camera
    Guru:
  • 441 Answers
Good day,
This tip will explain a few methods on how to try and fix your lens if it is stuck or you get a lens error on your screen.
Please note that all these methods are used at the users own risk and that I can not be held responsible for any damages or losses that occur while trying these methods.
1. If your camera is still under warranty, send your camera to the manufacturer to be replaced or fixed professionally.
2. If your camera is out of warranty try these methods.
  • Make sure your batteries are fully charged.
  • Remove the batteries for 10min. Replace the batteries and see if the problem persists.
  • Try compressed air. This method can be useful if there are any sand or any other object stuck in the lens motors. Use compressed air with a fine tip. Direct the air between the camera body and lens and move in a circular motion around the lens to complete a full rotation.
  • You can also try to tap the padded USB cover firmly on a flat surface like a table. This is sometimes a surprisingly effective method.
  • The last method is to try and force the lens. Turn of your camera and place it on its back on a flat surface. Look at the spacing between the lens and the body and see if the gap is consistent all the way around the lens. If the gap is not even it is likely that the camera fell while the lens was extended. Now VERY GENTLY push down on the lens were the gap is the biggest until you her a "click". This will indicate that the lens is back in place. Try powering back on.
  • If the lens does not extend or it extend and retracts turn of the camera. Hold the camera in your one hand and with the other hand turn the one part of the lens in a circular motion. Rotate both sections of the lens until you hear a "click". This will indicate that the lens popped back in place. Power the camera back on.
  • The last method you can use is to turn the lens while powering on the camera until you hear a "click". Power the camera of and back on to see if it works.
If any of the methods listed above failed to work for your lens problem it would be wise to take it on to a professional to get your camera repaired.
Thanks for taking the time to read my tip and feel free to let me know if it was of any help.
Regards
15073327
Posted on Mar 25, 2011
Lens doesn't work
Try removing the battery and memory card for at least 15 minutes. With some cameras, this will reset the camera and lens may clear the error message, as long as there is something that is not physically damaged the camera.
Jan 20, 2013 | Kodak Easyshare C195 14 Mega Pixels...
What does fEe mean on Nikon 35 mm camera
This means that the lens doesn't have its aperture ring set to its smallest opening.
Turn the aperture ring to its smallest opening (largest f/fnumber) and lock it if the lens has an aperture ring lock. You control the aperture from the body, the same way as with a lens without an aperture ring.
Apr 01, 2012 | Nikon Photography
My d80 is flashing fee and wont take no pics
You're apparently using a lens with an aperture ring. Turn the ring to its smallest opening (largest f/number). You can control the aperture from the camera body, the same way as on a lens without an aperture ring.
If this doesn't do it, please reply to this post specifying the lens(es) you're using.
Sep 25, 2011 | Nikon D80 Digital Camera with 18-135mm...
The camera starts up and shows the blue sanyo screen. Then the screen turns black then shuts off. The lens doesn't even open. I've tried charging the battery and that is not the problem. What's...
Hello ..Yes please make sure your batteries are fully charged..If battery is charged and still shuts down..There is a good chance lens was hit or bumped.When lenses are bumped the camera will try to extend lens upon power up as part of cycle.If camera detect problem with lens not opening..Then it will shut down...
Sep 23, 2011 | Cameras
Foldable lens cover doesn' t open and closed fully... Thanks.
It's usually merely a grain of sand or dust jamming it. But it's also usually easy to fix. This link outlines repair techniques for a stuck automatic lens cover. Recommend trying the less "risky" ones first before considering the end of the lens.
Dec 27, 2010 | Canon PowerShot A610 Digital Camera
Camera doesn’t start
The only solution that I found is to take off the battery from camera. After I reconnect the battery, the camera starts without any problem (lens are moving, LCD is on, AF is also on). The battery status is full.
Sep 12, 2005 | Samsung Digimax V5 Digital Camera
Sony DSCW320 Digital Camera Logo
54 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
