Question about GPS
Binatone b430. recover the hive partition, on screen all the time
How do i update my sat nav b350
usually they come with a disc that needs to be installed on your PC, then when you connect your device you should be notified of any updates. Failing that, try going to their web page, or drop them an e-mail
Jul 16, 2014 | DURAGADGET USB Data sync computer...
Message missing operating system
This sounds like the main partition on your harddrive was corrupt. You will need to reformat the system.
Using the Recovery Partition:
1. Press [F9] during bootup.
2. Press [Enter] to select Windows Setup [EMS Enabled].
3. Select the language you want to recover and click
Next.
4. Read the ASUS Preload Wizard messages and click
Next.
5. Select a partition option and click
Next. Partition options:
Recover Windows to first partition only.
This option deletes only the first partition and allows you to keep other
partitions, and to create a new system partition as drive "C".
Recover Windows to entire HD.
This option deletes all partitions from your hard disk drive and creates
Recover Windows to entire HD with two partitionThis option deletes all partitions from your hard drive and creates two
new partitions "C" (25%) and "D" (75%).
6. Follow the onscreen instructions to complete the recovery
process.
Make sure to burn off your recovery DVDs as soon as you get you rsystem back up and running so that you have them in an emergency.
Feb 28, 2013 | ASUS X53U-RH11 New
How do i update my Binotone 430?
You should be able to find out how to correctly update it in the manual. You didn't specify exactly which 430 model you had, but here are the links to each of them. Hope this helps you out.
Binatone R430 Sat Nav GPS Manual
Binatone D430 Sat Nav GPS Manual
Binatone G430 Sat Nav GPS Manual
Binatone F430 Sat Nav GPS Manual
Binatone B430 Sat Nav GPS Manual
Feb 05, 2013 | GPS
Binatone B430 . Says no GPS driver found . Will not connect to satelite
Please contact me again if you still need help for the same. sorry for the delay..
Nov 12, 2011 | Toymax Binatone Carrera X350 Car GPS...
Please tell how to reset my computer to factory defaults
If you Toshiba is a fairly recent laptop and there is a Restore partition on your hard drive.
To restore your Toshiba to "Out of the Box" condition then please click on this link and follow my instructions :-
http://www.fixya.com/support/r8248520-restore_toshiba_out_box_condition
Mar 11, 2011 | Toshiba Satellite L455DS5976 Notebook
Need fly b430 mobile unlock code
plz enter code on fly b430 1122 this code for for fly b430
Jun 03, 2010 | Nokia N70 Cellular Phone
My Binatone B430 will not load its software - simply displaying 'License key error code bla -bla-bla'. Also, why has it come with an SD card installed - designated W.Europe? This is my second machine in a...
Take it back to where you bought it from. Its a software problem, i called up Binatone with the same problem and was given a reference code to give to retailer upon returning the item.
They are ****! Replace it with another one or buy another brand...
Jan 02, 2010 | GPS
Nc6000
Okay, then you'll have to go to the second of my previously posted recovery tasks... For reference...
(b) For this one, you're going to need to move files. For that, you'll need a Windows CD. If you have an extra one around so you can boot to the Recovery Console, you'll be fine. Assuming you find one, then just follow the steps on this page --> Recovering HIVE Files. That will get Windows back to functional status, but you will have to reinstall your programs because even though they're there, you're recovering to a pristine version of that registry file that doesn't include any non-Windows software, so Windows can't use it.
Good luck, and post back with how it goes.
Jan 04, 2009 | Computers & Internet
GPS Logo
148 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
