Question about RCA 25413RE3 Corded Phone
I cannot get the caller ID to work on all phones. We are currently using 4 phones in the office and the caller ID works on 3 of the 4.
  • 225 Answers
The RCA 25413 phone does not have caller ID capability. I have included a link where you can download the manual. On page 16 of the manual it says in a note that caller ID does not apply to the 25413 model phone.
http://www.rca4business.com/products/pc/pdf/instruction-book/25413RE3.pdf
Posted on Mar 25, 2011
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
Our phone system rings three times (on the caller's end) before the standard greeting connects. We use Avaya and Caller ID and it seems it is standard with that program and calling feature that the...
Is this an IP Office?
This is how it works. For some reason the IP Office waits for teh first 2 rings to get caller ID, and then lets the call ring in.
Sep 07, 2011 | NorStar M7324 Telephone
Caller id doesn't work for iphone 4
Caller ID is a staple in every iPhone. Your service provider may have blocked your Caller ID, so make sure to check with them first. To check if your iPhone has enabled the Caller ID setting:
1. Go to settings.
2. Click on Phone.
3. Click on Show my Caller ID, and select Yes.
Jun 14, 2011 | Apple iPhone (16 GB) Smartphone
StarTalk Flash is 1.7.00 + caller ID
The Star Talk Flash is a voice mail prduct. The caller ID feature is a phone system feature. If your system is a norstar CICS or a MICS the caller ID will work only if you have the caller ID capable central office circuit packs installed. Look on the card and see if the label has "CLID". If it dose there is also additional programming required for each set under.... terminals &sets/telco features/featue assignments/show line/caller ID...set:Y. You also have to program (under sets) /telco features/caller ID: Y.
Hope this helps.
Mar 24, 2010 | NorStar M7310 Corded Phone
AT&T 974 Caller ID has quit.
Unplug everything then replug should reset the Caller ID
Dec 11, 2009 | AT&T ATT-974 Corded Phone
Lucent Partner 18D - Caller ID not working
The caller id information is sent from your local telco provider after the first ring and might not be able to be extended to the individual sets, try backing off the ring to answer on your voice mail from 2 to 3 rings to see if the information is then passed on. The Voice Messaging System message is being sent from the system showing who transfered the call to you. You should also notice that the ring pattern when that message is displayed is a standard ring followed by a beep meaning a transfer is taking place.
Nov 20, 2009 | Lucent PARTNER18 Corded Phone
Caller ID Stopped Working - Think the phone needs to be reset?
Not sure why this worked, but I went to the Menu and the Set Area Code selection. The area code setting was blank, so I entered my area code and saved it. Caller ID started to work again. As a test, I went back to the Set Area Code selection and deleted the area code and saved it. It is currently still working. Seems really odd, but it worked for me.
Jan 08, 2008 | RCA 25414RE3 Corded Phone
This is a Definity system phone. The phones themselves have nothing to do with caller ID, it's the system that handles it. The phone line has to have the caller ID service AND the phone system needs to collect the information and then display it on your phone. If you are sure caller ID service is available on the phone line you are using than this is a programming issue. Definity is a huge system and you cannot program it yourself. Someone in your building is either in charge of making simple changes in the phone system or contacting the company that makes these changes for you.
Aug 20, 2007 | Avaya Definity 6408D Corded Phone
CALLER ID NOT WORKING
not only Panasonic, most other brand phones imported from other countries wont work in in India ( caller ID). Panasonic phones of Panasonic India, will work.I think panasonic has to explain this. if there are networks which does not support this equipment, atleast they should mention this is their booklets, to avoid users roam around telecom offices. To my understanding, all the land phones of BSNL through out India are caller ID enabled by default and is free!.
Aug 19, 2007 | Panasonic KX-TG2632W Phone
Caller id
Caller ID in the USA uses the FSK standard. For the most part, caller ID in India uses DTMF (although I have heard of some FSK usage).
I am currently living in New Delhi and have an Airtel home phone line. My switch uses DTMF. I went to the Palika electronics bazaar (I aways use shop number 266 near gate 5, they seem to be a little kinder to foreigners as far as the "final price") and purchased an DTMF to FSK convertor. My US phones now show caller ID information, although using US number seperations ### - ### - ####. I paid R500 but you could probably get it for around R400 if you are willing to put in the time bargaining. It looks like they are also available on Indian Ebay.
Mine says UST001B. It looks like these are low volume items because they stuck the components into a box marked "DSL Splitter" It works to convert the caller ID as advertised.
May 03, 2007 | Siemens Gigaset 4215 Cordless Phone
RCA 25413RE3 Corded Phone Logo
748 people viewed this question
Top RCA Lands Phones Experts
David Burbee
David Burbee
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
