Question about Sharp Office Equipment & Supplies
I have ar AR-M277 which is not scanning, the message on the copier reads" Server Access Denied. Check account information on device web page." I know this is probably and IP or DNS problem, can someone help with this remotely or talk me through the repair?
  • 3 Answers
SOURCE: NO IP ADDRESS FOR THE AR-C270 sharp copier!!!!?
Custom settings, List print, Print test page, NIC Page.
Posted on Jul 27, 2007
how whee
  • 8 Answers
SOURCE: D-Link Print Server Compatibility issues
DP-300U Print Server is not compatible with Sharp AR-5320. Pls check D-Link website on the list of compatible printer. For USB Print Server that is compatible with Sharp AR-5320 try Intellinet.
Posted on Feb 21, 2008
Bubbabear64
  • 2794 Answers
SOURCE: IP Address on a Sharp AR-M237
The easy way to do it is to set the copier up for AUTO DHCP.  That way the copier will connect to the router and assign a free IP address to the copier.
Then go into internet explorer and type in the ip address of the copier.  If you can get a control panel screen of the copier to appear.  It worked.
Once you get the IP address, take it off of AUTO DHCP and type in the IP address that the router assigned to the copier.
Posted on Oct 16, 2008
  • 148 Answers
SOURCE: Sharp -COPIERS - AR-5316
If you go to this web page:
http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
You should be able to find the driver for that machine.
Hope that helps.
Lbcoaster
Posted on Nov 14, 2008
  • 118 Answers
SOURCE: How do i change the IP address on the sharp ar 275
press printer button >special key then you can browse through arrow button check there you can see how to change IP address
Posted on Jul 19, 2009
Due to a power surge, my Sharp AR-M277 won't turn
There is a 20A fuse on the AC power board it is most likely blown. Follow the power cable to the board the big white ceramic fuse is the main, check continuity with meter and replace.
Sep 02, 2011 | Sharp AR-M277 Digital Copier Copier
I'm trying to use my Sharp AR-M355N as a scanner for the first time. I've already made sure it's properly hooked up to the network and have successfully printed to it. I scanned a test page, put in the...
When scanning to e-mail you would need to enter the details of a smtp server e.g. Gmail, as well as your DNS settings into the photocopier via the web browser. To access the browser, enter the I.P. address of the copier into the web address & this will give you the front page of the copier. To access the network settings you'll need the user name : admin & the password Sharp. Depending on the firmware version the machine must have SSL installed, if it hasn't then unfortunately you will not be able to scan to e-mail. The alternative is to scan to SMB (folder), again this is set up via the web browser.
Hope this helps.
Dave.
Aug 26, 2017 | Sharp AR-M355N Copier
Does a Sharp AR-M277 use 1 or 2 bags of developer?
Hi, the Sharp AR-M277 takes 1 bag developer (type AR-271MD).
Jan 05, 2011 | Sharp AR-M277 Digital Copier Copier
I am an IT pro who has an AR-M355U. We are having a problem with some new email addresses we entered. We changed the suffix of the address to a new service, and the decive stopped sending scans to our...
CE-O3 = The specified server suspends reponse during transmission of images.
Cause: Improper connection of the network cable, An error occurs in the SMTP server/FTP server/ NTS
Check: Check that the network cable is properly connected.
Check the SMTP Server/FTP server for any trouble.
Aug 23, 2010 | Sharp AR-M277 Black and White Copier
How to scan a document using a Sharp copier model number AR-M277.
Requires optional network scan kit. When installed it comes with software for scanning
Jul 17, 2010 | Sharp AR-M277 Digital Copier Copier
We cannot scan to email from our Sharp AR-M237 Multi-function "Error[973]: Incorrect format for Primary SMTP Server." I am using all the settings for SMTP that I use everywhere else. HELP?-pjm
Model AR-M257 - I have several Sharp MFP devices at different locations and all are set up to scan through our email server using a special account I have just for this purpose. I have all of them setup using the external IP address of our Exchange server (not its name or FQDN) and I have firewall rules setup to allow SMTP from the WAN IP addresses of our different offices to the LAN IP address of the Exchange server. It worked at all the others but this one. I was getting the following error when trying to send a status message (under Log) from the device to my email account as a test: [error 973] incorrect format for primary smtp server. And when I tried to scan through our email server I would get "network error". However, a connection test succeeded. I had everything set correctly for SMTP and DNS but as I was trying anything I could to get it working I went to mDNS under Services and it was enabled. I disabled it and then I could get a status message to be sent to me and we could send a scan through our email server.
Apr 12, 2010 | Sharp AR-BC260 Color Copier
Getting a CE-02 error when trying to scan.
1) Check that the Network Cable is
inserted properly.
2) Check that the connected network
supports TCP/IP protocol.
3) Check from the Web Page that the
Primary/Secondary E-mail Server
Address or the Destination FTP server/
Desktop PC address are properly set.
4) If the above address is described with
Hostname, check that the DNS server
is properly set.
5) Check that the SMTP server/FTP
server/NST causes a trouble or not.
Jun 10, 2009 | Sharp AR-275 Copier
Scanner
If you go to copiers web page you will find address book in that, to axcess web page type in copiers ip address in web browser (explorer) , you can find copiers ip address by printing out config/setting page of copier or looking at print driver port setting on pc, a IP address look like this 123.123.001.023
Oct 29, 2007 | Sharp AR-M277 All-In-One Printer
Network Error on display
Have you setup your smtp address on the machine? From any workstation in the same network open your web browser. Key in the IP address of the mfp copier. Goes to network setup and key-in your smtp address.
Sep 14, 2007 | Sharp AR-M277 Black and White Copier
160 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
