Question about Keurig B60 Coffee Maker
I have a Keurig Platinum B70 model and it sometimes dispenses less water. When it does dispense less water, I can see water returning to the reservoir. How can I fix this problem?
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Apr 02, 2011
  • A Brown Jun 09, 2013
    D. Floyd! You are the man! Thanks for helping me fix my Keurig. It was plugged in the dispenser and though I had gone at it before I used you suggestion of the paper clip. Mom-In-Law will be happy when she is able to brew her coffee! Wife will be happy I got it running! When the momma's are happy, I'm happy! Thanks - Allan
Won't dispense water nearly as fast as it should
Hello if you have tried everything and it is still not working the way it should check to see what the warranty is if you still have the instructions if not call Keurig support.at 1-800-361-5628 and give them your model number..
Hope this helps. Good luck ,All the best!
Feb 09, 2016 | Keurig Platinum B70 Coffee Maker
Keriug water reservoir won't dispense into inner tank. what to do?
Lift the reservoir, then reseat it. This will clear the prime message. If it repeatedly comes back then your machine is dead. If in the year warranty, call Keurig they will ship you a replacement. Common Keurig problem
May 23, 2014 | Keurig Platinum B70 Coffee Maker
My coffee maker states that it is brewing but it doesn t take any water out of the reservoir nor dispense any coffee
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Sep 19, 2011 | Keurig Platinum B70 Coffee Maker
Our newer Keurig B-70 is only sending an ounce or less of water to the K-Cup.
Hello. W/D here.
I wrote this earlier for another person, but perhaps it will be of use to yourself as well......
A lot of people have luck with clearing the needles to improve their Keurig's operation. Here's how:
Take an ordinary paper clip, and make it into an "L" with about 1" on the short side. Use the short side to probe up into the puncture needles on the top side of the K-cup, and the dispensing side as well. Frequently, grounds escape the K-cups and get trapped in the needles.
You can force the machine to produce more water sometimes by plugging off the return line to the reservoir with a gloved finger. The return is just below the level if the reservoir cap, in the back. It is a white fitting, and turns down. The water can be hot there, thus the glove. Sometimes this helps clear the lines.
Best regards, --W/D--
Please feel free to rate this solution. Thanks.
Feb 06, 2011 | Keurig Platinum B70 Coffee Maker
What is wrong with my Keuring Platinum B70 doesn't always dispense the water when it says it is brewing?
The unit inside may either be needing a descale even thought the display doesn't say it... or... in my case. the electrical connections go intermittent...
to fix... the black plastic cover needs to be removed and the electrical panel cover (located in the right lower side ) needs to be removed, and all connectors need to be reseated...
for more info re-ask another question... on how to remove the black outer cover... I answered one problem with this procedure.
May 02, 2010 | Keurig Platinum B70 Coffee Maker
Our Keurig only dispenses a partial cup of coffee. We descaled as recommended and did the paperclip cleaning of the need,es and no improvement. When we press brew, it draws an appropriate amount of water...
Keurig coffee maker dispenses only part of a cup (about 5 ounces) after brewng one cup. Running a second clear cup (w/o K-cup) shows coffee grounds in cup of clear water. the maker will then brew a full cup of coffee. It appears that the top pin is too long and goes into the coffee after it punches through the top of the K-cup. Some of the gorunds appear to get stuck in the top pin.
Nov 10, 2009 | Keurig Platinum B70 Coffee Maker
Keurig B60 Coffee Maker Logo
582 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
