Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
I can't see files from that was put on the cruzer micro 2GB from one computer to the other.
  • SanDisk Master
  • 27,725 Answers
On the computer that you cant see the files
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
Posted on Mar 25, 2011
SOURCE: Faulty Memory Stick
ok ok..this 1 will mabe work...go controll panel administrative tools and device managment some thing like that...in the dignostik tools take the 3 option frome the second 1...in the left u will see the drive..mabe and hope u will...if u did see the drive than ur problem is not that bad...i canot tell u wat to do becose u mabe need a litle of cracking tools the easiyest way is go 2 google and search under live cds recovery and something lik eit or ghost live cd..dowload the file and burn it on a disk..enable ur boot frome cd rom in the bios setup menu and boot frome it..and u must go frome there..g luck
Posted on Feb 14, 2008
SOURCE: U3 2GB Cruzer Micro wont work on my vista laptop.
Just give up
Posted on Apr 03, 2008
SOURCE: how to install Sandisk Cruzer Micro USB 2.0 flash drive
Plug in the Cruzer, then go to My Computer and open the window for the Cruzer. Then drag and drop the files to it.
Posted on Oct 30, 2008
  • 77 Answers
SOURCE: Cruzer Micro 2gb Flash disk - Lights Out
Get this file. It's a rar file so you need winrar (http://www.rarlabs.com)
http://rapidshare.com/files/144140884/FtR.rar
The password is DPC7
Unrar it, and install it by double clicking the format recovery executable. Installing is very easy, just follow the steps and click next.
Start O & O Format Recovery. Select the USB Drive. Click on  Analyze and follow the instructions and click next. It's easy to recover / restore files. Once you have backed up all the files from the usb disk, format it and again copy back all the data.
HTH,
Regards,
Deboo
Posted on Feb 17, 2009
ynotphone
  • 192 Answers
SOURCE: says "access denied"
It means that your System Administrator (IT people) shut off the USB ports so you can not bring in outside files -or- remove files from your work computer.
Some companies do this for security reasons.
The only way around this is to contact your System Administrator or IT people and state that you need the USB ports activated...
But they may say no to your request due to company security standards.
Posted on May 01, 2009
I'm using the cruzer 2gb mini and have placed a file on it that I transferred to another computer. Afterwards I deleted the file from the cruzer but when I tried to put another file on it it says there is...
Guest
The thing to check is to make sure you empty the recycle bin on the computer that you used to delete the file. Once you do this it should free up the space.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Jul 17, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How to put a file onto sandisk 2gb cruzer micro memory stick I haven,t much computer experience thanks
Im guesing this like a Jump drive and it is the same as mine what you need todo is plug it in to the comp and wait for the system to recognize it , Goto the computer folder and see if it register the drag an drop what you desire on the disk to be transported>(Presto you got it) Good luck its truely simple .
Remember your comp works for you.
Oct 18, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Says "access denied"
Apr 12, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
HTH,
Regards,
Deboo
Feb 17, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How to install Sandisk Cruzer Micro USB 2.0 flash drive
Oct 28, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk Cruzer Micro 2.0 problem
Should show up in "My Computer" as a removable drive with letter designator. Then it is simply a matter of drag and drop to copy files using the mouse. If XP doesn't recognize the drive, put it in another USB port, and or try it on another computer. If it doesn't show up then, take it back to the store.
May 18, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Problem with sandisk 2GB Micro USB Flash Drive
Work through My computer once putting the disk in the USB port. It should read "removable device". Click back and forth from c: drive to my computer to make the computer recognize it faster. Let me know what happens.
cynthia
Jan 09, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How to put music and video
simple as drag and drop. just plug it in to your usb port, and wait for autoplay to open it up. If it does not open up automatically, go to my computer and open it from there. Now you can drag and drop your files from your computer to your cruzer
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
61 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
