Question about Kenmore 93142 Gas Dryer
Will start, clothes will tumble but will not heat up to dry the clothes
  • Kenmore Master
  • 5,370 Answers
Run it with the vent off if you feel some heat for the first minute and the airflow is strong you best bet is to change the valve coils.The vent is not a part in the dryer the vent is was connects to the back of the dryer pull the vent off and run the dryer to test.
The coils are on the top of the gas valve.
Gas dryer with no heat: The parts that I have pointed out with the arrows are the parts that you will need to check with an ohm meter if the dryer is not heating. First check and see if you have 110 volts coming to the gas valve at this type of a connector. If you have voltage, then unplug the dryer and check the parts I have pointed to. Some dryers have 3 coils instead of the 2 shown here. If you do not have voltage coming to the burner, then you will need to check the timer contacts that feed the gas burner, hi limit thermostat, operating thermostats, the safety switch on the motor, and any other point that you can see on your wiring diagram picture that feeds voltage to the burner. The coils on the gas valve are very bad for working once or twice and then quitting. If you find a open circuit on one of the gas coils, replace them all = less problems later on. If the glow coil does not work ( get red ), check it with a ohm meter for continuity. The next thing to check if the glow coil does not come on would be the radiant sensor. Inspect the igniter for small burnt spot on dark gray or black part of igniter or check for 110 volts to igniter wire plug when dryer should be calling for heat. Sometimes the ( older style ) igniter is separate from the holder and the holder can no longer hold the igniter tight enough and the two parts burn/arcwhere they touch each other = new igniter and holder ( some manufactures have new kits to replace these older style parts ).
Does the igniter get red and stay red, or does it get red, you hear a click and it goes off, then a minute later its gets red again?....if so you possibly have a bad set of coil valves. If the igniter gets red and stays red constantly then its the flame switch that is bad and maybe welded closed.
Check out, this possibilities.This should help.Thanks.Helpmech.
Posted on Mar 25, 2011
Washer_tech
  • 164 Answers
SOURCE: Tumble Dryer not drying clothes
the problem could be several different things. first remove the front panel and see if the globar glows. if it doesn't check it for cracks and replace if needed. if it glows, replace your gas coils, they are usually the problem
Posted on Nov 01, 2007
Maytag317
  • 1136 Answers
SOURCE: Heat works and tumbles fine, but the clothes do not get dry
Hi, First thing you need to check is the vent that goes outside. Make sure it is not pinched or plugged in any way. If it is an electric dry, you can try one load without the vent if it is in a ventilated area so that you don't get a lot of humifity.
Please let me know if I have helped or if I can be of more assitance.
Thanks
Vic
Posted on May 14, 2009
  • 6 Answers
SOURCE: dryer working but no heat
Your dryer has two separate fuses, one to turn the drum, and one to heat it. It sounds like you have a broken fuse. Unless this is a new installation, then you need to make sure you have the proper electric cord attached. If it's mistakenly connected with a range cord, it won't supply enough power to the dryer.
Posted on May 20, 2009
guru_dev
  • 315 Answers
SOURCE: no heat in dryer.
First, I assume that the drum spins OK but there is no heat. Many things can cause this. From the most likely cause to the least likely:
1) An open thermal fuse. This is a small "thermostat" with 2 wires at the middle/top of the heater "box" (a tall narrow box on right in the back of the machine), or a plastic type on the duct close to the blower, depending on the model. You will need to remove the back cover of the machine to see these. Check with an ohm meter after disconnecting one of the leads, or jumper the 2 wires together to see if heater works (don't use this way though, fire hazard... replace the device) If this proves to be the cause of the problem, it would be wise to check all ducts and blower for excessive lint buildup. This will reduce air flow, causing overheating and blown thermal fuses.
2) A burned out heating element. Remove tall box on right, element slides out from the bottom together with the "carrier". Look for broken coil, or check 2 terminals at bottom with ohm meter.
3) Burned wires at connectors. Check for obviously overheated wire terminals at all sensors (thermostats and thermal fuses in back), heater box, main terminals where power cord hooks up, etc.
4) Bad thermostats. There are usually 2 or more. A high limit on heater box, just above terminals on the bottom. 1 or 2 will be on the duct next to the blower. Check these with an ohm meter (or continuity checker). Some have 4 terminals, the extra 2 small terminals are small heaters inside the thermostats which alter it's temperature characteristics. These will usually read around 4000 ohms or so. Check the 2 main largest terminals for continuity.
5) Only getting 110 volts: This is often overlooked, but if for some reason one of the poles feeding the 220 power from the house wiring is open but the other is OK (for example, houses with fuses where only one fuse is blown, or a bad circuit breaker with one pole open). The motor and timer run on 110. If the side of the 220 line that feeds the motor is OK but the other one is open the motor will run but the heater, which needs 220 will not heat. Check for 220 volts between the 2 outer terminals where power cord connects or between the 2 "hot" terminals of the 220 outlet the dryer is plugged into.
6) Bad centrifugal switch in motor. This is what actually turns the heater on, for safety reasons, so the heater cannot come on unless the fan is spinning. Otherwise without air flow past it, the heater would burn out.
There are 2 large gauge (usually red or yellow) wires going to the connector on the motor, these go to the contacts inside the motor that turn the heater on.
Posted on Jul 20, 2009
milten1
  • 1304 Answers
SOURCE: my kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Posted on Oct 05, 2009
E15 error code on hoover tumble dryer
Controls
  • The control unit on the tumble dryer will vary among different makes and models. The main purpose of the controls is to allow the user to select the drying cycle. You can choose the time and temperature setting on most units, while others allow custom settings such as moisture sensors and end-of-cycle alert signals. The controls may include a dial or a touch panel and LED screen display. Some tumble dryers allow you to independently select the appropriate time for the load you are drying and separate programs for temperature.
Motor
  • The motor inside the tumble dryer spins the basket to allow the clothes to tumble while being dried. The tumbling action allows the air to pass through the clothing to dry them faster. Heating laundry that is stagnant will likely dry the clothing on the outside while leaving damp clothing inside the pile. The constant motion, along with the heat and steam created by heating the clothing, reduces wrinkles. The motor also powers the fan that delivers the heated air to the basket of laundry. The heater can be an electrical element or gas powered.
Jan 15, 2013 | Dryers
Frigidaire Galaxy Dryer tumbles but heats to dry seldomly
What is the model number of the unit?
Nov 13, 2012 | Dryers
My zanussi TD4212W is tumbling but not drying the clothes.
Check the heating element, I'm sure it has burnt through.
Oct 17, 2012 | Dryers
Clothes not drying
Clothes not drying? Thats it? Does the dryer turn on at all? Does it tumble the clothes but doesn't get warm? If it turns on and tumbles but takes a long time to dry, then your heating element is not working. There is a thermal fuse right before the heating element that will open up if the vent becomes clogged and its gets too hot. The thermal fuse is not resettable and will have to be replaced. If the thermal fuse is o.k. then your heating element could be burned out. These two items almost require an electrical meter to read continuity to check them. Make sure the dryer is unplugged before checking these items.
Dec 21, 2011 | Zanussi TC7114W Electric Dryer
My dryer runs but does not heat up or dry clothes. What could be the problem?
I have a Kenmore dryer and it runs but won't heat up and dry the clothes. I don't hear the ignition even turn over. Please help. I can't afford to buy a new dryer at this time.
Feb 16, 2010 | Kenmore 62602 Electric Dryer
My dyer heats and tumbles, but doesn't dry
I'd check first for clogged vent hose or clogged lint filter or clogged vent flap on wall (outside).
If that's not a problem, it may be a faulty thermostat. Heating element is probably okay if it heats some of the time.
More info, let me know.
Charlie
Oct 01, 2009 | Kenmore Dryers
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Jun 02, 2009 | Kenmore Dryers
My GE dryer is tumbling & heating but not drying.
there may be heat but if your heating element is not working properly it will heat some but will not dry cloths
Nov 15, 2008 | GE DBL333EA Electric Dryer
Clothes dryer
washer dryer and dryer ony machines differ in a huge way. the big diff. is the drums on each are completly different sizes. the conventional dryer has the bigger, giving better air flow and tumble to clothes. the w/d has a smaller drum thus less air flow and less tumble between clothes. the best way to see this effect is remove half the clothes after a wash and then select a drying cycle. u will see that by giving the clothes more room to tumble free of each other rather than tumbling in a large ball will dry them. washer dryers are really only a marketing tool.
(ex main brand engineer)
Nov 12, 2007 | Candy DQW150 Front Load Washer / Dryer
Kenmore 93142 Gas Dryer Logo
141 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
