Question about LG Televison & Video
I want ot change my LG television Model 47LH40 to 1080p using my LG remote
    Guru:
  • 276 Answers
1080p video resolution can only be achieved by a Blu-ray Disc. Satellite TV, broadcast TV, cable TV do not actually send out 1080p resolution. So unless you are using a Blu-ray movie, you will not be viewing 1080p. Your HDTV has a NATIVE screen resolution and the TV will SCALE all incoming video to its native resolution. Most people cannot tell the difference between 720p and 1080i. 1080p signal sources are slightly sharper. But if you have a HDTV that is 1080p capable and you give it a 1080p source (Blu-ray Disc) and use a HDMI cable to connect, you will get 1080p, you do not have to change the HDTV as it will automatically display 1080p.
Posted on Mar 25, 2011
I have a 32" ln32c450 samsung tv that im trying to get into settings using a universal remote.i have tried every code known to man and cant get into settings.i can pull up the menu but when i try to...
Hi! I would send email to samsung at their web page and include the model of TV and model of remote you are trying to use.. They are very good to help out in these cases...
Jan 01, 2015 | Televison & Video
CAMPORT STUCK on???
I had ot go online to buy a remote control to use with my zenith concierge tv. It is the same model # as yours. I ended up paying almost 40 dollars for a remote made by lg who I believe bought out zenith. I believe you could problably just get a universal remote and get the same thing accomplished. I can do everything with the remote I ordered except the one thing I wanted it for and that is to turn up the volume. It says on the menu, custom, not preset, but it still will only go up halfway no matter what I do. I heard that you could program the tv to factory settings but I tried that with another remote and all it did was reprogram the remote so that it didn't work anymore. If you have any suggestions as to how I can get the volume to work on my tv, I would appreciate it as well
Dec 21, 2011 | Zenith B25A02Z TV
How would i program my rogers remote to my lg tv to be able to change the volume without having to use the two remotes
Please rate this solution if you find it helpful:
It would help to specify the model of remote control or TV, however, here is the guide to programming your Rogers remote for any television:
http://www.rogersdiscover.com/cable-tv/learn-about-your-rogers-remote-control/
Oct 14, 2010 | LG 42LC2D 42 in. LCD HDTV
Tv doesnt respond to buttons or remote
this is looking like a common LG problem our tv started doing this tonight
May 15, 2010 | LG 42LC2D 42 in. LCD HDTV
Remote control code
Television Direct Codes for Sky remote:
Goldstar 065, 405, 318, 245, 275, 037, 060, 391, 137, 459
Here are the codes for GoldStar which became LG. They might be the same.
Good luck,
Techjoel
May 09, 2009 | LG Televison & Video
Need remote code for LG HDTV model 47LG90...
Just bought an LG 32" HDTV and have the new Samsung STB, with a Scientific Remote; the code in the remote manual for LG says to use 1005, but after trying it and many others, I used the "Find Code" set-up (991) and (990) in the remote manual and happened upon 1004 for the LG.
While this worked, the remote is a bit awkward, as you have to enter yet another code (998) in order to control the Power for both the TV and Box with the remote; the good news is that the instructions to do this are pretty straightforward and well presented.
Now, I can turn both TV and Box on/off with power button on remote, can change channels with remote and also vary volume with remote!
Hope this helps
Mar 29, 2009 | Televison & Video
LG TV renote not worknf on 4 new sets
If you have a cable box (otherwise known as a set-top-box) that you have to turn on when you turn the tv on, and you use to change your cable channels, the LG remote will not control it. The LG remote is strictly for the tuner built into the television, and is not capable of controlling the cable box.
You probably see "function not available" because you are viewing the picture on an external input of the tv (component, composite, etc). Your tv cannot tune stations in when it is set to an external input that you use to watch DVD's, cable boxes, games, and other devices. The tv is telling you that you can't change channels if it is on an input.
I hope this helps you...
Jan 20, 2009 | LG Televison & Video
PURCHASED 52" LG LCD HAD A GREAT PICTURE.ALSO HAVE DIRECTV. TOUCHED THE MENU BOTTON SAW THE AUTO TUNING, THOUGHT THAT WOULD BE A GOOD FEATURE. WENT AHEAD AND LET IT RUN THROUGH ALL THE CHANELS. NOW IT...
Because you have DirecTV there is no need to use auto tuning. You simply changed inputs on the TV when you started auto tuning. Just use the input button on the remote to go back to the Direct TV receiver. Most likely it will be under Component (Color Stream) or HDMI input.
Dec 31, 2008 | LG RU-27LZ50C 27 in. HD-Ready LCD...
Remote control of LG 42LB5D
Here's a link to order the original LG remote control for this model (42LB5D) from a major parts distributor. Please note, you would have to verify the complete model number of the unit as their are 2 versions available (there should be either a C or F at the end of the model #):
LG 42LB5DC Replacement Part Remote Control
LG 42LB5DF Replacement Part Remote Control
Oct 30, 2008 | LG 42LB5D 42 in. LCD Television
Televison & Video Logo
197 people viewed this question
