Question about Yamaha HTR6230 Receiver
My yamaha av receiver is not getting turned on?
    Sniper:
  • 54 Answers
Please check big transformer if prime coil is open, it happened a lots
Posted on Mar 25, 2011
I'm trying to connect a DVR to my Yamaha HTR-4066 receiver, but it appears there's no signal coming from the AV-OUT ports.
You need to connect cables from your TV to the AV input ports on the receiver to get a signal out.
Jul 28, 2017 | Yamaha Televison & Video
Tip
Reset factory default settings for yamaha HTR-5650 AV receiver
How to reset yamaha HTR-5650 AV receiver (maybe others) to factory default settings:
1. turn power off.
2. press the 6ch input and stereo button simultaneously for 4 seconds. Then while holding down these 2 buttons, turn the power on.
3. press preset tuning to the right until option #9 is selected.
4. Then, press program button until the *RV option is selected.
5. turn power off, wait 10 seconds.
6. turn power on, settings are reset.
on Feb 10, 2009 | Yamaha HTR-5650 Receiver
I have just brought a rx-v367 av reciever and have connected it to my tv/ speakers. speakers work fine when testing set up. however there is no sound coming out when connected to tv. also it keeps coming...
Hi, Yamaha audio-video receivers are equipped with a variety of connecting jacks for hooking up different types of electronic equipment. Component AV cables are typically used for hooking up the receiver to a cable TV box. Component cables can also be used to connect the Yamaha receiver to an HDTV, although a High Definition Media Interface (HDMI) cable offers a simpler connection if the receiver is equipped with HDMI (all HDTV sets are equipped with the distinctive, six-sided HDMI jack). The connections should take less than five minutes.
Instructions
Things You'll Need:
* 2 sets component AV cables
* HDMI cable
Check the back of the Yamaha receiver to determine if HDMI is available. The six-sided jack contains 19 holes set in three rows. If the receiver is equipped with an HDMI Out port, use an HDMI cable to connect to the TV by inserting the plug straight into the jack with the wider end turned upward.
Insert the red, green and blue plugs on a set of component AV cables into the Video Out jacks on the cable TV box, matching the plug colors to the jacks.
Connect the plugs on the other end to a set of Video In jacks on the back of the Yamaha receiver. Make a note of which jacks are used for the connection. Each set of jacks is labeled on the receiver.
Insert the audio plugs on the component cables into the Audio Out jacks on the cable box, using the white plug for the left channel and the red plug for the right.
Attach the plugs on the other end to the Audio In jacks on the Yamaha receiver.
Use a second set of component AV cables to connect from the AV Out jacks on the Yamaha to the AV In jacks on the HDTV only if an HDMI cable was not used.
Feb 18, 2011 | Yamaha RXV367 Receiver
Not getting on yamaha av reciever rx-v363
IF IN WARRANTY SEND BACK FOR SERVICE...
Apr 04, 2010 | Yamaha RX-V363 Receiver
Yamaha rx-v456 av receiver, shut down with optica cable
Does it work without PS3 attached?
When receiver turns off, it is usually due to badly connected/configured speakers. Try powering on the receiver without speakers.
Jan 06, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Yamaha RX-V550 AV Receiver Stuck on Zone 2
You can always do a system reset. there should be instructions in the handbook
Nov 06, 2009 | Yamaha RX-V550 Receiver
HTR-5930
To get audio from your TV through your AV receiver, please connect stereo audio cables from an available AV input on the rear of your receiver such as D-TV/LD or CBL/Sat. Then refer to your TV owner's manual for more information about audio output to an amplifier. You may have to turn off the internal TV speakers in order to get any output from the TV into the AV receiver.
Feb 17, 2008 | Yamaha HTR-5930 Receiver
Yamaha av receiver rx-359
go to best buy and buy a new recever
Jan 12, 2008 | Yamaha HTR-5560 Receiver
Yamaha HTR6230 Receiver Logo
75 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
