Question about GE DSXH47EGWW Electric Dryer
I have a GE dryer model number DSXH47EGWW. I replaced the plug in back. After doing so the dryer will turn on for under 30 seconds but then trun off and beep. I can use the dryer under a test mode and it functions normally. I would like to be able to run the dryer normally though out of test mode. how do i do this?.
  • chelseacleve Mar 25, 2011
    it turns on, beeps once and the light above the pause button all flash continously until i push another button. I check outlet and plug. Im getting 110 from each side and the plug is secure and hooked up correctly
    The dryer turn on then quickly shuts off. Beeps once and all of the lights above the pause button start to flash continously until i hit another button. 110 coming from both sides of outlet and new plug hooked up securely and correctly.
  • 1,998 Answers
How many times is it beeping and do you have any error codes or flashing lights when this is doing this? first thing that you should do is assure that you have 110 comeing in from both sides of the outlet and also assure that the connections you made when you hooked up the new plug are tight and in the right positions as well I await your reply Thanks Rick
p.s on some units the amount of times the unit beeps gives which error the unit is showing as a fault along with any flashing lights
Posted on Mar 25, 2011
  • Rick Ead
    Rick Ead Mar 25, 2011
    check the hi and the low thermal limiter you can do this by doing continity tests on each whichever is at fault replace the hi thermal tells the unit when to cut off the tempreture if it is not working it would shut down you unit after a short amount of run time tghis is the part number for you thermal limiter as well WE04X10094 and this is the schematic for your entire machine as well http://www.searspartsdirect.com/partsdir...= DSXH47EGWW&blt=06 there is also a safety thermostat built in at 1233 on this diagram as well http://www.searspartsdirect.com/partsdir... the thermal limit is at 1236 both of these can be checked by doing continuity tests if you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
  • Rick Ead
    Rick Ead Mar 26, 2011
    awaiting your reply on how your comeing along with your reapair Thanks Rick
Why does my ge model number dsxh47egww not heat?
Could be the element or the thermal fuses or other fuses.
Jul 21, 2014 | Dryers
How can I stop the intermitting beeping
I was told by repair man that it is in the circuit board and it woukld have to be replaced. It stopped when I turned it down to Medium. My clothes still get dry!
Jul 09, 2014 | GE DSXH47EGWW Electric Dryer
How to remove drum from a GE DSXH47eg1ww dryer
disassemble from the front, remove the belt & there you go & if your not sure get a service tech so you dont do more damage
Apr 10, 2014 | GE DSXH47EGWW Electric Dryer
Stops during cycle
some times the number of flashes and pauses will be an error code counting them could result in a solution also try turning off the breaker count to 5 turn on see if helps
Nov 25, 2013 | GE DSXH47EGWW Electric Dryer
Dsxh47eg0ww
I would replace parts. It still is cheaper than a new unit. So get the new control panel and do it yourself and save money. The average life of a dyer is dependant only on when the owner gives up. I just serviced on last week that was 25 years old.
Jul 08, 2013 | GE DSXH47EGWW Electric Dryer
I have a ge dsxh47egww that until reecently worked fine. Suddenly it would rapidly flash the signal, extra care and start button intermittently and not work. Now it doesn't do anything. what is
is there an error code displayed,then check tech spec sheet located inside unit? if no code,try measuring between pins 1 & 2 on plug J-4 if you have 120volts a.c. its the control board,if 0 volts are found then its the door switch
Apr 26, 2012 | GE DSXH47EGWW Electric Dryer
I have a GE Model DSXH47EGWW dryer that is 3 years old. It has recently started beeping when the dryer is off. Three lights come on and it beeps twice, and the lights stay on. I push the pause/cancel...
if that beeps on it's own and lights come on most likely when this happens it's the computer board,i've seen them start up just sitting there it will beep and then turn on.
Jan 07, 2018 | GE DSXH47EGWW Electric Dryer
How do you replace the bearings on a GE Spacemaker DSXH47EG1WW dryer. In addition to a bearing set, is anything else recommended for the repair?
I looked up your model and it is VERY similar to that of a Frigidaire model. Same rear bearing as a Frigidaire type. The front of the drum rides on felt. The controls are all quick connected with molex blocks so that is not an issue. I ran across a homemade video of the bearing being replaced by a homeowner who is by no means a tech just a guy who can git her done!
I have a manual and the other videos He does 3 and repair photos HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 06, 2011 | GE DSXH47EGWW Electric Dryer
I have a GE DSXH47EG0WW dryer and clothing is getting caught along the edge between 2 parts of the drum. This is causing fabric to tear. Any way to stop this from happening?
if its in the front of dryer you need the front brg and felt replace and the 4 slides . if in rear of drum replace rear barg and do the front . may also need a belt and idler . dryer sounds like if done a few loads .. hope this helps mm
Dec 03, 2009 | GE DSXH47EGWW Electric Dryer
Dryer makes a loud squeaky noise
probably a bad pulley or drum bearing
Aug 31, 2009 | GE DSXH47EGWW Electric Dryer
GE DSXH47EGWW Electric Dryer Logo
420 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
