Question about Estate Washing Machines
My estate washing machine will not spin out, all of the other cycles work correctly.
My washer will was the load but when it gets to the cycle to drain the water before the rinse cycle it stop .. moved the knob but will not do the spin cycle or drain water .. but filling up with water and the wash cycles work..
Posted on Aug 09, 2014
    Genius:
  • 1,400 Answers
Hello
Try to clean the magnetic door switch,some windex and a paper towell.Just do the part on the door or lid and where the lid meets the top of the magnet.Make sure this is not loose and is seated in the machine.
You may need to unplug machine and remove the door switch,take both wires and tie them togther so they make contact.Then try a wash cycle or try the spin cycle.
The door switches in the estate washers fall apart and get corroded and can stop the spin cycle.
If the machine works with the switch taken out then you will need to get a new one from whirlpool.
Posted on Mar 25, 2011
Fills with water correctly, will not go to next cycle
Hi ,, ok lets try some fault finding,,, try putting the washing machine on a no or low temp programme like wool,, or even the fill empty spin , see if it moves then,, if the programmer moves through then spins, i would assume the thermostat is broken,, if it moves through but does not spin , it may be the heating element,, if it does not move at all in any programme i would assume the programmer has a problem
Nov 14, 2013 | Whirlpool Washing Machines
Estate by Whirlpool washing machine Model:etw4400sq0 not spinning.
In my experience, a failed coupling is a likely cause
Dec 26, 2012 | Estate Washing Machines
Spin cycle is not working on my estate whirlpool washer
If all works except the spin cycle- replace the door safety switch
Feb 07, 2011 | Estate TAWS800JQ Top Load Washer
Whirlpool washer machine model TAWX700JQ1 will wash cycle and will not go to next cycle and will not drain the water
I had the same problem, I replaced the timer part no 3953146 and that solved the problem.
Jun 12, 2010 | Whirlpool Washing Machines
Spin cycle on wash not working well.
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 29, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washing machine spin problem!!!!!
whirlpool estate washer is dun the clothes are ring Wet
Jan 13, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washing machine making whining noise during spin only
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Apr 11, 2008 | Washing Machines
Estate by Whirlpool washing machine will not drain or go into spin mode in any cycle.
I would try and check voltage at the overload on the motor
when in spin cycle and see if you have power there..
 that should tell ya if your at least getting power from the timmer or not in the spin cycle to the motor
Sep 04, 2007 | Admiral AW22 Top Load Washer
Washing Machines Logo
197 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
