Question about Garden
I have a 22hp. twin (cylinder). I have a problem with starting it. There is too much compression for the starter to overcome on the first compression stroke. Is this a valve compression problem? Could it be the valve clearance is incorrect? My phone number is (423) 396-3326.
    Sergeant:
  • 259 Answers
First of all remove the valve covers and remove the sparkplugs. make sure all the valves are opening and closing when you crank the engine over. If they are set the valves to the specs in the manual for that engine. Put the cylinder on top dead center with both valves closed then set the intake and exhaust valves for that cylinder and do the same for the other cylinder.
Posted on Mar 25, 2011
How to remove the starter. On my v twin 22hp Brigg's and Station zero turn.
unhook the battery, take the nut off the side of the starter that holds the red battery wire, take the two bolts out that hold the starter on the engine.
Jul 17, 2017 | Garden
My intec 22hp. Briggs moter blowing compressed air out dip stick
they all do that to some degree . some vent back to the carburetor and some use that pressure to power the fuel pump .
May 14, 2016 | Garden
Only firing one cylinder, replaced both plugs and one coil? What else could be causing this?
Justin, Did you replace the right coil, are the leads good,
Are both the triggering magnets still in the fly wheel,are they clean? Touch any piece of metal to both of them and make sure they are equal strength or close to it. If one magnet weak replace.
Twin cylinder briggs and stratton not firing on 1 side
22hp twin Briggs running on one cylinder at idle MyTractorForum com The...
Lawn tractor 1 cylinder not firing General Discussion Forum In Depth...
Briggs 422707 Firing one cylinder
Feb 09, 2016 | Garden
22hp bs wont idle
always check spark and compression first spark needs to be blue and compression should be 120 but will barely run on 80psi if both are fine rebuild and acid dip carb
May 22, 2012 | Briggs & Stratton Briggs Stratton Intek V...
2004 John Deere 118 tractor, 22HP Intek engine. New battery, but still won't turn engine. I can manually turn it by the pulley but the starter just clicks....when it did work, the starter took a couple of...
It sounds like a starter problem. If the starter was used heavily -long runs or multiple times to start the engine- it could be shorted. Overheating is the enemy of the starters and happens when a starter is used hard to start a balky engine. Repalcing the starter isn't a big job and many B&S engines use the same starter. Find a working starter, replace yours with it and try to start the engine (with clean plug and full battery.)
It is also very possible that the compression relief valve is malfunctioning. It s mounted on the cam shaft and opens the exhaust valve to bleed compression from the cylinder(s) when starting. When it doesn't hold the valve open the starter can't throw the cylinder past top dead center TDC) to relieve compression. The work around is this: turning the pulley manually past TDC will allow a good starter and fully charged battery and clean plug to turn the engine and fire.
B&S has a high failure rate for the compression relief valve and states that the valve clearances are critical for the valve to function properly. And when the engine is worn and valve clearances are set right but it still malfunctions... the company has various reasons why YOU caused the problem.
Replacing the compression relief valve etc takes 3-5 hours and at $65+/hr you can see what the cost is- not including the relief valve which costs somewhere around a $100 (more for larger engines.) Even after replacement, it might not fix the problem.
Dec 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Running a Vanguard 23 Hp on my Mud Motor.\r\nQ1: developing a hard starting problem, seems like starting on 1 cylinder, after the first tank of fuel this fall. Fuel filter, spark, and plug OK. Looking at...
It sounds like your valves are out of adjustment. Your starter will bog down if it is out of adjustment and stop at the compression release.
So just take your valve covers off and set your valve lash to
.006 intake
.008 exhaust
Oct 04, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs and stratton miss fires on one cylinder.22hp intek
possibly a commpression test might throw a little more light on the situation ,that will eliminate alot of speculation, and make it easier
Oct 25, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
61 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
