Question about LG Washing Machines
Have l g tromm # wm2277HB drum stoped truning and code on front says L E
  • 5,370 Answers
Error code LE indicates that either the motor is not turning or has locked up for some reason. It can also be due to Hall sensor which monitors direction and speed of the motor. If the sensor is faulty then also this error appears. Motor lock can be caused by several things from a loose connector, to a bad motor. To make sure it's not a locked motor, try turning the drum with your hand. And, if there is any resistance while turning the drum or the drum doesn't move freely then the motor is locked and you'll need to get it replaced. If the motor seems to be fine then you would need to replace the Hall Sensor. To replace the hall sensor, take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. --------------- Unplug the unit from main outlet.Then drain the water from the machine.By disconnecting the drain pump ,There will be too much water so be care full.If you disconnect the drain pump from drain hose to drain the water it will flow on you,so keep towels ready to soak the water. Also clean the water filter. ----------------- In most of the case LE error is solved by just disconnecting the washing machine from main power outlet for 30 minutes.But if the problem is still the same then try cleaning the filter and draining the water from drain pump.This error occurs when motor stops functioning and water does not drain. --------------Also another cause of LE error is Regarding the LE ERROR CODE. This code is also caused by having a residue on the sensors in your unit. You have to use a HE liquid detergent.If you use fabric softener use half of the recommended amount and dilute if it is concentrated. Once a month (for a family of four) put 3 cups of white distilled vine-ager directly into the drum and select sanitary cycle or the hottest cycle you can. This prevents residue from forming in your unit and causing the LE ERROR CODE. ---------------- This should help.Thanks.Helpmech,.
Posted on Mar 25, 2011
  • sselbert May 21, 2011
    i just experienced the "LE" error code and thankfully was able to solve it without a service visit:) thought i should post on this site, as i had read this page looking for help, on how to go about fixing. i called the LG customer service number and the lady on the phone told me it could be because of soapy water. sounds silly, isnt that what a washer deals with all day? anyhow, the following easy steps solved the error code and now we are back in actiion. step 1: unplug washer. step 2: turn off water. step 3: drain water out of the machine through the hose. step 4: turn water and power back on. step 5: select rinse and spin cycle, do not add clothing or soap to this. you will notice that no "LE" error message comes on and the machine goes through the cycle as it should.
    et voila, you will have a working washer like i do now.
  • raj somaiya May 22, 2011
    Thank you sharing your experience.thanks.Helpmech.
Water enters drum overnight with machine off
that is your water valve in the washer need replaceing
Apr 06, 2013 | LG 4775er2002a Door Hinges for Wm2277hb...
Hello, I have a front load LG TROMM WM2277HB and yesterday it wouldn't spin anymoreand there was a noise coming from inside like 2 metal cylinders were rubbing on each other. I called SEARS Serv
if the machine fails to spin and makes noise there are thee things to check .if it fails to drain the water check if something is stuck on the drain pump no 2 turn the drum with your hand and check if the drum is moving freely if not something is stuck between the drum and the housing if the bearings are faulty the machine spins but makes alot of noise towards the end of the cycle i hope this will help you.
Jan 21, 2013 | LG 4775er2002a Door Hinges for Wm2277hb...
Annoying LG Tromm wm2277hw "LE error" won't go away.
Might be "tE" error code. Thermistor error. A $6 parts and pretty common and causes the symptoms you described.
Mar 02, 2017 | LG 4775er2002a Door Hinges for Wm2277hb...
LG TROMM WM2277HB Washer will not dispense Bleach from the Bleach compartment. Thank you.
Pull out the dispenser drawer far enough to be able to just see the tray with the bleach in it, select the (final?) rinse and check that water is entering the tray. If it isn't there is a fault with the water distribution and an engineer call is required ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 19, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have a lg tromm wm2277hb and it's not spinning. The le error code is coming on. I tried to unplug the unit and press and hold start button and then the power button for 5 seconds. Then tried the...
Hi
Error code LE indicates that either the motor is not turning or has locked up for some reason. It can also be due to Hall sensor which monitors direction and speed of the motor. If the sensor is faulty then also this error appears. Motor lock can be caused by several things from a loose connector, to a bad motor. To make sure it's not a locked motor, try turning the drum with your hand. And, if there is any resistance while turning the drum or the drum doesn't move freely then the motor is locked and you'll need to get it replaced. If the motor seems to be fine then you would need to replace the Hall Sensor. To replace the hall sensor, take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Hope this helps...
Daniel
Jun 17, 2011 | LG WM2277H Stainless Steel Front Load...
My washer is marking LE.What does that mean?
This is a motor overload. Could be too many items in the barrel. I have had this code in the past and took some items out and it went away. I still think there is an underlying issue with the hall sensor or the motor altogether.
Jun 23, 2009 | LG WM-2277HW Front Load Washer
Washing Machines Logo
181 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
