Question about Neff B7740N0GB Microwave Oven
How do you change the language on NEFF C67M70 microwave oven combi?
MicrowaveSvc
  • 9098 Answers
SOURCE: Power Problems on NEFF H7871 Combi Microwave
It would seem there is a bad connection in the fuse holder or in the wall socket or in the microwave itself. Maybe you can narrow it down to the microwave by trying other devices in the wall socket. If it's the microwave, it's time to call for serivce.
Posted on Dec 14, 2006
  • 184 Answers
SOURCE: Replacing lightbulb in Sharp R953M combi microwave oven
most microwave ovens built in the last 20 years do not have an
access panel to the light bulb. you must remove the screws on the back of the microwave that hold the outer sleeve in place.
Then pull upward and backward on the sleeve to disengage it
from the front lip of the chassis. the light bulb should be close to the front of the microwave behind the control panel. Some lights
are not unscrewable from the socket, but the socket and bulb
come as an assembly.
Posted on Mar 27, 2008
  • 228 Answers
SOURCE: I have a combi Neff Microwave/Oven and the
will need turntable motor cheap and easy to replace
Posted on Oct 28, 2009
SOURCE: Noisy Fan in Neff Combi Microwave/Oven. B6774.0gb
We had this problem - fixed today - its the chimney fan which extracts fumes and sends them to the cooling fan. Its an easy fix when you see the engineer replace the fan. Neff were excellent my warranty ran out 6 weeks ago and they replaced the part for free and all I paid was a call out charge. The rattling was caused by the blades coming loose from the fan
Posted on Dec 10, 2009
  • 17 Answers
SOURCE: replace light bulb on the Neff H7871 combined oven and microwave.
The bulb is positioned at the top of the oven, accessible only from the outside. You'll need to pull off the top and bottom trim strips, remove the bottom trim strip locators, remove 2 fixing screws from the left edge of the oven (with door open), and the 2 fixing screws from behind the top trim strip. The oven should then just slide out. You only need to pull it out 6 inches or so to gain access to the bulb cover. You'll need a T20 driver to remove the cover, then the bulb unscrews as it has an SES fitting. Bob
Posted on Dec 01, 2010
Neff c67m70
check the timer setting make sure its not on a set timer mode
I’m happy to help further over the phone at https://www.6ya.com/expert/jovani_c02b023fe087f6cd
Aug 15, 2014 | Microwave Ovens
Micro wave stops working after 30 secs
Replace the door interlockswitches - or try re-positioning the existing set. They wear after time
Jun 08, 2012 | Neff H5470 Microwave Oven
I have a neff combi microwave oven and it stops working after 20 seconds and doesn't heat the food
It is one of three things, the microwave oven, "heart of the system" inverter board, "if less than 7 years old" and the keypad control board. all parts mentioned are not cheap.
Apr 16, 2012 | Microwave Ovens
Neff microwave combination oven
no solution sorry but we also have a Neff mw/combi oven which keeps blowing for no apparent reason, the Neff repair man has looked at it 4 times and practically replaced every component -power module, operating module,relay board, door switches but it`s just gone again! The model is a H5972N0GB/01 and it is approx 3 yrs old, no problem for the first 2 years .Time to write to Neff -is yours the same model?
Apr 23, 2008 | Microwave Ovens
Neffcombination built in microwave and grill
The options for language selection will be detailed in the setup menu in the manual. German and English are similar enough to work out the steps to return it to English. A manual can usually be acquired from the manufacturers website, or from download sites. (Internet search your brand and model number).:::Spiceweasel.au.
Jan 28, 2008 | Neff H5642 Convection / Microwave Oven
yes you can fix it yourself it is a cooling fan in the top it is round metal fan quite small venting waste fumes from cavity when grilling etc need to remove top panel and 3 screws to remove it is a push in fit.
Jan 15, 2008 | Neff B7740N0GB Microwave Oven
Dec 11, 2006 | Neff H7871N2GB Convection / Microwave Oven
Neff B7740N0GB Microwave Oven Logo
177 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
