Question about Samsung Jet S8000 Cell Phone
My touch screen does not work all the time and when i press the right of the screen it press the left for example when i press menu it brings up the phone book what can i do
  • 255 Answers
There are a couple of things you might try. Do you use an adhesive screen protector? A screen protector which is trapped under the screen edge may interfere with touchscreen calibration. Occasionally, just having the screen protector on the screen can cause the issue. Try removing the screen protector.
You may have debris trapped under the edge of the screen. Use the corner of a piece of thin, stiff paper (copier paper works well) to very gently slide all around the edge of the screen. Don't let the corner of the paper travel more than an eighth of an inch under the screen edge frame. By doing this, you may be able to dislodge small particles of debris trapped under the frame.
Posted on Mar 25, 2011
Touch screen
After clearing the memory,or if the touch panel detection function is not working correctly,follow this procedure to calibrate the touch screen.Press the yellow reset key ,press 1993 and press red stop key 5 times to open the self diagnostics menu.On the touch screen press Touch Screen Adjust.Use a pointed tool to press the upper left mark.Press the lower right mark after it appears.Touch a few spots on the touch pannel to confirm that the marker appears exactly where the screen is touched.When you are finished press OK on the scree,touch Exit on the screen to close the self diagnostic menu and save the calibration settings.
Dec 30, 2013 | Ricoh Office Equipment & Supplies
Tip
Nokia 5800 Tips
5800 Tips and Tricks
1. To bring out the Shortcuts on your Screen/Desktop-> Settings/Personal/Home Screen/Home Screen Theme and select Shortcut bar, you can then select which shortcut to display if goto "Shortcuts". This will also bring out the "Track" playing being displayed when you open the Music Player.
2. Tap the Clock to bring out the Clock menu and make your alarm, alarm repeat is now built-in.
3. Tap the "General" or Date (the set Profile besides the clock) and the Profile selection menu pops out, almost similar to pressing the "Power" button in all S60, but here the Remove memory is not shown, but "Calendar" shortcut is included and the other profiles as well.
4. If you are on the Numeric Keypad, pressing the [#] key alternately will toggle the General and Silent Profiles, same as before, which means long press on zero [0] will bring out bookmarks for the Web.
5. Tapping on the displayed To do or Calendar entry will bring you immediately to that particular item.
6. Tapping the Active Icon on the Top Left (near the battery indicator) will give you shortcuts for any of the active icons.
7. Long press on the Green Call Button will still activate the Voice Command Prompt
8. Long press on the center button is similar to the Long press on the "Menu" key (the yin-yang key on most S60) which will bring out the menu for all the active applications.
9. Go to Applications/File Manager and setup "Backup" for automated backup schedule of your phone data.
10. How to update your Nokia 5800 firmware using your phone.
Presss *#0000# to display phone factory information and firmware
Now press options and select check for updates
The newest update is sent to your phone from nokia
Download and install updates.
This is done using GPRS or WIFI Connectivity.
General Tips
1. Use Dialer and press # for about 2 seconds will switch the profile between Silent and General; press and hold 0 will open the web browser; press and hold 1 will open the voice mailbox
2. There is a shortcut key for Music, Gallery, Share, Video, Web shortcut at the top right corner just below the front camera
3. Press and hold the Green caller button when standby mode will activate the voice command. You could call the name from the contact or application name.
4. Organize your sms by grouping them like outlook by Messaging -> Option -> Setting -> Text message -> Other -> Show messages in groups -> Yes
5. Notification light will blink if there is unread sms/missed call. It could be turned off at Settings -> Notification light -> Off
6. If the touch input is not accurate, you could calibrate your screen at Touch Input-> Touch Screen Calibration -> ( Tap around the 4 dots at the corner)
7. Turning control functions:
a. Rotate your screen horizontal or vertical
b. Silence your phone for incoming call by rotate your phone with screen facing down.
c. Snooze the alarm by rotating phone screen facing down
8. Theme effect will give 3D and transition effect if on but will slow down your tube considerably. Settings -> Personal -> Themes -> General -> Themes effects -> On/Off
9. Shortcut to exit application : Press and hold the middle white button then press and hold the program that you wish to quit, an open/exit option will pop out (useful for those haven’t install handy taskman yet)
10. When using handwriting input, slide from left to right is Spacebar, right to left is Backspace
11. Organize your menu by Menu -> option -> organize. You could drag and drop the location of the application you wish to relocate.
on May 12, 2010 | Cell Phones
Can i stop the alcatel one touch 665 from playing a tone when i open and close the clamshell
Goto Menu then Profiles you see a red dot on General. Press options on lower left of screen and Edit. scroll down to Flip Beep and click it then scroll to Silence and press Select on lower left of screen. It worked for me.
Nov 20, 2011 | Cell Phones
I do not know how to change the date on the camera. Con you help me
Press the Home button to bring up the main menu. Touch the Setup function area (pliers and screwdriver) to bring up the Setup menu. Touch the down-arrow function area until you see the "Date" option. Touch the calendar function area to enter the Date menu. Select "Set date" and press MENU/OK. Use left/right to select a digit and up/down to change it. Press MENU/OK when done.
See page 22 in the manual.
Mar 06, 2011 | Vivitar ViviCam 8025 Digital Camera
HOW DO YOU GET THE TIME & DATE ON A PHOTO
Press the HOME button to bring up the menu. Touch the Setup icon (pliers and screwdriver icon) to bring up the setup menu. Touch the down-arrow icon until the "Date" option appears, then touch the function area to bring up the date menu. Touch the left-arrow function area to select "On". Press the Menu/OK button to confirm.
Feb 12, 2011 | Vivitar ViviCam 8025 Digital Camera
How do you set the date? ViviCam 8025
Press the Home button to bring up the main menu. Touch the Setup function area to enter the setup menu. Touch the down-arrow until you see the "Date" option. Touch the calendar function area to enter the date menu. Touch the left-arrow function area to select On/Off/SetDate, then press Menu/OK to confirm.
Use left/right to select a digit, up/down to change it. Press Menu/OK to confirm and save.
Nov 04, 2010 | Vivitar ViviCam 8025 Digital Camera
How do i erase memory card
The memory card should be formatted each time you finish downloading your pictures from it. This will erase all files, including protected files. Unlike deleting each file individually, it will also clean up the directory and allocation tables, preventing potential problems.
Press the HOME button to bring up the main menu. Touch the Setup icon to bring up the Setup menu. Touch the down-arrow as necessary to get to Format, then touch the Format icon to bring up the Format menu. Touch the left-arrow to select OK, then press Menu/OK to confirm. When it asks if you want to format, use the arrows to select YES, then press Menu/OK.
Oct 22, 2010 | Vivitar ViviCam 8025 Digital Camera
My touch screen on my Designer 1 is off-kilter. You touch to the right to get the left box to work. For example, if I use the first stitch I touch the second stitch. The touch also does not work well...
You need to access the SET menu. Try pushing to the right of this in various spots and hopefully you will be able to get in to this menu. Then you need to keep hitting More until you get to "Colour touch screen adjust" . Select this (by trial and error - keep touching to the right of the square until it is selected). Now get your stylus and carefully press it directly in the centre of the crosshatches - first the one marked "1" - it should turn green - then the one marked "2" - it too will turn green. Your screen is now re-calibrated and you should be able to push the buttons and get the correct selection. If not, I think the machine should be seen by a technician. There may be problems either with the screen or the motherboard.
Oct 13, 2010 | Husqvarna Designer I
IPod Touch Automatically Reverts to Main Menu Screen
you need to restore your ipod touch by connecting it to your computer and clicking restore. make sure you have backed up your ipod touch before you do this or you will lose everything on your ipod touch.
Jun 16, 2009 | Apple iPod touch
I turn off the flash on my sony dsc - t77 , how to turn it on? i could not find the function!
That solution does not work on the T77.
I have the same problem and this is how I solved it.
Press the Menu button on the bottom left corner of the screen.
Go to the second page (2/3) select the "REC MODE" (it is the firrst choice)
Select your mode as normal and not burst and then exit the menu.
Now you should be able to activate the flash from the screen..
Hope it works for you as it did for me.
Dec 27, 2008 | Sony Cyber-shot DSC-T77 Digital Camera
Samsung Jet S8000  Cell Phone Logo
221 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
