Question about ASUS V9999/TD (128 MB) Graphic Card
Hello, my problem is, when the computer starts the graphic card work perfect, but when it comes to the deskopt, its going black with the text: signal not support, PLEASE HELP!
  • 81 Answers
Lower your resolution.
Posted on Mar 25, 2011
Dimension 3000 WinXP PC not starting...white screen.diagnostic lights are Y-G-Y-G
hello
check this link out
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_dimension_desktops/dimension-3000_owner%27s%20manual_en-us.pdf
On page 34 it states
A possible graphics card failure has
occurred.
• If the computer has a graphics card,
remove the card, reinstall it (see
page 56), and then restart the
computer.
• If the problem still exists, install a
graphics card that you know works and
restart the computer.
Graphics card is also called a Video card
Mar 14, 2013 | Dell Computers & Internet
Black Monitor, (NO SIGNAL FOUND)
Start your computer with monitor attached to the onboard graphics poart,
go to bios,
search for graphics setting and change it to PCIE.
Exit while saving changes connect your cable to graphics card port.
This will solve ur problem.
Nov 25, 2012 | MSI N210-MD1G/D3
No monitor signal on my m2n-vm dvi after installing my new graphics card asus en210.The graphics card was tested on my other pc and works fine..any help?
First boot the computer without connecting Graphic Card, then go to BIOS and find for VGA option change the option to compatible mood, save the setting and come out of it. now off the computer re connect your graphic card and start the computer.
Aug 15, 2012 | ASUS M2N-VM DVI - Motherboard - micro ATX...
I have a acer m 1620. when i power it up the screen comes on and say no signal and then goes black. the fan comes on and continues to run but thats it. does anyone have any ideas?
It sounds like the video cable is loose, try unplugging it and plugging it back in. Also check if the screws on the video cable are tightened. If this does not work the graphics card has likely failed.
Mar 05, 2011 | Computers & Internet
When I powered the desktop computer up this morning, my monitor powers on, but the LG logo comes on then the message Analog Power Saving Mode comes up and the power button starts flashing and I still have...
The problem is that there is no signal from the graphic / vga card from the PC, check the cable connection from monitor to the PC, or the PC itself got error on memory card or grapic card. Try to clean/ firm the graphic and memory card socket/ connection inside of your PC
Dec 10, 2010 | LG Computers & Internet
VGA connection works, DVI does not
Everything seems perfectly normal...
When you connect the computer to the monitor via an analog VGA cable, you get signal on the analog input.
When you connect them via a DVI cable, you feed the monitor's DIGITAL input, so the monitor doesn't get any signal on it's analog input, and informs you about it.
You have to select the digital input from the monitor's On Screen Menu, and then start the computer up - you should see the picture OK.
Also remember to set the display resolution on your computer to match the optimum (native) resolution of your monitor - this will give you optimum picture quality. In case of VA712B it will be 1280x1024.
Good luck and please come back with a testimonial if helped.
Jan 24, 2010 | XFX GeForce4 Mx440 (64 MB) Graphic Card
Very fine hotizontal black lines are appearing and the text starts to melt. The cursor doesn't work at that point. Finally it goes black and comes back by it self. I put in a new graphics card and it was...
Try a different monitor on the computer, then if needed try another video card, then if you still have the same problem then that means the motherboard is the problem.
Nov 28, 2009 | Computers & Internet
9400Gt won't work anymore
Hello tainted feat,
Please download DriverSweeper:
http://downloads.guru3d.com/Guru3D---Driver-Sweeper-(Setup)_d1655.html
Reboot into SafeMode and select the Nvidia drivers and PhysX. Select only those. Do not delete the chipset drivers. Reboot into normal mode and then go here to download drivers.
http://www.omegadrivers.net/nvidia.php
This should work. Good luck
Jul 07, 2009 | XFX GeForce 6800 GT, (256 MB) Graphic Card
Graphics Cards causes computer to not display
Hi there.
I'm working on the assumption that the graphics card is a PCI Express card.
Remember that if you are swapping from on-board graphics to a card you have to go into the BIOS and tell the machine that the primary graphics adapter is AGP/PCI Express.
Plug the VGA cable into the on-board graphics port, start the computer and enter the BIOS, tell the computer to use the AGP/PCI card as primary, press F10, save the changes and exit the bios.
The computer will try and restart so let it boot to post and turn it off, then put in your card and try to boot again.
Please post back if you need more help or advice.
Good luck and thanks for choosing FixYa!!
Jun 04, 2009 | Vantec iON 2 VAN-460N (VAN460N) 460-Watt...
Black screen no signal
replace the graphics card, ours was going black here and there the last few months then finally it didn't work at all, we just replaced it today and the new graphics card (ati) works fine.
Jun 07, 2008 | Evga e-GeForce 8600GT, GeForce 8600 GT,...
ASUS V9999/TD (128 MB) Graphic Card Logo
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
