C7280 printer will not duplex print
Get error message that duplex accessory is not plugged in. Works fine for manual duplexing. Have unplugged and restarted with no luck
This only happens using wireless.
plug in the usb port to the pc
let it install automatically
turn off pc, unplug printer
turn on pc, adj printer prefs for wireless
Posted on Sep 13, 2008
I have a 69.0 printer error on my HP5100dtn printer.
Hi Mary L,
Good day... This steps may be helpful for you. try sorting one by one steps...below
solution 1:
1.The duplexer side adjust has failed.
2. Turn the printer off and then on.
3. Reseat the duplexer assembly.
4. Replace the duplexer assembly.
solution 2:
1. The duplex printing unit is not functioning.
2. Turn the MFP off, and then turn the MFP on.
3.Reseat the duplexer.
4. Check the connection between the duplexer and the DC Controller.
5. Replace the duplexer.
solution 3:
1. Duplex mechanism failure.
2. Duplex slide adjust has failed.
3. Temporary error.
Hope this solve the problem...
Thanks in Advance.
Hp Error Code 69 Service Errors 69 Printer Repair Message
Sep 15, 2017 | Office Equipment & Supplies
Iam getting the duplex paper jam error 371 each time i try to print . how do imake the error go. i dont use the duplex at all.
See page 75 of the attached user manual on how to remove a duplex paper jam. If you can't find a paper jam in the duplexer, simply remove the duplex assembly (power off the printer, then power on) and see if that resolves your issue.
(The printer will operate just fine without the duplex assy. installed)
Okidata C9650 User Manual
Sep 12, 2012 | Oki Printing Solutions C9650 Led Printer
Hi...I have a problem with my HP Photosmart C7280...can you help ? the error message "Photo tray problem" keeps coming up, telling me to "lift the output tray, push the photo tray all the...
Photo tray problem
' Lift the output tray up and verify that the photo tray
' is pushed in until it stops, then lower output all the
' way down. Press OK button on the printer to
'continue printing
HP Photosmart C7280 All-in-One Printer
1. Turn off printer.
2. Pull out paper tray and photo tray
3. Remove output duplexer (on back of printer)
4. Open input sheet feeder (on top of printer)
5. Open cartridge access door. (Basically lift up control panel and scanner section of the printer)
6. Turn on printer (Power button on now raised control panel)
7. Printer may display message "Performing printer alignment - Do not interrupt"
8. Wait for a few minutes until printer stops making all setup noises.
9. Close cartridge access door, close input sheet feeder, replace output duplexer, insert paper trays
10. Do a test print. All should be fine.
Mar 11, 2011 | Office Equipment & Supplies
We can duplex copy but not duplex print on the KM Bizhub 250. When printing from the computer, in the Konica Document Properties Window on the Layout tab, when the Print Type pull down screen is activated...
See if you have selected weight paper from the tray in the duplex mode.
Weight paper is selected in duplex mode only from the bypass.
So you check that the paper in the tray 1 or tray 2 must be plain paper and in duplex mode it can print normally.
Jan 29, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
HP C7280 duplex scan problem
click on start and select control panel.
in control panel on the top left hand click on switch to classic view if is not there dont worry.
Next Goto printers and faxes and then right click the printer icon and select printing prefrences and in the advanced tab make sure that duplex printing is enabled.
IN vista
Click on start
in the start search box type "printers" and click on ok.
Single left click your printer and then single right click your printer icon and single left click the option that says printing prefrences.
in the advanced tab make sure that duplex printing is enabled.Now try to give the scan command and it will work as long as the paper is fed in from the adf it will be better
May 29, 2009 | HP Photosmart C7280 Laser Printer
Paper jam on hpc7280 printer noise from duplexer area NO PAPER JAM
Follow the instructions in this video. If you follow those instructions and still get the message, you may need to replace your printer or the rear door.
May 19, 2009 | HP Photosmart C7280 Printer
Cannot get printer (hp C7280) to print double sided
There is a new driver from april 2009 on HPs site which adresses this problem. I installed it, and now everything works fine. You have to download and install it yourself, it doesn´t update automatically.
Apr 26, 2009 | HP Photosmart C7280 Laser Printer
Not printing double sided
check the driver
does not print from bypass tray (manual feed)
does not print on thick paper (check paper type)
Apr 01, 2009 | Ricoh Aficio SP C410DN Laser Printer
Lanier ld145 duplex error
The duplex is on the right hand side of the copier (external unit from the main print engine). You firstly need to check for a jam inside the unit, open the unit away from the copier and there will be a blue tab to access further beyond the black plates. Also make sure the unit is seated correctly and plugged in (Turn off unplug and plug back in, this will also reboot the machine). This is customer recoverable error so the reboot should fix it
Dec 26, 2008 | Lanier Office Equipment & Supplies
Can aphotosmart c7280 all in ne do duplex printing
The printer’s built-in duplexer lets you print on both sides of a sheet of paper, but there’s no duplex scanning for two-sided documents. taken from Mac Life last sentance 4th paragraph Please rate my service thank you  PJ
Dec 02, 2008 | Office Equipment & Supplies
303 people viewed this question
