Question about IBM Office Equipment & Supplies
My IBM Selectric II will occasionally not print letters or parts of letters. Why does it do this?
  • 478 Answers
MAKE SURE THE ABCD LEVER (located on the top left of the machine) IS IN THE A POSITION
Posted on Jan 09, 2015
  • IBM Master
  • 8,404 Answers
Your Selectric II (a wonderful machine) is in need of cleaning and adjustment. When I did this, I got $65.00 for the service ... that was years ago. I don't know anyone who does this work any longer though a search on Google may get you results for a shop in your area. There may be a FixYa.com advertiser who can help you. Look at the ads around this answer (that is what pays the bills, after all).
Thanks for your question @ FixYa.com
Posted on Mar 25, 2011
How to unlock typewriter?
Remove cover and in the back there is the motor and belt, with machine off, try turning the belt. There is a tool that screws into the main cam shaft that allows you to turn the main cam shaft. most likely something is stuck. These IBM Selectric need oiling on a regular schedule.
Aug 15, 2017 | IBM Office Equipment & Supplies
My IBM Selectric II typewriter skips part of a letter when typing envelopes and going over the overlapped thickness. Even repeating the letter doesn't help.
That particular key is not hitting the paper flush as it should. Carefully try adjusting it in the direction of the miss.
Nov 08, 2015 | IBM Correcting Selectric II
My IBM Selectric II either does not type some letters or only partially types them. Sometimes the machine will type a letter and sometimes not. It happens no matter which ball is on the machine. What
First put in a mulyi part form, type on it if the carbon is ok you have have a ribbon problem. The ribbon may be very old or not properly installed or twisted.
DickyO
Sep 30, 2014 | IBM Correcting Selectric II
IBM Selectric II letter printed does not correspond to the letter typed
You could have a broken element (type ball). You could also have a broken or out of adjustment rotate or tilt tape. Those are the two wire bands that control the rotation and tilt of the element.
Dec 11, 2013 | IBM Office Equipment & Supplies
The alignment of a couple of letters (i.e., "m") on by IBM Selectric II is askew. How can this be fixed?
It may be as simple as replacing the element (ball). Remove it and look for broken ao badley worn teeth on the lower edge of the ball.
DickyO
Jul 31, 2013 | IBM Correcting Selectric II
My ibm selectric ii type impression is messy and sometimes missing part of the letters. I have check for proper ribbon placement and cleaned the ball element, but the impressions are still dirty looking. ...
Left Rear chrome lever with ABCDE or - marks should be towards the typist and the red ball next to the typing ballo should be moved to a higher number. Messy printing is caused by paper not being held tight against platen(black roller)
Jan 31, 2013 | IBM Correcting Selectric II
Ibm selectric II typewriter prints a different letter than the one typed. the typing ball appears to be very sluggish.
By this time in thier life selectrics have become very gummed up which causes many many problems, you need a chemical cleaning and lubrication. It may be cheaper to buy an IBM Wheelwriter on EBAY.
DickyO
Mar 07, 2010 | IBM Office Equipment & Supplies
IBM Selectric II Will type letters, but will
Several possible causes. Needs lubrication most commonly. Sometimes the velocity cable is hung up on the left side and under the carriage. remove the ribbon and shine a light down on the left side and look for a cable hung up on the pulley, make a hook with a paper clip and lift the cable up and past the pulley
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 31, 2009 | Office Equipment & Supplies
IBM selectric I...88 charter type balls
All the selectric I & II's take the same elements the sel III uses a 96 char. one that is printed in yellow that isn't compatable.
DickyO
Jul 06, 2008 | IBM Wheelwriter 30 Typewriter
Correcting IBM Selectric II Typewritter correcton ribbon won't engage
Selectric I and II type elements are identical (88 char) where Selectric III uses a different element (96 char). The 88 character element will have white lettering and the 96 character element will have yellow. Directly underneath the lift-up tab to remove the element will be a 3-digit number. That's the last 3 digits of the element's part number, which will be preceeded by 1167 for 88 character, or 1352 or 96 character. For example, if you have a '052" stamped on the element, and it's an 88 character style, the P/N will be 1167052.
The correcting mechanism is an intricate additional function of the backspace function. To test it/adjust it/or repair it requires the machine be hand-cycled using a hand cycle wheel which is screwed into the right hand side operational shaft. It's unlikely that an un-trained party would be successful repairing this..
May 15, 2008 | IBM Wheelwriter 30 Typewriter
177 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
