Question about Vanguard Heating & Cooling
Need new burners for VP10T - Vanguard Heating & Cooling
    Brigadier General:
  • 4,736 Answers
If you need the entire burner assembly, the DESA/Vanguard Part # is 099884-02.
If you need the Burner Tubing, too. The part # is 102491-01
You should be able to get the parts from Master Distributors http://www.vanguardheaters.com/
Hope this helps get you what you need. Please be kind enough to take a moment and rate my reply to you. Thanks and have a great day!
Posted on Mar 25, 2011
Baxter OV-210G burner cycling on / off @ 90 sec, repeating after new burner blower
You need to clean the flame sensor or replace the flame sensor.
Sep 30, 2017 | Heating & Cooling
Tubes blow flames out the front of burner
Burner out of postion , gas leak on control on off . or burner is blocked try cleaning burner some thing could be in the burner causing the gas tO light back , or you need new burner.
Mar 26, 2012 | Nexgrill 720-0234 (LP)
Jenn-Air Model 720-0061-LP. Burners will not
burner is blocked needs cleaning out remove burner and clean it or put it in clr , or buy new one
May 18, 2010 | Grilling
Whirlpool 465. The top range burners will not ignite. I can hear and smell the gas. The oven burner works fine. Do I need to replace an ignitor for the range?
The bake is seperate from the burner ignition system. You may need a new spark module for the top burners. All burners should spark at the same time even if you are only trying to lite one burner.
Aug 27, 2009 | Ovens
Crooked stovetop burners
This happens when purchasing pans/bowls from home depot ect..., there are so many different shapes and models you never get the right ones. Order new bowls online with your model number located behind oven door to get the correct size and the elements should be fine.
Phil
Apr 11, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
How do you chance the burners?
All you need to do is get the same length. Just remove the old ones by lifting them out after removing screws. Slide the new ones on the valves. NOTE: look at the air gaps on the air curtains on the old burners and try to match them to the new burners.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 01, 2009 | Kenmore 490 sq. in. Cooking Area Gas Grill...
PC will not recognise new DVD Burner
if the recognized it then the wizard will not appeared. u need to install application software for burner like nero, alcohol etc
Nov 27, 2008 | ASUS P4B533-VM Motherboard
Heating & Cooling Logo
59 people viewed this question
Top Vanguard Heating & Cooling Experts
Paul Carew
john h
Are you a Vanguard Heating and Cooling Expert? Answer questions, earn points and help others
