I have had my 2400 heater for seven years, not a problem until last week. The monitor shut down showing E 13 & E 14. The fuel was low in the barrel so I filled it and we called the repair man who told us how to reset the heater. The fuel came in but it would not light so we had lots of fumes..since then the repair man has tried three times to fix it, checked and clean everything and replaced a filter and the fuel pan, it worked for 24 hours after he left now it is off again showing E13 & E 14...what are your suggestions?
Monitor MPI it flashes F 13 or 14 & smells, I had it cleaned 6 months ago
The codes are "E" Codes. an E13 is no fuel. E-14 means flame rod malfunction. Unplug the heater then reconnect, this will reset the heater. Try your red prime button. Could also be the fuel pump or your fuel source feed line isn't flowing fuel.
Feb 17, 2016 | Heating & Cooling
E-14 code mpi monitor 2400
It sounds like you have a fuel problem, check to see if there is some kind of blockage in the line or at the tank value.
Jan 25, 2013 | Rinnai Toyostove Direct Vent Heater: Laser...
I have a mpi 2400 monitor. I ran low on fuel so I went and got 4 or 5 gallons to keep it going till my delivery came, but it keeps shutting of and getting an error E 14. I know this means there are...
usually when you run out of oil,you need to bleed off air. there's a bleeder on pump looks like bleeder on a car brake cylinder.atach a piece of rubber hose and run to a bottle, open it up when pump is running till all you get is oil.
Jan 25, 2011 | Heating & Cooling
WE HAD A POWER OUTAGE AND NOW MY MONITOR HEATER 2400 IT JUST HAS LINES GOING ACROSS IT WE CANT SET THE TEMPERATURE THEN WHEN IT FIRES UP IT LASTS LIKE 20 SECONDS THEN SHUTS DOWN, WHEN IT DOES THAT IT SHOWS...
Since you had a power outage, you possibly have a circuit board issue. Try unplugging the heater for a couple of minutes then plugging it back in. If that doesn't help then a new circuit board may be needed. There are 2 different circuit boards. One main circuit board and one for the display. I hate to inform you of this but this are both very expensive. The main board will cost somewhere around $400. I'm not sure of the cost of the display board. If you have someone replace them, have them do to one and see if it fixes it. If it doesn't, put the old one back and replace the other, that way you can narrow it down to 1 or the other. There is a place in Ashville, NC that will repair monitor circuit boards. http://www.mathiselectronics.com/product-services/Monitor-heater.html Go to this link and it will give you prices for the repairs. They guarantee their work for 3 years. If you contact them mention you heard about them from Niten's Heater Service. Sorry I can't be more helpful.
Dec 01, 2010 | Heating & Cooling
My monitor 2400 suddently goes into error 13, I shut the monitor off for a few minutes and then it starts again, it has gone into error for the paste 4 days about 2 tims per day can you give me some idea...
It could be a dirty fuel filter or the small strainer located inside of the heater that is restricting the fuel flow. The problem could also be with the flame rod being dirty or touching the burner ring.
Feb 21, 2010 | Heating & Cooling
We have a monitor 2400 kerosene heater, it will start up and after a few minutes at most it shuts down and starts beeping and many times has a message "error 13"
Next time you try to start the unit listen to the pump on the lower right side of the unit. Just before the E13 message if you hear a thumping noise, you have a fuel problem. If you don't hear a thumping and there is a flame you have a problem with the inside of the burner. I would say since it's a 2400 you have a fuel problem. Low fuel, no fuel, dirty filter or blocked flue pipe.
Tom Hawkins
hawkins111@gci.net
Jan 19, 2009 | Heating & Cooling
Monitor 41 20 years old rebuilt 3 years ago. out of fuel
Hope you got this fixed. Sounds like you were having fuel flow problem.
Jan 17, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
I have a Monitor 2400 oil heater. I would like a more detailed description of all the parts for this heater. Also I would like to find a listing of the possible error (e) codes that this heater may display...
I cleaned the fuel screen located on the unit and replaced the filter on the external fuel tank. The external filter can freeze if it accumulates enough water and the temp is cold enough, or it can just get full of debris. I also unplugged the 2400 for 30 min to let the factory preset settings come back. Filter(s) caused the e14 error, preset settings cured the e13 error caused by me fooling with the start stop function so much. Thanks for the help!
Dec 10, 2008 | Heating & Cooling
MPI kerosene Monitor Heater
need to bleed air out of filter at oil tank crack open the screw on top it will bleed out air wait until oil starts to run out then tighten back and bleed at heater on right side lever inside hole push and let off slow 4-5 times and restart
Nov 02, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Have a mpi monitor flashing a e13 code
I have a propane monitor heater just installed 2 months ago and I get an e 13 code and the heater won't stay on???
Oct 19, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Heating & Cooling Logo
161 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
