Question about Lexmark X2600 InkJet Printer
Need parralle cable driver download to connect printer or get to print do not have USB port
  • Lexmark Master
  • 4,350 Answers
If your system lacks USB, get a USB card and install that. Parallel is not the way to go.
Posted on Mar 25, 2011
Downloaded drivers for a new Samsung M2830DW and will not print. Computer does not recognize printer. Help???
Dear
Some times the front usb port arnot work. try to connect the /replace the usb cable to the usb port mounted on motherboard(back side panel of pc), It also may happen the usb port may disabled due to virus. Also you can unistall the driver during power OFF of the printer after uninstall successful power ON the printer, it will show NEW HARDWARE FOUND at the right right bottom of the pc screen ,If you OS is win 7 and connected to internet the driver automatically installed, otherwise you can load the driver cd and install the driver.
Also it can be checked at control panel-add hardware.
Thanks.
Feb 26, 2015 | Samsung Office Equipment & Supplies
I have a citizen prolaser 6000 laser printer, it emulates HP Laserjet 3, I want to connect it to my laptop via a usb interface cable, currently it is connected to the printer port of a desktop (lpt1 for...
There is three things that you will need:
Proper port set up on laptop device manager (Check settings) LPT1 is for a parallel port - Need USB Correct Driver for the Citizen 6000 Pro Laser (Windows should auto install) Hub that will communicate via USB to the IEEE 1284 Printer via cable.
Driver Site: http://www.driverfiles.net/Printers/Citizen/Prolaser-6000-Printer-Driver/download/page,sh,38839,389,12,.html
I hate to suggest, but you may have to call Microsoft Citizen Tech Support for suggestions on the Hub that will communicate via USB properly. Check your manual for setup options.
TF
Jun 02, 2011 | Office Equipment & Supplies
I would like to print off of my lap top HP paodion dv7-1451nr Where is the port for the USB cable ? Is there a program/Cd I need for this?
Printers do not have a standard USB port. Instead, they use a port that is a bit more square. The cable you'll need is USB one one side and Printer on the other wide. These are extremely easy to find at an electronics retailer and are commonly known as a printer cable.
Whether or not you'll need a program/CD depends on your computer. After you have the correct cable, you can try connecting the printer to your laptop and seeing if the driver already exists/works correctly. If no luck, you can use the Internet to go to Canon's website and download the correct driver for your printer. That should get things going with no Program/CD needed.
Mar 01, 2011 | Canon MP560 All-In-One InkJet Printer
Driver for windows 7
According to the Hewlett-Packard support website, DOWNLOAD the DeskJet 3600 Series driver for Windows 7. It is equal to the USB driver for the DeskJet 3325. At the present time, the Deskjet 3600 Driver is available thru WINDOWS UPDATE ONLY. Enable WINDOWS UPDATE on your Windows 7 PC and manually download this driver.
At this time, a full feature Windows 7 driver solution is not available for your product.However, a compatible print driver solution for your product is included with the Windows 7 operating system. There is no need to download any additional software. Follow the steps in this document to identify the print driver that is compatible with the product, install the driver, and then configure it in Windows 7. When this driver is installed, you can use the basic functions of the product.
Follow these steps to install the compatible driver in Windows 7.
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon (c01319360.gif), and then click Devices and Printers. The Devices and Printers window opens.
  3. Click Add a printer. The Add Printer window opens.
  4. Click Add a local printer.
  5. Click Use an existing port.
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port), and then click Next.
  7. Under Manufacturer in the Install the printer driver window, click HP.
  8. Under Printers, select the appropriate alternate driver for the product (listed in the table in the previous step), and then click Next.
  9. NOTE: If your HP product is available through Windows Update, click the Windows Update button to select additional print drivers. You must connect to the Internet before using Windows Update.
  10. In the Printer name text box, type the product name and then click Next. The print driver starts the installation process.
  11. NOTE: The name of the alternate driver displays in the window as the default name. If you prefer, you can change the name of your product. This step is optional.When the installation is complete, a message displays on the computer stating that the product was added successfully.
  12. In the message window, click Finished.
  13. Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  14. Click Close (c01900743.gif) to close the window.
Follow these steps to configure the installed driver.
  1. In the Devices and Printers window, right-click the name of the product and then click Printer Properties. The Printer Properties window opens.
  2. Click the Ports tab.
  3. Click the drop down menu, and then change the port from LPT1 to USB or DOT4.
  4. NOTE: If there is more than one USB/DOT4 port available, select the USB/DOT4 port with the highest port number. To see the full port name, widen the ports row in the Properties dialog box by placing the cursor over the vertical line between Port and Description, and then click and hold the mouse button. Move the mouse to the right until the port name is visible.
  5. Click OK.
Jun 07, 2010 | HP DeskJet 3325 InkJet Printer
Epson 9500 using usb to parallel interface
1.Reinstall driver for your operating system.
2.So been relationship from-zi long cord USB - change on short.
3.Chek installing the driver that he was local and not network.
4 Versions of the driver 32 or 64? tire your.
5 Open port USB in panels of management printer -a CHARACTERISTIC-PORTS- note port USB
Sep 28, 2009 | Epson Stylus Pro 9500 InkJet Printer
Printer won't print test page after downloading driver for x4270
-disconnect from computer
-perform printer self-test (refer to printer documentation)
-change usb cable
-try another usb port
Sep 16, 2009 | Lexmark X4270 All-In-One InkJet Printer
Printer is connected but does not print
Hi
Thanks for using FixYa. Please check the following things first---
· The printer cover is closed and the rear access door or optional duplexer is attached.
· The printer is connected to the power source and turned on.
· The cable connections are secure and the cartridges are correctly installed.
· The paper or other media is correctly loaded in the in tray.
Now check the printer cable connection: If the printer cable is attached to a USB hub, a printing conflict might exist. Use one of the following methods to resolve the conflict:
· Attach the printer USB cable directly to your computer.
· When printing, do not use other USB devices that are attached to the hub.
Now verify if the printer is connected to the correct USB port: If the computer is configured to use both the back and front USB ports on the printer, then you might be printing to the wrong port. The computer has two versions of the printer driver: one for the front USB port and one for the back USB port. If you are connected to the back USB port, but select the printer driver that is associated with the front USB port, the printer will not print. In the application that you are printing from, click File and then click Print. The Print dialog box opens. The Print dialog box displays two versions of the printer driver. Select the version that is associated with the port to which you are printing. The issue will be resolved.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 12, 2009 | HP DeskJet 6540 InkJet Printer
Failed to print using Intermec Easycoder pc4 label printer
If you have another USB port asidefrom the oneyou are using now try to transfer your printer cable. Make sure your USB port is firmly connected to the motherboard. Follow the USB connectors and check if these are well fitted and not loose.Apply pressureon the endsto set the connectors.
May 12, 2008 | Intermec EasyCoder PC4 Label Printer
Can't print using USB connection
Unplug printer and un install software. Delete printer in printers folder. Restart pc. Install software first and then connect printer. Also make sure your usb drivers is correct.
Sep 29, 2007 | Samsung ML 1210 Laser Printer
Lexmark X2600 InkJet Printer Logo
24 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
