Question about Fossil Speedway watch #TI5066 Watch for Men
How do I change batteries on a fossil speedway watch
VOTIT
  • 2071 Answers
SOURCE: how to remove the back
First you need to determine if the watch is a snap back type or a screw back. If the watch back has a series of equally spaced slots (usually about 6) around it's perimeter, then it is a screw back and you will need a special tool in most cases. You can sometimes remove a screw back using a pair of snipe nose pliers in two of the slots, but unless the watch can be mounted safely in a small vice then this is quite difficult. The back from snap back watches can be removed with a blunt pen knife. If you look carefully around the edge of the watch casing you should see a small indent in the cover. This is where you start with the blunt pen knife, working your way around the edge twisting the knife gently as you go. Eventually the back will snap out of the watch casing
Just click below for more information;
http://www.pmwf.com/Watches/WatchSchool/WS%2011%20How%20to%20remove%20and%20replace%20a%20watch%20movement/WS%2011%20How%20to%20remove%20and%20replace%20a%20movt.htm
a youtube video guide sample on how to;
http://www.youtube.com/watch?v=ZMLZNclIcME&feature=related
Hope this may help you;
Regards,
VOTIT
DON’T FORGET TO RATE;
Posted on Sep 15, 2008
indays
  • 111 Answers
SOURCE: i have a fossil blue
to change the battery of fossil blue watch,just open the case back and remove the old battery,look the number size on the battery and put a new battery that same number size ,after replacing battery press the case back tight to avoid water damage !good luck
Posted on Aug 25, 2008
SOURCE: Time change Fossil JR 9120
i already found one link with all Fossil manuals.
Thank´s for your support.
Posted on Feb 09, 2010
SOURCE: how to change the battery
when changing a battery in a swiss legend how do i get chronograph hands to reset to correct position
Posted on Mar 25, 2010
  • 906 Answers
SOURCE: Fossil watch battery
Link
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi SDMIKED
I suggest you consult your authorized Fossil Dealers for the correct battery replacement of your watch.
Thank you.
Posted on Jul 28, 2010
What battery does the fossil ch2599 watch take
You are going to have to remove the battery to find out which one you need. For instructions on how to do this see: http://www.mademan.com/mm/fossil-watch-battery-replacement-guide.html. You can buy the battery at: http://shop.batterymart.com/search#w=fossil%20ch2599%20watch%20battery. Replacing a Fossil battery is delicate and tricky. Fossil recommends that you send it to a shop that specializes in Fossil watch battery replacements.
Feb 25, 2015 | Fossil Watches
What is the battery number for a fossil am3848
We can tell you the battery number you may need for your Fossil Watch, but it is not worth you to change it yourself.
Many people think that replacing a battery to a watch is an easy task, but that is far from truth.
Note that once a watch is opened ( if you can get it without leaving marks all around the case) all circuits are extremely delicate. If you may touch some part with any metal instrument or even with your fingers, you will loose your watch.
Best you can do is take it to be replaced to a watch shop, sure you have one near you.
But let me insist, if you need the battery number, let us know and we will provide.
TicTacArea.com is Fossil authorized dealer, you can find our complete Fossil watches and Straps for Fossil watches here:
Apr 04, 2014 | Fossil AM3848 Watch for Men
What battery does the fossil fs 3105 watch take
It's actually a lot easier than that video shows. You're trying to represent a watch that is a PDA! To change the battery in your watch, you need to purchase a watch kit on eBay for about $15-$25, purchase the correct battery, watch a realistic video of changing a battery on Youtube, and then you will never need to pay more than the cost of a battery (a few dollars) to change your watch battery ever again! Sending it to Fossil takes time and money and you can do it at home with basic skills!
Jan 16, 2011 | Fossil FS3105 Wrist Watch
I have a big tic watch but after a battery change the digital number display on watch face no longer works,why?
Who changed the battery, you or a watch repair serviceman? Did you replace the battery bar after you replaced battery? Did you check and see if there was a second battery (some watches have two)
You may need to have it serviced. Or try Fossil at :
http://www.fossil.com/en_US/shop/customer_care/static/fossil-Instructions.html
Aug 23, 2010 | Watches
Fossil watch dead
Get battery out again. Clean (scrape) all the battery related contacts using steel needle or small screwdriver. Make sure the battery is not underpowered. Refit the battery keeping the right polarity and set the watch.
Don't forget to rate, please.
Jan 26, 2009 | Fossil AM 3688 Wrist Watch
Changing the battery for my Fossil Watch
You have to have a tool to unscrew the back of the watch. I figured this out the hard way. I suggest taking it to a jewler for after I replaced my battery, the stinking thing still did not work. This sounds like a commom problem as I read more about them. Hope this helped.
Nov 22, 2008 | Fossil AU4003 Wristwatch
I have a fossil blue watch. How do i change the battery? thanks
Aug 23, 2008 | Fossil Watches
I have a fossil blue watch that isnt working. i have tried to change the battery and that does not seem to help.
take it to a jewlrey store, like sergios. They know how to fix all watches. I took my fossil blue to 4 watch stores including the fossil store in the mall and none of the stores could fix it. I took it to sergios they changed 2 batterys in like 5 minutes with no charge.
May 03, 2008 | Fossil Watches
Link
Thank you.
Nov 11, 2007 | Fossil AU4003 Wristwatch
Fossil watch
I have a Fossil Kaleido that i havent used in some time. I just replaced the batteries in it and the only thing that works is it goes from solid red to hearts..it wont keep time. I only have 2 buttons on the side..one to change the time and one to set to either red or switch back and forth/// PLEASE HELP!! i love this watch
Mar 15, 2007 | Fossil University of Oklahoma LI2282 Sport...
Fossil Speedway watch #TI5066 Watch for Men Logo
187 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Lyle Siemens
Lyle Siemens
Are you a Fossil Watch Expert? Answer questions, earn points and help others
