Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Where is dryer element - Frigidaire FEX831CS Top Load Stacked Washer/Dryer
    Sergeant:
    Champion:
  • 202 Answers
Its at the back wall of the dryer .... you need to take the drum out if the dryer.. then you 'll see it
Posted on Mar 25, 2011
Ge dblr333etoww dryer
If your dryer isn't heating up, it's probably down to either the heating element or the thermostats. Most dryers have two thermostats and these correspond to the two temperatures that you can set your dryer to, typically "Low" and "High" on most dryers. The other cause of a cold dryer is a faulty element.
Because the element and the thermostats are closely linked, and it can be very difficult to troubleshoot if either the 'stats or the element is the cause of the problem. Therefore we recommend that you replace both the 'stats and the element at the same time.
Jan 21, 2014 | Dryers
How do i change the element on a samsung dryer
Hello.
When the dryer just isn't getting your clothes dry anymore, the culprit is usually the heating element. The dryer part may look intimidating, but you can replace the heating element.
Step by step instructions
TOOLS NEEDED New heating element,Screwdriver, Needle-nose pliers.
1 Unplug the dryer from the wall before starting. Find the dryer heating element cabinet. For most dryers this is located in the back, however it can be in the front. Find the compartment on the dryer.
2 Remove the screws or clips to get into the compartment to expose the heating element and wires. Use a needlenose pliers to carefully remove the element wires.
3 Detach the can shaped object that may cover the heating element. Tip the can backward to slip it off the hooks holding it in place. Some models place the heating element with the can, while others provide easier access to it.
4 Unscrew the screws holding the element in place and pull it out.
5 Put the new element in place, and replace the screws to secure it in the dryer. Put the can back in place and connect the element wires before putting on the cabinet cover.
6 Run the dryer on fluff with no heat, and go outside to make sure enough air is getting through the vent system.
7 Break the new heating element in by running your dryer on high heat for 10 minutes without any clothes in the dryer. This cleans oily residue off the element and keep the clothes from getting smoky.
Thanks.
Sep 26, 2011 | Dryers
Replace heating element for Duet Dryer GEW9200LW1
First disconnect the power to the dryer by unplugging it from the wall. Then remove the 3 screws on the lower panel of the dryer. This should expose the heating element in a metal housing on the right side of the dryer. Disconnect the 2 wires going to the heating element and slide it out of the housing. The heating element part number is 3387747.
May 25, 2010 | Whirlpool GEW9200L Electric Dryer
Kenmore Dryer, heating element doesnt turn off
remove the back of dryer and remove the heating element from the heater box,check to see if the wires in the box are touching the heater box walls any where,this would make the element stay on all the time,also check the high temp thermostat on the left side bottom,this is the on off thermo for the heating element-mike
Feb 16, 2010 | Kenmore 63942 Dryer
My dryer does not heat. Fuse, thermostats, heat element all have continuity, power chord is good, 240v at plugin... stumped. It is a model # LER4634BQ1 Whirlpool SN# ME4471484
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Feb 06, 2010 | Whirlpool LER4634J Electric Dryer
Heating element is out.
Instructions Things You'll Need:
  1. Step 1 Unplug the dryer from the wall before starting. Find the dryer heating element cabinet. For most dryers this is located in the back, however it can be in the front. Find the compartment on the dryer.
  2. Step 2 Remove the screws or clips to get into the compartment to expose the heating element and wires. Use a needlenose pliers to carefully remove the element wires.
  3. Step 3 Detach the can shaped object that may cover the heating element. Tip the can backward to slip it off the hooks holding it in place. Some models place the heating element with the can, while others provide easier access to it.
  4. Step 4 Unscrew the screws holding the element in place and pull it out.
  5. Step 5 Put the new element in place, and replace the screws to secure it in the dryer. Put the can back in place and connect the element wires before putting on the cabinet cover.
  6. Step 6 Run the dryer on fluff with no heat, and go outside to make sure enough air is getting through the vent system.
  7. Step 7 Break the new heating element in by running your dryer on high heat for 10 minutes without any clothes in the dryer. This cleans oily residue off the element and keep the clothes from getting smoky.
Dec 01, 2009 | Kenmore 62602 Electric Dryer
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Dryer heating element(s) are inconsistent
there is only 1 element. were you taking these readings with the wires on them?
the other 2 were thermostats.was there lots of lint?
sounds like you may have bad thermostat.
Nov 23, 2008 | Whirlpool GEQ9800P Electric Dryer
My GE electric dryer's heating element will stay on when the dryer shuts itself off after running through a cycle. Even if the dryer is in the "off" position, the dryer will become hot to the...
It sounds as if your heating element may have broken in one area and fallen against the element shround and grounded itself out. This will cause the element to bypass the safety circuitry and continue to heat, but at a lower wattage. You were very diligent in unplugging the dryer.
You will have to replace the heating element. Do not attempt to repair the element as this will only cause a hot spot and will burn in two again.
May 28, 2008 | Dryers
Frigidaire GLer642As3
A grounded element on an electric dryer is an element that has broken and the element heating wire has touched something metal, like the cage that is suppose to hold the element or the element metal housing around the element. What this does is, the element only heats on the section that is touching the metal part and usually this part of the element is only heating at about 1/2 heat output. An grounded element can also stay on even when the dryer is not in use!!
May 12, 2008 | Frigidaire GLER642A Electric Dryer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
21 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
