Question about Car Audio & Video
Wiring dia for 4 dual voice coils subs to 1 ohm 4000 watt amp
  • 3 Answers
What are each of the coils impedance at? Are they all the same sub, normally I would assume they were.
Posted on Mar 26, 2011
Wiring a crossfire vr602 at 4ohm
OK what you are saying now is that your speakers are dual voice coil; models? 4 Ohms per Coil? I have always used single 4 Ohm Voice ciol speakers since amps are mostly based on 4 Ohm outputs. but you can get 8 Ohm dual voice coil subs also. With 8 Ohms per coil you can get 4 Ohms if you parallel the wires. What is best for you and will get you the most stable power and still will be in the specs of that amp is to run the amp in BRIDGED MODE running each subs voice coils in series with each other then run those 2 subs in parallel to the amplifier giving it a 4 Ohm load. So, your will have two sets of wires from your amp 1 for each speaker. Then you will take a short piece of wire that will connect the + to the - of each voice coil then hook up the wires from your amp to each sub What it will be is 4 Ohms + 4 Ohms = 8 Ohms per speaker the 8 Ohms in parallel each speaker to the Bridged amp output using just the + from one channel and the - from the other will give you a total of 4 ohms and power out put of 600 Watts so that ends up being 150 watts per voice coil or 300 watts each speaker
Apr 04, 2013 | Crossfire VR602 Car Audio Amplifier
I have two different sets of hook ups on my Power Aucoustik 10" Sub. Do I hook up both sides?
Depending on the PA FUBAR you have. The voice coil on those subs are DVC. Dual Voice Coil. You need to know a couple things. What kind of amp are you going to run on it. And what is the resistance (OHM) rating of each voice coil. MY two 12's are dual 4 ohm. Meaning that there are essentially 4 speakers to hook up. My amp currently is not 2 ohm stable in bridged. So what I did is run each speaker in parallel (red2red,black2black) then run to the box terminal. So now the dual 4 ohm voice coils are basically 2 ohm. I have 2 speakers. Now I hook the box up in series. To bring the now two 2 ohm speakers into one 4 ohm speaker. This is called series/parallel setup. My amp sees this box as 1 channel @ 4ohms. The downfall to this is the output of the amp is divided up into each speaker. So instead of sending all 1400 watts to one sub. I will send 700 to each sub. But here is a catch. even though each speaker is half the total wattage it will still be 3db louder. Meaning it will be as loud as 1 sub running 1400 watts. To conclude i need to know how many of those subs you are going to run on the amp.. And the model number of the amp so I can match up your wiring.
Jun 06, 2011 | Power Acoustik FUBAR-12W Car Subwoofer
How do you wire a AW1000V to 1 amplifier?
The easiest way to wire this would be to make sure you have a 2 ohm amp, wire both voice coils in parallel to the amp. This means to connect both + terminals on the speaker to the + speaker output on the amp, then wire both - terminals on the speaker to the - speaker terminal on the amp. With the voice coils in parallel like this it makes it into a 2 ohm load at the amplifier. If you are running for example a 1000 watt amp at 2 ohms into this speaker it would give each voice coil the equivalent of 500 watts of power at 4 ohms. The other way would be to run the voice coils in series (voice coil 1 - terminal to - speaker terminal on the amp, voice coil 1 + terminal to the voice coil 2- terminal, voice coil 2 + terminal to the +speaker terminal on the amp.) The series wiring would give you a 8ohm speaker load to your amp so you would need a 8 ohm amp.
Mar 07, 2011 | AudioBahn AW1000V 10" Dual 4-ohm Voice...
To get the most power what is the best way to connect paraelle or
run them straight and dont use the cross over. One speak on right channel and the other on other channel. Then turn up amp settings 7/8 the way up and control the rest from your dvd/cd player. I recommend some monster cable which is very thick. Ground the amp directly to trunk bolts but make sure to scrape the paint off or the connection will be bad. You can also use a cap which will send battery pulses to amp much quicker.
Nov 19, 2009 | Lanzar VIBE286 Car Audio Amplifier
Why does the kenwood kac-9103d has two sets of terminals if its a one channel amp so how do i hook up a dual 12 phoniex gold 1200 watt sub to it
Hello damasogrizzl,
The 2 sets of terminals are connected internally. Having 2 sets just makes it more convenient when wiring multiple subs. The amp is rated for 900 watts RMS into a 2 ohm load. The specs claim that it is stable at 1 ohm but does not give a power rating.
The Radial SD competition series from Phoenix Gold are rated to handle up to 600 watts RMS. If you have the model RSdC124 with dual 4 ohm voice coils, it would be best to wire the voice coils in parallel for a 2 ohm load and connect the sub to one set of terminals on the amp. If your sub is the model RSdC122 with dual 2 ohm voice coils, you should wire the voice coils is series for a 4 ohm load and connect the sug to one set of terminals on the amp. Wiring the voice coils in parallel will result in a 1 ohm load. And, while the amp may be stable at 1 ohm, the sub will be seriously overpowered.
Hope this helps.
Sep 23, 2009 | Kenwood KAC-9103D Car Audio Amplifier
I have 2 positives and 2 negatives on back of my alphasonik sub, do i connect amp to one side or both sides?
Hello gaz69,
Your PSW815 has 2 ohm dual voice coils allowing you to better match the impedance to your amp. Each voice coil is 2 ohms. If you wire them in parallel (both +'s together and both -'s together and then to the amp terminals), the sub presents a 1 ohm load which is too low for most amps. Wiring the voice coils in series (one + to the other - and the remaining + and - to the amp terminals) results in a 4 ohm load.
This link shows the wiring diagram for both options. If you know for sure that your amp is 1 ohm stable, use Wiring Option #1. If the amp is not 1 ohm stable, use Wiring Option #2.
Hope this helps.
Aug 09, 2009 | Alphasonik PSW815 Car Subwoofer
Wiring a sub with duel voice coil
In short yes. And is very common even has its own term called bridged. Taking two channels and making them one. I would hope that you are running a cap. that's going to put out a lot of power and stress on your battery
Feb 10, 2009 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
How should I wire my 3 subs to the 500/1 amp???????
First of all how many ohm's are each subwoofer rated at . Are the subwoofers dual voice coil or single voice coil. Once I know that I can help you. I think the JL amp is not recommended below a 2ohm load.
Mar 16, 2008 | Jl Audio 500/1 Car Audio Amplifier
Dual voice coil wiring to class d amp
The easiest way to think of wiring voice coils and subs is this:
  • Two items of the same impedance in parallel = Half of the impedance
    • 4 ohms in parallel with 4 ohms = 2 ohms
    • 8 ohms in parallel with 8 ohms = 4 ohms
  • Two items of the same impedance in series = Double the impedance
    • 4 ohms in series with 4 ohms = 8 ohms
    • 8 ohms in series with 8 ohms = 16 ohms
In this case, you want to wire two subs, each with dual 4 ohms voice coils, so that the total equals 2 ohms. Your options are:
  • DVCs in parallel, 2 subs in series = 4 ohms
  • DVCs in series, 2 subs in parallel = 4 ohms
  • DVCs in parallel, 1 sub = 2 ohms
With two, dual 4 ohm subs, you can only have 1 ohm or 4 ohm total impedance.
Mar 16, 2008 | Car Audio & Video
Unsureness of wiring configurations.
Mamola,
Get an amp with at least 200 Watts RMS. The RMS value is what is important about driving Subs. This could be proclaimed to be a 1000 Watt amp. REad the RMS value.
Wiring. It is better to series your Speakers to give them and your amp more reliability,
Get a Mono or Bridgeable amp. If it si bridgeable, BRidge the output as described in the manual you get. Some Amps have a diagram right on the output..
AMP+ to Sub1 +
Sub1 - to Sub2 +
Sub2 - to Amp -
Get a 4 Guage wring kit. Run your power wiring down the Drivers side, and Audio signal wiring down the Passenger side, keep the two separate.
Nov 26, 2007 | Kenwood 12" 4-Ohm Single-Voice-Coil...
Car Audio & Video Logo
26 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
