Question about Heath Zenith 270 Degree Replacement Motion Sensor - White, SL-5716-WH
I want it to turn on only at night in the moring i dont want it on
Phone wont work
It all depends on the type of phone you have. If you have a flagship smartphone, then I recommend that you search for it in different smartphone forums. I could help you a bit more if you were to write in detail more info about your phone. Like phone model, does it turn on or just do nothing, have you try to turn it on while in the charger, all those little things help us help you.
Mar 24, 2015 | Cell Phones
Blinking night light
Night mode limits the maximum output of the subwoofer for later night listening or to be more considerate of close neighbors. Press the night button to turn the night mode feature on or off. Night
mode, when active, is indicated by the flashing blue power LED.
May 16, 2010 | Velodyne DPS-12 Subwoofer
My 26' sanyo vizon wont turn on and i dont know why.
I have the same tv. Was watching last night when it turned itself off. When I tried turning it back on the switch just made a click noise and nothing happened. After a couple more tries, it didn't even do that.
Jan 26, 2010 | Sanyo DP26746 26 in. LCD Television
My amp wont turn on
I have heard this problem occurs often with the vypyr I have heard to try and turn it oun without your guitar cable plugged in and it should work fine. If not try wiggling the guitar cable out a little and and should turn on and try and get the update for it.
May 06, 2009 | Audio Players & Recorders
Bad fuel in my 2005 suzuki drz 400
if you can get the oil problem and let the gas evaporate, then Berrymans B12 fuel additive should take care of the gum in the carb, double the dose run til hot turn off let sit overnight then try it next morning. if you was burning oil then it has to be the oil ring maybe reving it full trhottle and it running too lean overheated it. i would put more oil in and try it and see what happens. lets face it i dont think it can make anything worse.. dont know what country you are in for the berrymans, but you can get it in the USA
Apr 04, 2009 | 2003 Suzuki DR-Z 400
Got my sidekick 2008 wet & now screen wont work
Hello xxlucygoosie,
First off you did the right thing, however you need to leave it for more than just a night, more like 48 hours at least,add a good amount of rice.
Replacing the screen likely would not work as you probably have damaged more than just the screen(the main board) when you tried to turn it on if there was any water in it then you shorted it out.
You will have to replace the phone if you can not dry it out more and it works on some miracle.
Sorry for your misfortune, and thank you for trying Fixya!
Apr 01, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Fuel starvation?
no I tried what you said but stiil the same dont want to pay any more! you asked for more info well it has cut out when changing down but starts again strait after.
Dec 12, 2008 | 2006 Suzuki Grand Vitara
Turning on and off LG KS360
yea do wat i did and throw it at a wall then it cant keep turning its self of lol
Nov 19, 2008 | Lands Phones
Night photo's without the camera shake
Dont use night mode because shutter takes more time to capture.I advice u to use AUTO mode during taking pictures alltime.
Sep 10, 2007 | Sony Cyber-Shot DSC-S500 Digital Camera
Heath Zenith 270 Degree Replacement Motion Sensor - White, SL-5716-WH Logo
115 people viewed this question
Top Heath Zenith Home Security Experts
Mike
Domenico Grillo
Are you a Heath Zenith Home Security Expert? Answer questions, earn points and help others
