Question about Cameras
Estou com uma maquina kyocera km 2810 e ela esta dando erro CF 248,oque que pode ser ??
  • 196 Answers
SOURCE: lens error 15
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera. The following photo illustrates unseated guide pins that would cause a lens error
Posted on Nov 04, 2008
mishrajk21
  • 202 Answers
SOURCE: Não Consigo acessar Serviço de
helo
Try the following:
Switch the Power OFF from the back of the Printer and disconnect the
Power cord. Check the Primer Tubes. Reconnect the power cord and
power On the Printer.
Perform the Service Station diagnostic test to troubleshoot the problem
further
If the System Error continues, replace the Service Station .
If the System Error continues, replace the PrintMech PCA
Posted on Jul 30, 2010
ozztech
  • 285 Answers
SOURCE: Estou com uma S600 quando
ajusta o sensor que esta em baixo da printhead, carrega no ultimo botao ate a luz do calibrar acenda e enter. Atravez do driver e possivel ajustar a printer, confirma imprimindo a label de configuracao e ve se esta de acordo com o tipo de etiquetas, na pior das hipoteses, faz o reset to factory defult.
Posted on Nov 12, 2010
ZJLimited
  • 17970 Answers
SOURCE: Minha cam digital Kodak aparece com código de
O problema ? que a lente se tornou presa no cano. Existem algumas solu??es DIY, voc? pode tentar, mas a probabilidade ? que voc? ter? de obt?-lo fixo por um profissional. Use estas por conta e risco, pois pode prejudicar ainda mais a c?mera:
Em primeiro lugar, tente conectar o adaptador de corrente alternada ou cabo USB.
Tente segurar o bot?o do obturador quando ligar a c?mera.
Olhe para a lente, e se alguns dos "c?rculos" a lente est? desalinhada ou n?o conc?ntrica e tente mexer-lo (mantendo lente da c?mera para baixo).
Tente gentilmente empurrando ou puxando a lente quando ela se estende, mas isso ? arriscado, pois pode causar a lente para escapar de seu sistema de orienta??o.
Outra maneira de fazer isso ? colocar a lente da c?mera sobre uma superf?cie dura e, em seguida, poder-se. Tenha certeza de usar um pano macio ou algo similar para n?o arranhar sua lente ou inv?lucro. Vamos empurrar a lente da c?mera para cima e para baixo algumas vezes e ?s vezes a resist?ncia do pequeno fornecida pela c?mera ? suficiente para fazer as coisas andarem novamente.
Tente acertar a c?mera perto da lente no corpo com o tecido mole na palma da sua m?o.
Fora isso, eu tomaria a c?mara a um centro de repara??o de uma avalia??o para ver se ele custaria mais do que a repara??o para substituir a c?mera.
Visite aqui: LENSS ERROR
Boa suerte.
Posted on Dec 31, 2010
santosj27
  • 263 Answers
SOURCE: tenho uma ricoh 171 esta
You have a main motor overload. This can be caused by a defect in the photoconductor unit. Try putting an old photoconductor unit. If you still can not run the engine is broken
Posted on Jan 18, 2011
E8 error message midea ceiling cassette
MEU CASSETE MIDEA DE 36000BTUS ESTA DANDO U CODICO DE ERRO NO DISPLEY QUE E8 O QUE PODE SER?
Jun 07, 2013 | Heating & Cooling
Quando ligo a maquina dsm715 ela informa logo o codigo sc322. como faco para resolver?
Independente do modelo ser Dsm715 ou Dsm745 esse codigo corresponde a um erro na Unidade de Laser, mais precisamente com o sincronismo.
A primeira coisa a verificar nestes casos é se a Unidade de Laser está suja. Por vezes cai toner para o Laser e provoca estes codigos.
Se tiveres conhecimento tecnico saberás chegar á unidade de Laser. Se não tens esse conhecimento aconcelho a não mexeres (chama alguem que o saiba fazer).
Na minha opinião este deve ser o primeiro passo a dar. Deves fazer uma limpeza na Unidade de Laser.
Se não resultar replica para mim ou volta a colocar a questão no Fixya. Existem otros factores que podem provocar este codigo.
Fica bem!
Apr 25, 2011 | Gestetner DSm745 Black and White Copier
Estou com uma S600 quando mando imprimir 10 etiquetas ela imprime 6 etiquetas e trava acende os leds paper /ribom, pause e cancel. O que eu faço para resolvers este problema?
Nov 09, 2010 | Zebra Z4Mplus Label Printer
Não Consigo acessar Serviço de hp plotter Calibração T610. apresentou o Código de 21.1:03 Erro, Substitui uma Estação de Serviço e continuou o Mesmo Erro, Substitui...
helo
Try the following:
further
Jul 29, 2010 | HP Designjet T610 InkJet Printer
Hp designjet 8000s 1290 error
ESSE ERRO DE SISTEMA 1290 ACONTECE QUANDO O TEMPO DE TROCA DE ALGUMAS PEçAS ESTá PERTO, GERALMENTE é A TROCA DO KIT DE LIMPEZA.
QUANDO ACONTECER ISSO BASTA FAZER O SEGUINTE:
- DESLIGUE A IMPRESSORA;
- PRESSIONE DE UMA Só VEZ O SHIFT+CANCEL E DEPOIS LIGUE;
- SETA PRA ESQUERDA+SETA PRA DIREITA+SHIFT+OK;
- Vá ATé O íTEM COUT DEPOIS OK
- OK.
- DESLIGUE.
- AO LIGAR ELA VOLTA A FUNCIONAR.
Apr 05, 2010 | HP DesignJet 9000 InkJet Printer
The no close
sometimes there can be something stucked inside the levers and gears...even small objects can do so...becuz everything inside is very sensitive...or it's having an internal circuit problem
Aug 14, 2008 | Sony Handycam CCD-TR517 Camcorder
Error Code H4 for Sharp AL-1642CS
`the fuser is not the drum it the heating assembly from where the copy finally comes out of the machine . the buttons you must press in sequence are these: # , interrupt, C, interrupt then enter the no. 14 , then presss the green start button.
all these buttons are on the machine keyboard nothing to do with the computer.
May 06, 2008 | Sharp AL-1642CS Copier
Cameras Logo
1,018 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
