Question about Frigidaire Washing Machines
Need new water pump impeller--mine tried to eat some coins--\r\n131723500------plaset--62105 120 vac---85 w. cl. f 12-98
  • repairman473 Mar 26, 2011
    Good Morning and thanks for using fixya. May I please have your model number. S/B behind the door on the frame. Thank You
2 Suggested Answers
rickead1
  • 1998 Answers
SOURCE: serial no. 009KW00236 pump -
need the make the model number and what the problem is with the machine? I await your reply Thanks again
Rick
Posted on Dec 13, 2010
CLOTHES ARE STILL WET AFTER SPIN CYLCE
It possible something is jamming pump impellor, like a coin or hair pin, or pump itself is seized, or impeller is broken or loose.
Remove front panel, there are two clips in between front panel and top that you have to push in with metal putty blade or thin slot screw driver while pulling front panel away on either then pull up from bottom clips. Shop vac water from machine clamp off hose going from tub to pump.
Lean machine back if poosible so remaining water goes to back of tub, remove hoses, remove wiring to pump.
Unscrew pump from base observe inside ports for objects or broken or seized impeller on shaft if there things in pump remove them reatach wires put machine to drain or cancel and see if pump impellor turns freely, if so reassemble and try, otherwise buy new pump. Not very expensive.
Hope helped.
Jun 24, 2011 | Washing Machines
Will not drain and stops but does not give an error code.
Check any pump filter and outlet hose for blockages, if all is ok check pump.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way
Mar 06, 2011 | Maytag Neptune Washer
Will not pump water out of tub
Do you hear the pump running? If not unplug the unit and remove the panel to access the pump. Try to remove as much water as you can from the tub. Remove the hose clamps and the pump. You can disassemble the pump and see if the impeller is stuck from a foreign object like a coin. If the impeller moves freely then you need to check to see if the pump has voltage during the drain cycle. If it does you can replace the pump for about $50.00.
Feb 18, 2011 | Maytag Neptune MAH5500B Front Load Washer
Coad F21 keeps flashing
you have to clean out the pump.unplug the washer,open the door and with a shop vac vac out the water from the tub.next remove the bottom panel and you'll see the pump,in the middle of the pump you can remove the middle piece,have the shop vac ready,turn the middle piece counter clockwise slowly until water starts coming out,vac it up until it drains out,then remove the middle piece of the pump,most likely you'll find coins and a bunch of other gross stuff,also it could be stinky,clean out the coin catch and then stick your finger in the pump and feel around,make sure nothing is stuck where the impellar is,also check the rubber hose behind the pump,sometimes things get stuck in there,i stick the vac in the pump and vac out anything that's in there. put the piece back in the pump,plug in the washer,next dump some water into the washer with a container like a half gallon or so,put the washer on drain and see if it drains,if it doesn't drain turn the middle piece of the pump and drain out the water and check to see if anything is stuck in the impeelar of the pump,if it's clear the pump is bad but most of the time the pumps hold out.let me know how you make out and one more thing the number one killer of front loaders is to much detergent,if you use the cap off the bottle you should be using 1/4 a cup that's it,it's h.e. detergent and it's double the strenth of regular detergent.it eats at the rear bearing and spider gear,when it breaks the machine makes a loud banging sound in the spin cycle and it's time for a new washer,the part alone is 500 dollars so cut back on the detergent
Jan 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer did not drain the water and now the screen shows ---- ? How do I reset it to drain the water? Thanks, Erin Davis
if it's not draining you could have a plugged pump.usually there will be an error code like f21 or something.first you can try to unplug the washer for 15 to 20 minutes to reset the computer board.if it still doesn't drain then you have to clean out the pump.unplug the washer,open the door and with a shop vac vac out the water from the tub.next remove the bottom panel and you'll see the pump,in the middle of the pump you can remove the middle piece,have the shop vac ready,turn the middle piece counter clockwise slowly until water starts coming out,vac it up until it drains out,then remove the middle piece of the pump,most likely you'll find coins and a bunch of other gross stuff,also it could be stinky,clean out the coin catch and then stick your finger in the pump and feel around,make sure nothing is stuck where the impellar is,also check the rubber hose behind the pump,sometimes things get stuck in there,i stick the vac in the pump and vac out anything that's in there. put the piece back in the pump,plug in the washer,next dump some water into the washer with a container like a half gallon or so,put the washer on drain and see if it drains,if it doesn't drain turn the middle piece of the pump and drain out the water and check to see if anything is stuck in the impeelar of the pump,if it's clear the pump is bad but most of the time the pumps hold out.let me know how you make out and one more thing the number one killer of front loaders is to much detergent,if you use the cap off the bottle you should be using 1/4 a cup that's it,it's h.e. detergent and it's double the strenth of regular detergent.it eats at the rear bearing and spider gear,when it breaks the machine makes a loud banging sound in the spin cycle and it's time for a new washer,the part alone is 500 dollars so cut back on the detergent
Jan 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
12500 gal pool began by adding 8 \ 40# bags of
Drain this pool, give it a good cleaning and start over. Clean the electrolytic cell. Your 24" x 52" size pool holds 12,481 gallons of water and requires 310 pounds of salt at initial startup. You should set the timer to run 11 hours per day. If the low salt light comes on add 85 pounds. You need an owner's manual. You can download one here. http://pr-rp.pmra-arla.gc.ca/PR_SOL/pr_web.ve1?p_ukid=5143
Jun 01, 2010 | Intex Automatic Salt Water System for ...
Won't drain. Won't spin.
Sounds like there's a blockage in the drain hose, or the pump. There could be a coin jamming the pump impeller. If the clothes are wet it's got to be a drainage problem...Good luck....Nomess
Apr 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Neptune purchased brand new in 2007. Tumbler won't spin and water doesn't get pumped out, all I head is a humming noise coming from the water pump. I opened the back and could feel the water pump...
There is something jamming the impellers in the pump (coin, nail, bobby pin, ect.) You need to manually get the water out, remove the pump, and see if you can find and remove the obstruction. If you find something in the pump and remove it, check the impellers before you put the pump back in. There are 3 plastic impellers, make sure none of them broke off. If they did not break off, your good to go. If one or more broke off, you will need to replace the pump, you cannot buy just the impellers. good luck.
Oct 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Front load washer not draining
If the water is not draining the firt thing to check is the pump. take the 2 screws off the front bottom panel and remove it. get a bunch of towels or a wet dry vac ready. the pump should be on the right attatched to the drain hose and the coin/debris cather(a black rubber bladder. Remove the drain hose (use pliers on the clamp and pull the hose off. A lot of water will come out as well. Remove the rubber bladder(coin catcher) clamp with a philips head screw driver and pull it off the pump.Un plug the pump remove the monting screws. Check the pump and the bladder for debris. Look in the pump and make sure the impeller is not damaged. spin the impeller and make sure it moves. if the impeller is damaged then the pump need to be replaced. Assuming everything seems ok reassemble and run an empty load with the dial set just before final spin. If the pump is working you should hear it, and possible feel water moving through the discharge hose.
Mar 25, 2008 | Kenmore 44102 Front Load Washer
Washing Machines Logo
205 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
