Question about Amperite Dayton Solid State Timer On Delay Time Relay
How to wire a 12 volt DC1EJE8 Dayton Delay Timer
  • beacton Mar 28, 2011
    I need to know how to wire a 1EJE8 Dayton Multi Function Timer DC Volts
  • 43,501 Answers
A1 and A2 are the line terminals or the power to operate the timer...
Terminal 15 is the common or where you hook the line you want to switch...
terminal 16 is the normally closed out terminal
and terminal 18 is the normally open out terminal...
The power ro run the timer can be anything from 12 - 240 Volts A/C or D/C
Contacts are rated for 1/2 HP @120v or 1 HP @240v
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=1EJE8&op=search&Ntt=1EJE8&N=0&sst=subset
heatman101
Posted on Mar 28, 2011
  • 10,319 Answers
Here is the basic hook up at the link below
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html
Posted on Mar 26, 2011
Can you use a photo eye or motion sensor to act as a push button
Yes. You only have to identify the C,NO and NC wires on the motion detector and connect them to the timer.
Jun 05, 2014 | Dayton Audio Dayton 6a857 Solid State...
We have a 1EGD1 dayton timer delay relay what is the wiring diagram
Open following link to identify timer:
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=1EGD1&op=search&Ntt=1EGD1&N=0&sst=subset
This is typical 8 pin delay timer relay.
The wiring diagram appears on side of the timer.
Open following link for example how to wire 8-pin timer.
http://waterheatertimer.org/images/Connect-relay-to-timer.jpg
Example shows 24Volt, but 120Volt wires exactly the same.
The timer is 120Volts. So connect power to terminals 2 and 7.
Other terminals are dry, and receive no power when 120V is connected to 2 and 7.
In the example wiring, the objective is to have power connected to Load at all times except when timer activates. So power is connected to terminal 1 and Load wire is connected to terminal 6.
If the objective was to have power connected to Load only when timer turns ON, then connect power to terminal 1 and connect Load wire to terminal 3.
Read how to wire timer:
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html#pin
Oct 07, 2011 | Amperite Dayton Solid State Timer On Delay...
I am wanting to energize a relay for 3 min. then off, whether the power stay's on to coil or not! what I want to do is when a door rises and hits a switch I want to energize a coil for 3 min. whether...
You want 3 minute 'off delay' timer.
When timer is energized with push button or momentary electrical signal, circuit remains ON for set amount of time, and then turns OFF.
Aug 15, 2011 Dayton/ Grainger website is offline
Most delay timers have 1 amp capacity rating, so circuit needs fast acting 1 amp fuse, and timer controls separate relay or contactor unless Load is equal to 100 watt light bulb.
3-minute off delay pin timer
Omron shows 120Volt 8-pin M-series-(minute) 3 minute delay timer
Part number H3CR-H8L 120volt M
http://waterheatertimer.org/pdf/Omron-timers.pdf
Example 240Volt timer showing timer and base.
http://www.sourcingmap.com/ah33-220v-030-minutes-delay-timer-relay-socket-p-119441.html
Wiring diagram shows on side of timer.
Aug 15, 2011 | Amperite Dayton Solid State Timer On Delay...
To palaboy: when you talk about a switch on the left most terminals, you mean with this switch im enable the timer???
Question is not clear.
You posted about Dayton on-delay timer?
This timer has two contacts, and wires similar to a light switch.
Connect 120V power to terminal 1
Connect wire going to load to terminal 3
Maximum Load is 1 amp so this timer should be wire to a contactor/relay and not directly to Load.
If you have Dayton off-delay timer, open following link for wiring diagram, and to see examples of contactors:
If you have a different timer, then add a comment with clear description of timer or in-focus photo of timer posted on Flickr
Jul 11, 2011 | Amperite Dayton Solid State Timer On Delay...
I am looking for a multi function relay similar to the Dayton (1)6A855 but with a 240vac input not 120vac input. Can you assist please. Regards Bruce Peters
1) Dayton 6A855 time delay pin timer
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=dayton+6A855&op=search&Ntt=dayton+6A855&N=0&sst=subset
Grainger owns Dayton, so you might want to contact Grainger
http://www.grainger.com/Grainger/static/help_contactus.html
1-888-361-8649
2) Time delay timers at Grainger:
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=dayton+timer&op=search&Ntt=dayton+timer&N=0&sst=subset
3) Grainger shows time-delay 8-pin 120 or 240V
http://www.grainger.com/Grainger/DAYTON-Relay-1EJN7?Pid=search
Grainger shows 11-pin 120 or 240V
http://www.grainger.com/Grainger/DAYTON-Relay-1EJN6?Pid=search
Searching for "11 pin 240Volt delay timer" turned up results:
4) Following pdf shows knob-adjustable 240V delay-on pin timer
https://www.relayspec.com/specs/020050/T1Series.pdf
5) Signaline has delay timers (800) 862-2875
6) SSAC
http://www.ssac.com/standard/ff-tdr1.htm
7) Another pdf with 240V delay pin timers
http://www.askco.com/pdfs/tdd_tud_data.pdf
8) Not wanting to say what already know, but each 240V circuit is made from two out-of-phase 120V lines. Any 240Volt Load can be turned OFF by turning off one of the 120V lines. In this way, the Dayton 120V timer can be used to control 240V load.
Also the 120V Dayton can operate 120V double-pole contactor, and then the contactor controls 240V Load.
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html#contactor
Apr 04, 2011 | Amperite Dayton Solid State Timer On Delay...
On terminals 6 & 7 do you need to apply a power source? is terminal 2 the hot from breaker and #3 the neutral terminal?
Following page has Dayton timer wiring:
Terminals 6 and 7 are wired with 120Volt power as shown.
The push button gives momentary impulse of electricity to timer.
Timer activates when impulse of electricity ends.
Timer activation turns Load ON and begins countdown.
When countdown expires, timer turns Load OFF.
Terminal 2 is 125V Hot from breaker.
Terminal 3 is Neutral.
Terminal 1 goes to Load.
Load cannot exceed 1 amp.
So Dayton timer can only control single 100 watt light bulb, or it can control 120Volt coil on contactor.
Contactor turns on Load with any voltage: 120, 240, 277, etc or 3 phase contactor.
Suggest busman in-line 1 amp fuse between terminal 1 and Load to protect timer.
Jan 05, 2011 | Dayton Audio Dayton 6a857 Solid State...
Wiring a dayton timer relay
Open following link for illustrations showing how to wire 8 and 11 pin off-delay timers:
Jun 01, 2009 | Amperite Dayton Solid State Timer On Delay...
Amperite Dayton Solid State Timer On Delay  Time Relay Logo
414 people viewed this question
Top Amperite Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you an Amperite Hardware and Accessory Expert? Answer questions, earn points and help others
