Question about Rotary Hammering
Were do i get my eletric jack hammer repaired
    Scholar:
  • 54 Answers
These are not too hard to repair. I fixed a big HILTI TE 74 SDS type one by going to a German website and buying parts. There is a carbon composite connecting rod that breaks right up the middle due to all the shock loads. The oil in there really gets gritty and black too so it should be changed about every week when possible. Everything comes out the barrel end if you have long internal clip remover pliers and a big vice to use. The hard part is getting the ball bearing out which is squeezed into the aluminum barrel about five inches back. Search for conrod and your model of hammer.
Posted on Mar 26, 2011
Freeing up wheels on front and rear of 1955 210 post
hey Mike,
If the wheels will not rotate, its time for their removal..pull of the dust cover, remove the cotter pin,remove the axle nut, then pull the tire/wheel off...if its rusted on, you may have to use a DEAD BLOW hammer to the edge of the rim .. a metal hammer WILL damage the rims..USE JACK STANDS TO HOLD THE VEHICLE UP - DO NOT TRUST A HYDRAULIC JACK WITH YOUR LIFE!
.. remove each tire/wheel and replace the wheel bearings and seals, then check the brake shoe quality and operation... repair as needed..
Sep 10, 2017 | Cars & Trucks
Do you have to grease or oil anything on the bosch jack hammer
Grease bosch order nr 1 615 430 001 225 ml for 1 service OR 1 615 430 007 1000 ml for bulk repair.
Mar 16, 2013 | Bosch Brute Breaker Hammer 11304
Hammer not Jacking
Mine stopped and I took it apart and found a badly worn piston gasket. I can't however find a new gasket. Anyone know where to get parts for the sky687 hammer drill then let me know. Copipeworks@gmail.com
Sep 18, 2012 | Heavy Duty 1240w Electric Demolition Jack...
Dewalt breaker 25980 drawings
DeWALT D25980 Type 1 Breaker Hammer parts list and prices here:
http://www.ereplacementparts.com/dewalt-d25980-type-breaker-hammer-parts-c-1009_2700_3998.html
More information about the hammer can be found at dewalt for parts lists and manual here:
http://servicenet.dewalt.com/
Good luck with your repair.
Sep 24, 2011 | Dewalt D25980 15a Pavement Breaker Jack...
So does the hr200 work as a miny jack hammer or just a driil, can i buy a diffrent bit for that type of model to jack hammer up a little concrete
This is an older, discontinued model Makita that only works as a hammer drill. It does not have the dial selector the newer models have to switch from 'drill' to 'hammer drill' to just 'hammer'. If you need, there's a parts breakdown and user manual available at:
http://www.makitatools.com/en-us/Modules/Tools/ToolSupport.aspx?ID=352
Dec 23, 2010 | Makita HR2010 13/16 Rotary Hammer, SDS,...
I can't find motor brushes for the jack hammer. Any idea where to look?
You should be able to go to an electric motor repair shop and they can order them for you.Also check tool repair shops in your area.
Oct 19, 2010 | Electric Neiko 02845 Breaker Demolition...
Repair broke upper shock bolts on the rear shocks
Jack the car up bye the body and jack up the axle and tap the bolt out if not air hammer.
Heat the bolt with butane tourch.
Jan 15, 2010 | 1999 Jeep Cherokee
No hammer
i have 900 kango jack hammer motor work but don't jack in sacramento any repair dose work on the jack hammer can you give info who work in sac thanks jim
Jul 01, 2009 | Dewalt D25330K 2KG Sds Plus Demolition...
Replacing fuel pump
it is in the tank it has to be jacked on level ground front and back try to get as much gas out of it as you can remove the negtive battery terminal remove gas cap wait 15 to 30 mins to make sure pressure is relieved you will need things to do this rez style 2 hydraulic 2 x 6 board some blocks rags safety glasses 3/8 drive socketput safty set metric / standard you never know these days put your safety glasses on now and remove filler neck hose from tank .locate strap that hold the tank up follow strap to where it bolt to the frame loosen all bolts 3/4 of the way down get 2x6 and jacks . one jack at front of tank other at the other end jack up all the way to top place board jacks use blocks to make up differe nce betwen board and tank now you need a gomer. gomer will hold the tank in place while you take the gas lines loose then the eletrical connection remove the bolts gomer at one end you at the other slowly let down at the same time tell jacks bottem out remove jack and boards and place tank on ground i beleve the filter is down there to it should be replaced as well to get to pump there is a big ring on the outside of pump that must turn counter clock wise there are ears on the ring use a piece of wood and big hammer to hit counter clock wise remove ring and pump put in ring back on make sure it is tight reverse order tank on board board on jacks connect eletric then hook up gas lines up to top with jacks gomer lifts one side you put blocks then to the other side for the same strapbolt it 1/2 way all the around should be home free from there bolt up to the topreplace gas cap reconnect batt and test good luck later
Apr 01, 2009 | 1992 GMC Jimmy
Hammering Logo
229 people viewed this question
Top Rotary Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Rotary Hammering Expert? Answer questions, earn points and help others
