Question about Bosch WFO2862 Front Load
Bosch washing machine spins but not dry enough when spun as if it is on 800 not 1400
  • 24 Answers
This seems to be a common problem for Bosch WF02862. If the end result is not dry enough for you, you can try running an extra spin cycle. You can also try checking the machine if you can tweak its spin speed. Modern washers such as this model tend to have different spin levels.
Source: http://www.washingmachineadvisor.com
Posted on Mar 30, 2011
My Whirlpool spins... It just does not do a very good job
It's very possible that the impeller in the drain pump is striping out and not allowing the pump to get up to high enough spin to completely drain.
Jan 16, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
How can we use our Bosch Classixx 6 to spin dry only?
The spin cycle is usually to the opposite side of the OFF position. Pls watch this video. It should has the same control panel as yours. BOSCH Classixx 6 washing machine review for Appliances Online
Feb 14, 2013 | Washing Machines
It makes a squelling sound b-4 ging into the spin cycle. The clothes are not spun out very wet. This is the same without adding soap. I thought that was the problem so I rewash the clothes and the...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 05, 2011 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
The clothes have to be spun 2/3 times to get them dry enough for the dryer.
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 20, 2010 | GE WBSR3140DW Top Load Washer
Does not spin dry after rinse cycle; it drains, but the clothes are not spun dry
heatman101
Aug 18, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Not drying clothes still getting warm and turning but despite leaving it for hours the clothes never become dry just warm and damp
sounds like your clothes are not spun dry enough try spinning on maximum speed alternatively check your water pump is not partially blocked maybe you need to clean filter let me know how you went
Nov 12, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Towels did not get water spun out
drain hose kinked or belt slipping and not lettng the tub spin fast enough .
Aug 12, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Nexxt 800 series - washer doesn't always spin dry enough
First inspect the water pump then the pressure switch. Soap buildup can cause this too.
Jan 27, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Excel 1200 wahsing machine, when trying to activate spin, it shows the normal 10 minutes, but then goes straight from 8 mins to 1 min and items arent properly spun
bosch exxel 1200 washng machine
has error message 04 and wont drain or spin
what does this mean?
can you help?
have lost instruction book
Mar 27, 2008 | Washing Machines
Washing machine spin cycle
if a second spin dries the clothes as it should then i would be looking for blockages in the pipes that either go to the pump from the drum, or go from the pump to the outlet connector on the wall or sink, hope i have been of some help, if so please rate me, thank you
Oct 06, 2007 | Kenmore 22622 Top Load Washer
Bosch WFO2862 Front Load Logo
180 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
