Question about Toshiba Computers & Internet
I charge my laptop, but it will not turn on. - Toshiba Computers & Internet
  • 255 Answers
The most common cause for the laptop not starting up is the lack of power supply,but you have that in your case,so there could be a problem in your motherboard.So you should get it checked by an engineer for the fault.
Posted on Mar 25, 2011
How to Save my Laptop Battery?
Charge battery fully (with laptop off) then unplug AC power. Do not continuously have power plugged in. This will ruin your battery. Remove battery when not in use for long periods. To refresh battery charge fully then run laptop till it turns off. Turn on again and wait for it to turn off. When laptop wont turn on, charge battery fully again and repeat process about 3 times. This should extend an old battery's run time.
Oct 18, 2016 | Computers & Internet
I have a new LB1 battery for my 2006 15 in.macbook pro it will not charge the test button on the battery shows it is full charge but will not turn on laptop or charge
The laptop is the problem and not the battery, check the battery contacts for corrosion or consult a specialist on how to fix your laptop.
Dec 10, 2014 | Computers & Internet
Laptop turns off and wont charge battery
Does it turn on while it's plugged in?
3 most common things that go wrong with laptop charging.
1- bad battery - replace
2- bad charger - replace
3- bad charging port - replace
Feb 26, 2014 | Samsung NP355E5C-A01US Laptop
Batter wont stay charge
Most laptop batteries have a life expectancy of two years or 400 to 450 charge and discharge cycles. After this time, the battery may lose the ability to charge or to hold a charge for substantial periods of time. When this happens, it's likely the battery needs replacement. However, troubleshooting can narrow the problem and ensure you are not wasting money on a battery replacement.
Check Power Adapter Turn the laptop off. Remove any power cords or power sources. Separate the battery from the bottom of the laptop. Slide or press the locking mechanism to unlock the battery. Slide the battery out of the battery compartment. Plug the power adapter into an electrical outlet. Insert the opposite end of the adapter into the charging outlet on the side of a laptop. Power on the laptop. If the laptop does not turn on, the power adapter is not correctly working. If the power adapter is not working, the battery can not charge. Replace the power adapter. If the laptop powers on, the power adapter is properly working. Clean Battery Contacts Turn the computer off. Remove any power cords or sources. Take the battery out of the battery compartment. Dip a cotton swab in isopropyl alcohol. Rub the dampened swab on the battery compartment and battery contacts. Dust and buildup can prevent battery contacts from properly charging. Slide the battery back into the battery compartment. b> Charge and Test Battery Plug the power adapter into the laptop. Charge the battery for six hours. Remove the power adapter. Turn the laptop on. If the laptop turns on and stays on for at least 30 minutes, the battery is holding a charge. If the laptop doesn't turn on or the battery doesn't power the laptop for at least 30 minutes, the battery should be replaced.
Battery Won't Charge Or Short Power Life In Notebook
http://www.daileyint.com/hmdpc/battery.htm
Laptop Battery Depot http://www.laptopbatterydepot.com/problems.asp - clean
Feb 24, 2013 | Computers & Internet
DELL laptop isnt charging but power cord will keep it on why?
Jenni:
Your battery has died. You'll have to buy another one.
Nov 24, 2012 | Dell Latitude D630 Notebook
Please post the step by step process of turning on my laptop acer 5570z.. (powerswitch problem) thanks in advance and more power
Hi
Have you plugged in your power cord to the electric socket so that you can charge the battery
using the laptop with the power cord in while it is charging
so if there is not charge in the laptop at all maybe plug in and turn on socket switch
and leave to charge for an hour or so
then try to start laptop again
hope you can sort it
good luck
Apr 10, 2011 | Acer Aspire 5500 5570-2609 Laptop
My laptop in turn on but not charging and i turn off charging
sounds like you have replaced the laptop charger for the laptop to a universal charger and not an original.
May 27, 2010 | Toshiba Satellite Pro L300 Notebook
The screen on my laptop will not turn on, when i turn on my laptop the buttons light up but the screen wont come on.
your laptop is completely out of charge juice , charge it. if it is fully charged and still wont work, you need a new computer battery.
Jun 29, 2009 | HP Pavilion dv6000z Notebook
Startup/charge issue
Sad motherboard sorry,
replace and start again
Jul 21, 2008 | HP Pavilion dv6000z Notebook
3680 charging issue
ok " new batteries would be a cool Idea, but did ya know you can set your laptop for desk top mode and laptop mode, desktop uses more power , laptop conserves power .
go to control panel look for power management.
Jan 22, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
41 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
