Question about Cycling
My Dawes Super Galaxy has a lifetime frame and forks warranty. I bought the bike in 1993 and now the top tube has rusted through from the inside. On contacting Dawes they claim this is fair wear and tear and is not covered by the lifetime warranty. Where can I go from here and what is a Llifetime Guarantee'?
    Guru:
  • 347 Answers
I do not know the Dawes policy, however it sounds like they are expressing the industry standard. That is they will warranty against manufacturer "defects" for the life of the bicycle. Steel frames rusting are not a "defect" and thus not subject to warranty. It is unfortunate and had the original shop or the manufacture provided either a treatment or resources for treatment of the frame the rusting could have been prevented. But it's still not a defect.
Options: not much, you can either get the tube replaced by a frame builder or buy a new frame/ bike. Sorry, but other than stating your case to Dawes and seeing if they will sell a replacement frame at a discount there isn't much else you can do.
Posted on Mar 25, 2011
Need to know what kind of bike i bought the serial number is SNFS09G41987
Absolutely no way to ID a bike by serial number alone. The brand of bike is on the head tube (where the fork goes through the frame) and the model is on a decal on the frame. If those are missing it DOES NOT MATTER what the bike is, and it's possible it is stolen. Parts are universal and a (cheaply) repainted bike has little value.
Jun 13, 2017 | Cycling
Tip
Bike Headset Installation
Hi I found this Bike Headset Installation guide while searching in Google, it really helped me and I hope it will help others here at Fixya:
  • Make sure the frame has been reamed and faced, otherwise you will have trouble installing the headset, or the headset won't last very long. If you aren't sure, take the bike to a bike shop.
  • Seat the crown race on the fork crown. This requires a crown race slide punch. Pound the crown race down until it sits flat on the fork crown.
  • Clamp the frame into the repair stand.
  • Lightly grease both ends of the headtube and place the headset cups into the ends of the head tube.
  • Slide the cup press through the head tube. Install the lower half of the press.
  • Turn the handle on the top of the cup press clockwise while holding the bottom of the press with a wrench. Work slowly and carefully, making sure the cups press evenly into the frame. Be sure to tighten the cups firmly into the frame, but do not over tighten.
  • Remove the cup press.
  • Grease the bearing and install the fork. For information on how to adjust the headset, see related eHow "Adjust a Bike Headset."
Good luck
Daniel
on Oct 30, 2008 | Marzocchi 2008 XC 700 ATA Mountain Bike...
I have a dawes bicycle serial number SA41211422 what model is this
No way to tell what model from serial number if the decal is no longer on the bike. Dawes did not make expensive bikes, so model is not valuable, and parts are not made by Dawes so the model is unimportant for repair. Search for Dawes on Bikepedia and see which models match the parts on your bike.
Mar 31, 2016 | Cycling
How bike size is measured?
So what does "different frame size" actually mean? And what does that frame size number, 13" or 25" or whatever, mean? It's fairly simple.
The frame size number comes from the length of the seat tube. The seat tube is that nearly vertical tube of the three big tubes that make up the "main triangle" of the bike frame. The seat tube has the bike's saddle attached at the top, and has the pedals and crank arms attached at the bottom. A short seat tube will make the pedals closer to the saddle; a long seat tube will make the pedals further away. The frame size number is the length from the center of the crank arm spindle (the axle that holds the two crank arms together) up to the top of the seat tube (where the saddle and seatpost are attached). On some bikes this is measured in inches, on others in centimeters.
But that's not the only dimension that changes for different frame sizes. As bicycle frames get taller, they also get longer. That means the distance from the saddle to the handlebars gets longer. This makes sense, since tall people don't just have longer legs than short people. They usually also have longer arms, a longer torso, and so on. So the bike frame also needs to get longer in every direction for a taller rider, not just longer from pedal to saddle. The top tube gets longer, which pushes the handlebars further away from the saddle. The head tube (the frame part that the fork attaches to) gets taller, so the handlebars will be higher up. All of these dimensions and more are fine tuned in every frame size, so the right size frame for a person's height fits well everywhere, not just in the saddle.
Dec 21, 2010 | Cycling
How size is measured? So what does “different frame size” actually mean? And what does that frame size number, 13” or 25” or whatever, mean?
Dec 16, 2010 | Cycling
Fork seal replacement
If all you want to do it replace your fork seals, if you can find a way to jack the bike high enough, you don't have the fork tubes our ot the triple trees. Work with on fork tube at a time. Raise the bike up off the ground and take the front wheel and fender off. Brake caliper off it's tube. Now raise the bike up to where you've got about a foot of clearance below the lowest point of the slider. Look underneath the slider where the axle goes through and you'll see an 8mm bolt. Take this bolt out and your lower slider will come off. The fork oil will start to drain as soon as you take the bolt loose as well. Leave a pan under the upper fork while you work on the lower to catch the dripping oil. Replace the fork seal and reassemble that tube. Then, do the next one. Now, refill the tube with the correct amount of the correct oil from the top by removing the top cap nut. Pour in the correct amount of oil for a "wet" refill. The thicker the viscosity of the oil, the firmer the front fork action. I think they came with H-D type E which seems to be a bit softer action than 30 weight fork oil. Make sure you use fork oil. Regular engine oil or transmission oil should not be used and it will foam if you're riding down a rough road and your forks will collapse and not work until the oil settles again. Not a pleasant feeling. It's really doubtful if you'll get anywhere that is that rough with your Harley.
Good Luck
Steve
Sep 12, 2010 | 1993 Harley Davidson FXR Super Glide
I have a Dawes Ace folding bike. The frame has been replaced due a crack appearing in it at the point where the long seat tube enters. Also the bolt securing the saddle to the seat post has cracked three...
yes
the unit is not fit for the purpose and is in fact dangerous to ride as the seat bolt failure could cause you to loose control
items that you should be aware of that may affect your claim
1-- your mass ( folding bikes are designed with a mass limit for the user)
2 --speed limit
3--how you transport the unit
At best you can ask for a refund of you money as there is no warranty limit on design faults and there is in consumer law , that there is an expectation that the unit will last well past the warranty period
I suggest a talk with a lawyer as to the best way to get a result from the manufacturer
Nov 11, 2017 | Dahon Cycling
Hi i purchased a diora diamondback ladies roadbike 12 months ago and it is starting to rust where the headstem meets the forks. is this a problem with this bike? it is kept inside in my laundry with my...
  • The rust is only superficial and will in no way weaken the bike stucturally so dont worry about the frame being weaked. When the frame was painted there may have been a residue from the manufacturing process that was not removed prior to painting and this hasspellcheck.gif resulted in the weakness in the paint. If you are worried about it you could scrape back the rust spots and touch them up with a little primer then a dab of gloss. You can buy small ammounts of paint from a model shop or use metalic nail polish if a metalic finish. An alternative is to treat the spots with rust converter and spray the bad areas with WD40 and this should should protect it.
Sep 05, 2009 | Cycling
Front suspension to soft on mongoose xr-75 mountain bike
The front forks aren't adjustable, as you probably figured out. You can, however, get harder springs if the springs can be accessed at the top of the fork tube. If not, do what I did on my mountain bike. I bought a better pair of adjustable forks that I found on eBay. It will take a bit of investigation on your part regarding the dimensions of the forks, so you get the correct length and width where the forks fit onto the frame (and the overall desired fork length), but you'll be a lot happier with adjustables.
Jun 14, 2009 | Cycling
Bicycle Fork Installation
remove front wheel
undo allen screw or bolt securing headstem to fork
remove headstem and handlebars
undo lock nut & ring retaining bearings, at top of fork tube, do not lose bearings which may be loose.
withdraw fork from fork tube, do not lose upper bearing race
remove lower bearing from old fork
install lower bearing on new fork (I prefer replacing bearings)
remove brake caliper from old fork install on new fork
insert fork in fork tube
install upper bearing (I prefer replacing bearings)
install retaining ring and lock nut on fork tube, adust untill there is no wobble, but free movement, too tight the bearings will collapse too loose the rider will fall off
tighten lock nut
install headstem
tighten headstem allen key - bolt
install front wheel
Oct 29, 2008 | Marzocchi 2008 XC 700 ATA Mountain Bike...
Cycling Logo
199 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
