Question about Dishwashers
Maytag dishwasher has no power changed control panel and thermal fuse still no power...cb ok outlet ok power under dishwasher ok.....still no power
  • 4,323 Answers
Hi
Please post back with the manufacturers name and model no of your Dishwasher for further assistance.
Daniel
Posted on Mar 25, 2011
2 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: no power to dishwasher...cb ok...outlet
Hi
Daniel
Why isnt my dishwasher powering up
assuming the power circuit breaker is ok and you are getting power to the dishwasher itself, there are other factors that could lead to an outcome of dishwasher not appearing to be powering up.
The most likely cause is power supply inside dishwasher is faulty, the controller is faulty or simply the dishwasher display panel is faulty.
More likely the dishwasher has suffered a "thermal" trip. The thermal fuse located in the control panel on the door has blown. You may need to replace it. It is item 6 on this diagram
Jan 04, 2013 | Whirlpool GU2400XTP Built-in Dishwasher
Tip
Wont start or dead dishwasher, no lights, no power, thermal fuse
If you have a dishwasher that is not doing anything, the first thing to check is the incoming power. Make sure the circuit breaker is on and not tripped.
Another place to loose power to the dishwasher is under the sink if it is plugged in to an outlet. It could have come disconnected.
The third place to look is a wall switch. If you have a switch that does not operate a light in the kitchen it may be connected to the dishwasher power source.
If all of these are okay the next place to check is the junction box of the dishwasher. To check here you will want to turn the breaker off first or remove power from the cord before taking panels off. By removing the kick plate or lower panel on the dishwasher you can access the electrical junction box. Many times the wire connectors were not properly installed in this box and over a period of time the connection is lost. This connection should be made by a professional.
If we have power to the dishwasher a common component to fail on many brand such as Whirlpool, KitchenAid, Kenmore, Maytag is the thermal fuse. This device is a two wire heat activated fuse that if tripped will disable the dishwasher. This thermal fuse is attached to the control circuit board that is usually in the console in the upper portion of the door. It can be checked with an ohmmeter just like a regular fuse. When replacing this fuse it may come as a kit with wire connectors, be sure to use all of the parts in the kit. The fuse often will blow due to a loose wire connection on or near the fuse, that is why new connectors are supplied.
A sample image of a typical thermal fuse kit is shown below.
on May 04, 2010 | Dishwashers
No power going to front panel on whirlpool dishwasher gu2455xtsso
If the model number you listed this question under is correct, there is a thermal fuse (also known as a bi-metal) located inside the control panel of the dishwasher. The part number for the thermal fuse replacement is W10258275.
If you type in your model number you can utilize the exploded view parts diagrams at pcappliancerepair.com, appliancepartspros.com or searspartdirect.com to assist you in locating the part. The fuse is listed as item 6 under the "Control Panel Parts" section.
To replace the fuse, follow these steps:
1. Make sure the dishwasher is unplugged or the breaker is turned off.
2. Open the door and remove only the top screws directly behind the control panel.
3. Remove the protective cover from back of the control panel to expose the main control board.
The thermal fuse should be mounted to the control board. If you remove it and take a resistance check, it should read close to 0 ohms, if good. If bad, replace as necessary.
If you have any questions about this repair, or require additional assistance, please let me know. I hope this helps you.
Apr 23, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher does not light up, no power to LED switches
If you no longer have an owner/operator manual for your dishwasher, you can go to mangemylife.com and obtain one. Just type in your model number under the "Manuals" link and your owner's and installation manuals are available in .pdf (Adobe) format that you can download or print for FREE.
If you need a troubleshooting guide, all these appliances have a technical data sheet inside them that qualified repairmen refer to. The tech sheet includes all troubleshooting data and wiring diagrams. You can access it usually by removig the lower toe panel under the door. If its not located directly behind the panel, its usually located under the wash tub. Some manufacturers place the tech sheet behind the inner door panel.
Apr 14, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
My dishwasher just quit during the cycle but it still has power going to it none of the lights on the door will work now and it wont restart
There is a thermal fuse located in the control panel that is probably blown out.
Open the control panel by removing the 6 screws around the top inside of the door. The thermal fuse is located on the top right side. Remove the wires from the fuse. Use a volt neter set for continuity to test the fuse. No reading is a bad fuse.
This link will show the fuse.
http://www.appliancepartspros.com/part_details.aspx?part_id=3115186&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d5162747%26diagram_id%3d914101
Jan 03, 2010 | Maytag MDB4621AW Built-in Dishwasher
Kenmore dishwasher... filled up with water and its lights went off.. no buttons work acts like no power. check the house fuse box - ok ... check the 2 door switch - ok .. checked the thermal fuse - ok ...
Did you check power to the unit? Double check the common and grounds. When servicing I will disconect(unplug from wall) power to the unit. Is it pluged in? Use another outlet(the outlet under the sink may be wired thru a switch for a disposer)even if you need an extension cord. Hope this helps.
Nov 12, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Maytag Dishwasher MDBH965AW will not power.
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replace
If the junction box checks out ok, the wall outlet socket is live, replace the main control or timer module.
Jun 19, 2009 | Maytag 24 in. MDBH965AW Built-in...
Kitchen aide dishwasher KUD101IL control panel not working
1. Check plug outlet.
2. Check electrical box underneath the d/w where power cord connected to d/w (you have to take the kick panel off . The box located on right side). Sometime you can find burn wire there.
3. Check the thermal fuse on computer board. It is inside the control panel on right hand side. The fuse has 2 white plastic connector which sticks out, easy to find.
Dec 08, 2008 | KitchenAid Dishwashers
No power to dishwasher
Start by checking for loose or melted wires under the dishwasher underneath in the "junction box". if the wires arent melted and the plice is ok. then you may need to look for the thermal fuse by the control board. make sure your breaker isnt tripped. go and turn it all the way off then back on.
Nov 28, 2008 | Dishwashers
Maytag dishwasher MDB5601AWS won't turn on
ok under the bottom kick-plate you will find a tech sheet first id start with where my power comes in under the kick plate second remove the front panel and check the door switches third check the control for a fuse or burned wires resistors etc refer to the tech sheet but it sounds to me like a power problem
Jan 25, 2008 | Dishwashers
Dishwashers Logo
57 people viewed this question
Top Dishwashers Experts
