Question about Garden
I have 2 small wires besides the cables to hook up. Where do they go, on the positive or neg side or one on both?
  • 8,404 Answers
Normally, all wires on this type of equipment are + with the obvious exception of the - wire that goes to the frame, just like a car or truck.
I would normally expect the big wire to go from the battery to the start solenoid and from the solenoid to the starter. The smaller wires power other equipment on your unit, including the starter circuit. I would guess that if the wires you are referring to have large hole connectors, they both go to the + terminal. You have not made mention of the make or model tractor you are speaking of.
Here is what you should do. Hook up the large cables - make sure you have the proper polarity. Normally, you will have a red wire and a black. Red should go from the + pos on the battery to the start solenoid and the black to the - or neg on the battery and from there to the frame. Yours may be different ... you may have a white to go to ground or you may have a black that goes to +. The solution is to follow the wires and see where they go. Ground goes to the neg and the other wire goes to the pos.
The other two wires - don't hook em up. Try to start the tractor. If it starts, turn on the different features to see what if anything, works. Attach the wires one at a time (just tough them to the terminal) to see what they do. I think you will find one wire is for the headlights, if you have them, and the other wire is for the rest of the electrical needs, including electric clutch, if so equipped.
That answer your question? Thanks for your interest in FixYa.com
Posted on Mar 25, 2011
Old club car battery wireing digram
How old? The two most common wiring of the batteries are: (old) two batt on driver side , front one neg toward middle of cart, back one positive toward middle. Middle batteries-- both positive towards front of cart. Passenger side-- two batteries- front one - positive toward middle, back one negative toward middle of cart. Connect main negative to drivers side and main positive to passenger side- rest of them are connected in series( neg to pos to neg). The newer wiring only has two batteries that are switched- The main positive and the main negative batteries are reversed but the main cables are connected differently, you can tell by looking at what posts are not connected after wiring them in series. They will be the back ones on each side.
May 22, 2017 | Golf
Were does the wire for the points on a bolens 1058 cone from
The ignition coil will have two small nuts , one on each side of the spark plug wire. It can be labeled many ways, + - , pos neg , Bat Dist , point will hook to the - ,NEG , Dist . The only time this will be the other way is when you system is a Positive ground, that is the + , positive of the battery hooked to the frame instead of the - Neg.
Mar 13, 2016 | Garden
Why does the ground cable spark when u hook it up to the battery?
ground cable doesnot connect to the starter!! positive,+.goes to the red side,neg - is ground
Jun 25, 2015 | Cars & Trucks
How do I hook up this unit Two wires or four
Almost all car batteries have 2 pos and 2 neg. More precisely, 1 pos post and 1 side connector, 1 neg post and 1 neg side connector. You only usually use use one set or the other depending on what connectors are on the end of your cables. You can connect something else to the side posts if you need to, but generally only pair is used.
Feb 28, 2015 | Cars & Trucks
Convert battery cables from top post to side mount replacement ends?
If all you are doing is changing to a side post battery, just connect all the positive cables from the old pos post to the new pos holder and all the neg ones to the new neg holder. If you've already cut them all off and not sure where each wire goes, all the reds are positive, all the blacks are neg. To make sure use your continuity meter to test. Connect one meter lead to any good clean metal part on the car and test between each black wire in turn, the neg ones will show a circuit, the pos ones will not.
Feb 10, 2015 | 1993 Chrysler Concorde
Got 1987 4x4 Ford Pickup, which side does the Pos. side of the of battery cable hook on to the Solenoid
The solenoid has two large terminals--one side goes only to the starter motor. The other side gets the positive battery cable plus 1 or 2 small wires with large-hole ring-terminals. The small terminal should have only one small wire with a push-on connection. If you had hooked the cable to the starter side, as soon as the battery was completely connected, the starter would run. Hope this helps!
Oct 04, 2010 | 1987 Ford F 150
How to hook up 2 new batteries
hook them up in parallel, pos to pos, neg to neg from one battery to another, then pos cable to battery prs and ground cable to neg battery
Jul 29, 2010 | Renault Fuego Cars & Trucks
8 wires on my subwoofer??
"One has positive and negative input, another positive and negative output (red and black on each)"
Just from your description, it sounds like pos/neg input are the 12 volt pos neg supply for the amp inside the subwoofer. Red is pos, black is neg.
"positive and negative output (red and black on each)"
This sounds like it's used if you want to proved 12 volt pos/neg to another component.
"and a third wire with left input right input positive and negative (blue, red, yellow and black)"
This is for the cables coming from the "subwoofer out" on the amp. This is 4 wires altogether -- correct?
May 08, 2009 | Audio Players & Recorders
There was a spark from the positive cable when I hooked it back up can not jump the truck not getting anything did I cross some wires somewhere?
Ford uses fuseable links, look around battery and starter selanoid, could have burnt one when it sparked, if you find one just pull on it if its burnt it will pull apart. Just food for thought, any time your hooking up battery cables, its best to hook the positive cable first and negative last, that way if there is a spark it will be on the neg. side where it can't run thru the system and cause harm, with all the sensors and the computers, that little spark will cause a lot of problems.
Mar 05, 2009 | 1988 Ford F 250
Garden Logo
46 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
