Question about Neff Washing Machines
Cycle stops before finishing and is still full of water. Keeps coming up with anti-crease light flashing and open door.
    Brigadier General:
  • 6,277 Answers
Sorry but I do not know your particular machine BUT I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 25, 2011
Pre-Wash and Crease Care lights flashing?
WHILE IT IS LOADING WATER, TRY TO ADVANCE THE WASH PROGRAM; INSTEAD OF LARGE CAPACITY GO TO MEDIUM.
Jun 20, 2015 | Washing Machines
Keeps stopping
try a different cycle anti crease is not a full term cycle
May 22, 2015 | Dryers
How can I stop the lights from flashing mid cycle and make the machine continue its cycle to the end and drain?
first you need to take off the drain hose that allows the water to pump out and check to see if it is blocked at the part that it connects to from the machine , you could try to blow back the water but if its blocked i doubt it , after you remove the hosing inspect the inside of where it fitted onto , with the cord unplugged from the wall you might be able to use a bit of wire with a tiny hook bent onto it and pull out any blockages . also make sure the water pump is engaging when it goes into the pump cycle .
Aug 07, 2017 | Washing Machines
Anti crease light flashing, keeps stopping and beeping
Check the dryer vent to see if it is free and clear.
Jan 26, 2014 | Miele Dryers
Cycle is not finishing and the red lock light and green anti crease light is flashing
I am sorry, I have no specific manuals or experience with this machine. Another expert should pick up on this and hopefully will provide you with a good solution.
Nov 25, 2011 | Indesit Washing Machines
Dishwasher starts to work but after 30 seconds stops and two lights start flashing on pannel
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You shouldNEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.Service manual below, if the above doesn't help. http://appliancejunk.com/ge/dishwasher/31-9137.pdf
Jun 24, 2010 | Hotpoint 24 in. FDW60 Free-standing...
My dishwasher fills, but won't start running. it just sits full of water and just hums.
Apr 14, 2010 | GE 24 in. GSD1000G Built-in Dishwasher
START BUTTON AND ANTI CREASE BUTTON FLASHING RAPIDLY
It appears your Main Controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 03, 2009 | Washing Machines
HOTPOINT WASHER DRYER WD440G
That means that the machine detected a problem at a certain point of the cycle and stopped.
If the machine stops when filling check the inlet valve and the water supply.
If it stops because ofervilling check the water level switch.
If it stops when the cycle is hot water only , then check the heating element.
If it stops when draining, then inspect drain filter, drain pump , and drain hose. You access the drain hose removing a panel at the front side of the machine.
If it stops when motor is supposed to spin faster (rinse) then it is motor control unit or motor coupler.
If it is none of the above, then it is a defective control board.
Feb 16, 2009 | Hotpoint Ariston WD440G Front Load...
Machine is locked
to open your door make sure all the water is out of your drum if not get the outlet hose and place on the floor into a bucket if water comes out than your pump is either blocked/faulty
Aug 12, 2007 | Bosch Logixx WFT 2806 Front Load...
Washing Machines Logo
63 people viewed this question
Top Neff Washing Machines Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Are you a Neff Washing Machine Expert? Answer questions, earn points and help others
