Question about Air Tools & Compressors
Hi this compressor is supposed to deliver 7.8 cfm fad but is not keepin up with a tool that is rated needing 6cm so it appears that my machine is not pumping enough air. Everything else seems to work fine it starts, gets upto its cutoff pressure but presumably it is not pumping quick enough. If it was a car engine I would do a compression check to see if it was the piston rings or valves that are the problem but how do I do that on a compresssor. The pump is a twin cylinder single stage 3 hp item. any help would be appreciated. Many thanks Steve
  • 54 Answers
The best way to determine how the compressor is doing is with a pump up test. Time how long it takes the compressor to pump up from one pressure to another. If you know the tank size, you can then compute the air delivery of the compressor:
CFM=(Pressure Change / 14.5) x (tank size in gallons / 7.48) x (60 / time in seconds)
I'd recommend start timing about 40 or 50 PSI and pump up to shutoff.
If your compressor has no aftercooler (it probably doesn't) this should read a bit higher than your 7.8 CFM FAD because the air will be hot, but it will get you in the ballpark.
If compressor seems OK, tool could be worn or fed too high a pressure (if you put 120 PSI to a tool, it will use quite a bit more air than it is rated for - they are usually rated for about 90). If your compressor maintains pressure at 95 or 100, but doesn't gain ground, everything is probably OK. I'd just add a pressure regulator to maintain 85 or 90 to the tool in that case.
Posted on Apr 02, 2011
I just bought a craftsman pneumatic 1/2-in drive impact wrench. And used it with my craftsman 4-gallon 1hp air compressor tried to loosen the bolts on my car wheel wouldn't loosen them help
Pneumatic tools are rated in cfm (cubic feet per minute). Your 1 HP air compressor is rated at probably not more than 3 cfm while the 1/2 " impact driver needs at least 8 cfm, maybe 12 chm of air.
The compressor must provide more chm than tool rating needs.
It is a problem, by the time you look at five horse power air compressors and larger, a lot of electric power is needed. A circuit of 220 volts, 20, 30, or more amps would be required to run those large expensive compressors.
If you can, return the air tool and get a good electric tool instead.
Leave those high air volume air tools to shops that are so equipped to use, or invest if you must.
Jul 24, 2017 | Craftsman Air Tools & Compressors
I have an old craftsman impact gun model number 875-188992. what size compressor do I need for taking off lug nuts/automotive work?
The two most important specs are CFM at 90 psi (that's how fast the compressor can compress more air when the tank starts to run low) and how big the tank is. Virtually any compressor that has a top pressure rating 20 psi higher than you need for your tool (which is usually about 90 psi) and that has a tank of a couple of gallons will work. But the smaller the tank, the shorter time you can operate the tool before the compressor has to kick in. And the lower the CFM at 90, the longer you will have to wait for the tank to come up to pressure again so you can operate the tool at full pressure. If this is for occasional use and you aren't in a hurry, you don't need much of a compressor at all. If you want to operate continuously, then you should get something with a CFM at 90 psi that is higher than your tool's CFM consumption. Keep in mind that impact wrenches don't operate continuously like paint sprayers do. Good luck. Vote if you found this helpful. Al K
Jun 07, 2011 | Air Tools & Compressors
Craftsman air compressor 2 hp 20 gallon, seems to running o.k. builds up to 100lbs shuts off when it hits 80lbs come back on, but when i run a tool , right around 90lbs the tool dies out and runs week.when...
IT depends on the tool. Some tools require higher cfm. (cubic feet per minute) of air. IF your air line is not large enough, then sometimes 90psi is not enough to operate a tool as there is a pressure drop at the tool. Look at the required cfm for each tool. Find a chart for air line size, cfm and pressure. Most impact wrenches should be used on a minimum 3/8" air hose. You could look at your manual and see what the max pressure is on your compressor. You may be able to decrease the differential pressure e.g off and 100 and on at 90, but then the compressor will cycle more frequently, and may exceed the duty rating of the compressor.
Oct 01, 2010 | Craftsman Air Tools & Compressors
HOW CAN I DTERMINE THE CFM RATE AT ANY GIVEN air pressure
the air requirments of any air tool will be marked on it
the main problem in this area ,is the compressors, you are wasting time and money if your compessor is less than 15cfm and even then if you are useing sanders or grinders you will spend abit of time waitng for it to catch up
Oct 26, 2009 | Air Tools & Compressors
AIR VOLUME REQUIRED
You need to look at the tool cfm requirements because they are posted on the package or usually in the ads. Your compressor will run the sander, just how long at a time will depend upon your tool's cfm. Rick
Apr 14, 2009 | Air Tools & Compressors
Nail Gun how to
One of the factors used to designate compressor power is motor horsepower. However, this isn't the best indicator. You really need to know the amount of air the compressor can deliver at a specific pressure. The rate at which a compressor can deliver a volume of air is noted in cubic feet per minute (cfm). Because atmospheric pressure plays a role in how fast air moves into the cylinder, cfm will vary with atmospheric pressure. It also varies with the temperature and humidity of the air. To set an even playing field, makers calculate standard cubic feet per minute (scfm) as cfm at sea level with 68 degrees F air at 36% relative humidity. Scfm ratings are given at a specific pressure–3.0 scfm at 90 psi, for example. If you reduce pressure, scfm goes up, and vice versa. You also may run across a rating called displacement cfm. This figure is the product of cylinder displacement and motor rpm. In comparison with scfm, it provides an index of compressor pump efficiency. The cfm and psi ratings are important because they indicate the tools that a particular compressor can drive. When choosing a compressor, make sure it can supply the amount of air and the pressure that your tools need.
Sep 01, 2008 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
Nail Gun how to
Aug 27, 2008 | Irwin 24" Bar Clamp Multi Position Jaw
Air hammer problem
* Proper match between air compressor and tool ratings. * Correct fittings that match the tool and air hose. * Well-maintained air compressor and air hose. * Correct air pressure adjustment for the tool being used.
Aug 27, 2008 | Ingersoll Rand Air Hammer - 2 9/32in....
Portable Air Compressor Comparison
Portable air compressors give flexibility to the job both inside and outside the working environment. They're powered by electric, gasoline or diesel engine. A larger portable air compressor often has its own carrying trailer with wheels and handles. You buy a compressor based on its horsepower, pounds per square inch (PSI) and cubic feet per minute (CFM). Choose a portable air compressor to make work quicker and easier. Figure the amount of power you need based on the type of job and air tools used. Know the cubic feet per minute (CFM), such as 5 CFM for small household tools and 10 CFM or more for wrenches or sanders. All air tools have these ratings. Select a gas- or electric-powered engine. Gas gives a higher reliability for frequent use and portability, but consider electric for enclosed areas for its lack of fumes. Pick an air tank based on amount of use time and tools. Large tanks are best for longer use with sanders or grinders and smaller tanks for less time, like wrenches and air hammers. Consider the pump type you need: belt for heavy use or direct-drive for light home use. The quieter belt-drive pump needs periodic oil changes. Buy an inexpensive, small electric portable air compressor for small jobs. These typically operate from a 12-volt power outlet and inflate a 14-inch tire in a few minutes. Get a 150 PSI, 120 volt motor pancake-type air compressor for home use. These light-use models typically carry two air couplers, allowing hook up of two air tools and adequate 25 feet or more air hose. Obtain a larger PSI portable air compressor for bigger jobs, like nailing, with longer continuous use capabilities.
Aug 27, 2008 | Acme Automotive ACMA680CS Typhoon High...
Air Tools & Compressors Logo
99 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
