Question about Canon Pixma MP500 All-In-One InkJet Printer
Mp500 printer Well not print in black only well print any color but not black has a new ink tank
  • tyso0006 Aug 11, 2008
    My printer has quite printing with cyan (in the middle of a black and white photo). I have replaced the cartridge and it still won't engage any cyan. I try to print a test of 4 squares one of each color and every time no cyan.
This is what I did. I kept trying, taking it out, making sure it was inky, etc... eventually it started to use cyan again.
Posted on Aug 12, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
Take out clean contacts, clean cartrtidge, make sure there is a smooth flow of ink ( use tissue paper to put in bottom of cartridge to test)
I have the PIXMA MP500 & 3 of m ink cartridges #8 blue, magenta & yellow ran out of ink but I have a brand new #8 black & #5 pgbk that I changed. Now I just want to print from the black ink...
Unfortunately, the printer is designed to need all of the ink cartridges in place and no empty ink cartridges. This is designed to protect the ink system from damage.
There is a way to print a color document in black and white but it won't help with your issue. (Enter the Printing Preferences by right clicking on the icon for the Canon MP500 in the Devices and Printers Panel (Win7). (It's Printers for the Vista Classic View and Printers and Faxes for XP) Then put a check mark in the box for Greyscale Printing in the main tab. Then click OK and close the window. There is a similar method for Mac OS versions.)
I wish that I had better news.
Jan 03, 2011 | Canon Pixma MP500 All-In-One InkJet...
Cannon MP500, new ink now printing black line on back page
Got to Printers and Faxes in Start, Right click on the icon for the printer, click properties, click maintenance and try cleaning the backing plate from there.
Jan 19, 2010 | Canon Pixma MP500 All-In-One InkJet...
Printing only b&w from a colour Canon Pixma 500
The Canon will not allow you to print with empty color tanks, or without them installed.Canon does not want the ink to dry in the printhead which would destroy he printhead.
Sep 01, 2009 | Canon Pixma MP500 All-In-One InkJet...
Black ink only
Print using pigment black ink only (Windows) Instructionsto print using only the pigment black ink tank only. Occasionally youmay need to print using black ink only. Using grayscale alone does notprovide this option and the color inks will still be used. By followingthis procedure you may print using only the pigment black ink tank. Note: Image quality may be sacrificed when printing photographs.
  1. Open the Properties / Preferences window for the printer.
    For Windows Vista
    • Click/ Select 'Start' from the bottom left of the Windows screen, 'ControlPanel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    • Clickyour right mouse button on the listing for your printer, and thenselect 'Printing Preferences...' from the menu that appears.
    For Windows XP Home Edition
    • Click/ Select 'Start' from the bottom left of the Windows screen, 'ControlPanel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000/Me/98
    • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
    • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
  2. Click on the Main tab.
  3. Select 'Plain Paper' as the Media Type. If any other paper type is selected, color ink will be used to create black.
    Note: The pigment black ink will only be used when printing on plain paper.
  4. Select the box for 'Grayscale Printing'. If the document to be printed is in black only, then this step may be skipped.
    Note: If either 'Borderless Printing' or 'Duplex Printing' are enabled from the Page Setup tab, grayscale will be created using a combination of the color (dye) inks to prevent smearing.
  5. Click 'OK' to save the changes.
The printer will now only use the pigment black ink tank.
Oct 15, 2008 | Canon Pixma MP500 All-In-One InkJet...
PIXMA MP500 PRINTING IN BLACK ONLY
No I did not fix it. Can this printer, print only using black ink? That is the question.
thanks
Chet
cd.sales@comcast.net
pixma mp500
Sep 26, 2008 | Canon Pixma MP500 All-In-One InkJet...
Ink cartridge problem
Solution: Snap in ink tanks properly MP500
Ink Tank Seated Properly Refer to the following steps to verify the ink tanks are seated correctly:
  1. Confirm that the printer is powered on and press the Open button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
  3. Open the inner cover.
    CAUTION:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  4. Press down on the ink tank until a click is heard, thereby making sure the ink tank is seated properly.
    Note:
    Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
  5. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    Note:
    Ink Tank Lamp
    You can check the status of each ink tank according to the way its lamp flashes.
    • - On: The printer is ready to print.
    • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
    • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
    • - Off: An error has occurred and the printer is not ready to print.
  6. Close the inner cover and the scanning unit (printer cover).
    Note:
    1. When closing the scanning unit (printer cover), be careful not to jam your finger.
    2. When starting printing next time, the print head cleaning launches automatically.
Mar 30, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP500 All-In-One InkJet Printer Logo
94 people viewed this question
old marine
old marine
