Question about Fender FrontmanTrade 25r Combo Guitar Amplifier
I have a Frontman Fender 25R, it has a power, the auxilliary input is working (the RCA, red and white ) sound is produce, when I plugged an electric guitar on the 1/4 input there is no sound coming out, What may cause be the problem, thank you for helping me and I'll appreciate it very much.
  • Fender Master
  • 5,603 Answers
You actually have the "B" version as the original 25R doesn't have RCA jacks. Anyway, on with your problem...
I want you to do a test: With a set of headphones plug them into the preamp output and then play your guitar... don't expect much loudness, it may be very faint and will ONLY be in one of the sides of the headphones. This tests the preamp section... have the guitar volume wide open.
IF you can hear the guitar that way, then the switch contact on the PA INPUT jack (not the preamp output) is not making contact. These jacks are really poor and the problem is not that uncommon. Fix is to open the unit and increase the spring tension on the contact or replace the jack. Never use the jack as they worsen evertime you plug something into it.
Note that the failing switch symptom MAY be broken soldering in the vicinity of the jack so look for that also. And also check the soldering of the guitar input jack as that is a common problem. Always loop your guitar cable through the handle so tripping over the cable doesn't break the jack by yanking the plug sideways... another common problem.
Posted on Mar 25, 2011
Play mac through Fender Frontman amp
Simple: connect the headphones out (3.5mm jack) to the input jack of your fender (6.3 jack). By doing this you will loose one channel so you better generate a mono signal inside your computer before. Electrically this is no problem, nothing will be damaged. Turn the gain and volume knobs down and apply a signal from your Mac. Gently increase gain and volume. Et voila wonderful mono sound through a guitar amp
May 24, 2012 | Fender Frontman 65R 65W 1x12 Guitar Combo...
I have a little Fender Frontman Reverb, 15Amp, a versitile and handy amp, closed back and dual front ported with extension and headphone outputs. Went to use it one day and as soon as I turned it on I got...
It sounds like one of the preamp valves is faulty or other components in that area of the circuit causing a positive feedback loop which is generating the noise. You need to take it to an authorised Fender repairer in your area. Whereabouts are you?
Dec 13, 2017 | Fender ® Frontman 15R Electric Guitar...
Can i go straight out of the pre out on my fender frontman into a powered mixer pa system
yes,, Pre means before powered or amplified ,, so yes you can do this to a powered mixer, just be sure that the power is off before making any connections,, without the ground of the rca cable touching , the blast to the speakers can invert the cone !!
Aug 26, 2011 | Fender Frontman 212R 100W 2x12 Guitar...
Will a MP3/iPod/CD player play through a Fender Frontman 65 or 212 "Power In" input jack?
The power amp input jack takes "line level" input BUT is monaural (single channel). The output of an ipod is Stereo. Hence you would have to "mix" the two channels before connecting to the Fender. Mixing does NOT mean just tying the two channels together. A minimu thing would be a passive resistive mixer consisting of a resistor from each of the IPOD channels to the common point going to the input of the Fender. Remember if you plug into the Fender power amp input you DISCONNECT the preamp and other circuits and would ONLY hear the IPOD input.
Feb 24, 2011 | Fender Frontman 212R 100W 2x12 Guitar...
Can i put my fender strat mexican guitar into number two jack on the ampI got it today not sure
The Fender Stratocaster (in common with all Fender guitars) has passive pick-ups so should be plugged into the no 1 socket.
Whilst it will work in the No 2 input socket this has lower sensitivity and is intended for use with guitars that have active (battery powered) pick-ups.
Feb 10, 2011 | Fender Frontman 212R 100W 2x12 Guitar...
I tune on my frontman 25r and when I input I dont get any sound other than hiss.I tried two different cords and guitars but nothing but his. what should I do?
It sounds like a failure in the preamp stages, but fortunately you can do a lot of troubleshooting externally.
Drive the "power amp input" jack with another source of audio that has some reasonable output... like a small CD player. If this works (no mind the level, just the quality, that will verify if the power amp is OK.
If the power amp is OK, the use the preamp out to another amplifier.
If it is OK, then the Power amp input jack switch MAY be bad, When nothing is plugged into these, the preamp is sent to the power amp by a switch on the power amp input jack.
If you do these tests, you can email me the results and I will give further tests to run.
Nov 19, 2009 | Music
Fender FrontmanTrade 25r Combo Guitar Amplifier Logo
428 people viewed this question
Top Fender Music Experts
Michial Gueffroy
Virgil Watts
Are you a Fender Music Expert? Answer questions, earn points and help others
