Question about Schlage FE595PLY626FLA Satin Chrome Electronic Security Plymouth Keypad Ent
Lost manual, how do i change my code on my lock
  • 963 Answers
You will find the how to manuals and videos on this web page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Posted on Mar 27, 2011
I lost the manual and i need to reprogram the codes
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will give you instructions for various models of Schlage locks:
There is a video on this page, showing how to change codes.
Jan 22, 2011 | Schlage Electronic Lock FE595 Plymouth or...
I need to change my security code asap but ive lost the manual to the instruction can u please help
Jan 08, 2011 | Schlage BE365-CAM BE365CAM619 Satin...
Changed battery and lost program cant find manual need reprogram 4 number code
changed the battery and lost the manual, put my code in and it worked , latter it started to beep and now it doesn't work... respond at all ....help thanks
Apr 19, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
Need to change combination code lost manual
Lost the 6-digit programming code. How do you resore the lock?
Mar 09, 2010 | Schlage BE365-CAM BE365CAM505 Lifetime...
Lost manual and need to change the code what are the steps
Here's a link which tells you how to remove the cover, and reprogram the lock codes:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Jan 05, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
LOST SECURITY CODE FOR LG KE970
Then enter lock code instead. The defaults are in the manual. Thank you.
Aug 26, 2009 | LG Shine KE970 Cellular Phone
Need info to change code
Here's a link to the Schlage web site with pdf's and videos showing how to operate and program your lockset.
Just select which info you need from the list on the page.
http://consumer.schlage.com/customerservice/FE575_install_inst.asp
Hope you find this Very Helpful - Best regards!
Aug 20, 2009 | Schlage FE575-CAM-ACC FE575CAM505ACC...
Have to change the key code? No manual.
You can change codes as often as you like, for use by babysitters, contractors, etc. You can also reset the lock so you can reset the master code, which is needed in order to set the other user codes.
Rather than re-type all the step-by-step instructions, since you also could benefit by having a copy of the manual for your use and reference, I'll give you a link to a free copy you can save and print.
http://www.smarthomeusa.com/Products/ED1460XXXX/manuals/WeiserLockPowerbolt1000-manual.pdf
Hope you find this Very Helpful and best regards!
May 02, 2009 | Weiser Lock POWERBOLT ELEC DEADBOLT
What is the default code for unlocking a programme I have recorded?
hi, the default password/code stated in the user manual for my philips DVDR3460H is "3308".. try using that to unlock your recording - although, - it does state in manual that code needs to be change to own personal code before can lock and unlock programmes (buts its let you lock - so should also let you unlock) anyway to change the password - using the setup menu - browse down to change password and first input 3308 and then your own choice (sorry to state the obvious - but some people might need to hear the obvious - no offence intended)...
well hope that resolves the issue and the program was worth the wait..
Good Luck
May 04, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Schlage FE595PLY626FLA Satin Chrome Electronic Security Plymouth Keypad Ent Logo
50 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
