Question about Thomson GE Cordless Telephone 27995GE1
How do I turn off the alarm of my phone.........I might have accidentally press something.........
    New Friend:
In the phone menu, scroll until you reach the ALARM setting - it can be set to ONCE or OFF. Set it to OFF.
Posted on Jun 05, 2016
Doro 626 alarm
Alarm 1. Press Menu Organizer Alarm On. 2. Enter the alarm time using the keypad. • For a single occurrence, select Single. • For a repeated alarm, select Repeated. Scroll through the list of days and press On to enable or Off to disable the alarm for each day. 3. Press Save to confirm. Snooze or turn off • When the alarm goes off a signal will sound. Press Stop to turn off the alarm or press Snooze to repeat the alarm after 9 minutes. Note! The alarm will work even when the phone is switched off. Do not press Yes to power on if wireless phone use is prohibited or when it may cause interference or danger. Tip: To edit an alarm, press Edit or Off to stop the alarm.
Dec 16, 2017 | Doro Cell Phones
How do I set the alarm on model wau111a tag watch
  • Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
  • Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
  • Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
  • Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
  • Nov 06, 2014 | Tag Heuer Link Watches
    Hi there, If the phone is off the alarm clock doesnt work, is this normal? If so is there any app I can use to have the alarm with the phone powered off?
    You mean you press and hold the power button for a couple of seconds, and, then, select the 'Power off' option? If so, nothing will work on your phone. It's perfectly normal. It's something like removing any electrical stuff from the mains power. In that same menu, choose 'Flight mode' instead. All radio communications will be turned off, but everything else will still be kept alive.
    Hope it works for you.
    Regards, Carlos
    Jun 09, 2011 | Motorola Mobility Defy Cell Phone
    Sprint htc touch pro 2 - will locking prevent accidental dialing or does it have something to do w/the backlight,,,every couple min. phone lights up and then the buttons are too easily accessed leading to...
    locking your phone will help stop accidental dialling. if you don't lock your phone all you have to do is touch the screen and your ready to press buttons if you lock it then you have to unlock before you can press them, so in turn to acccidently call somebody it would have to unlock itself in your pocket.
    Dec 14, 2010 | HTC Touch Pro Smartphone
    I accidentally hid
    To make the alarm appear press the button at 8 O'cloc.
    To turn off/on the alarm press the button at 2 O'clock.
    Jan 05, 2010 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
    Samsung BlackJack sgh-i607 turned on yet reads ''phone off''
    Follow these steps in order:
    --- Enter the following exactly: *#1546792*#
    --- The following menu (or something close) will appear:
    1. Version
    2. Preconfiguration
    3. NETWORK & CALL SETTINGS
    4. Internal
    Simply press the number '3' on your keyboard or scroll down and select NETWORK & CALL SETTINGS.
    1. Auto Answer
    2. Power on Attach
    3. Service Domain
    4. Network Order
    5. NETWORK MODE
    Simply press the number '5' on your keyboard or scroll down and select NETWORK MODE.
    --- The following options will appear:
    Auto
    GSM
    WCDMA
    Select AUTO
    --- Press the red key to exit the menu.
    You should see the phone acquire service and update the date and time.
    Dec 07, 2009 | Cell Phones
    How do I turn off the alarm?
    Pageturn off alarm
    When the display shows an alarm:
    To turn off the alarm, press Dismiss or Red/End button.
    To set an eight-minute delay, press Snooze.
    Here is the link for your manual: http://www.motorola.com/staticfiles/Support/Mobile%20Phones/Motorola%20Tundra%20VA76r/US-EN/_Documents/Static%20Files/VA76r_UG_att_9519A36A.pdf
    Oct 22, 2009 | Motorola Mobility Tundra VA76r Cell Phone
    Set the alarm
    To turn the alarm off press and hold st/stop and then press lap/reset. To set, press the lower left hand corner button, you will see the option to set the alarm first and then the option to set the actual watch time.
    Apr 10, 2009 | Watches
    Accidentally threw out instructions and can't turn off alarm in a
    Just press ALM1 button for a second and it will be turned OFF. Do the same for ALM2.
    Mar 27, 2009 | La Crosse Projection Alarm Clock with...
    Thomson GE Cordless Telephone 27995GE1 Logo
    97 people viewed this question
    Top Thomson Lands Phones Experts
    David Burbee
    David Burbee
    Are you a Thomson Lands Phone Expert? Answer questions, earn points and help others
