When I open windows explorer and look at the 'computer' icon there are normally two icons in the 'folder'. The first is Local Disk (C) and the second is normally my CD/DVD disk drive. This has recently just disappeared. I've tried to reboot the laptop which doesn't work. I can open and close the tray and you can hear the disk spinning for a few seconds and then it stops. Any ideas how I can solve this?
  • lennyfixit Mar 25, 2011
    Go into disk management (control panel, administrator tools, computer management).
    Is the CD drive listed here?
    Scholar:
  • 80 Answers
There are 3 possible solutions to your issue.
First option is to check if CD-Drive is enabled or disabled:
Go to --> Control Panel open --> System go to the 'Hardware' tab and click on 'Device Manager' Find your CD drive and if it has a red cross on the icon just right click and click 'Enable'
2nd option involves tweaking the registry. It would be best to create a restore point before doing the process so that if ever you make a mistake, you can restore your windows to its previous state: 1. Click Start, and then click Run. 2. In the Open box, type regedit, and then click OK. 3. Locate and then click the following registry subkey: HKEY_LOCAL_MACHINE/System/CurrentControlSet/Control/Class/{4d36e965-e325-11ce-bfc1-08002be10318} 4. Click the REG_MULTI_SZ data type UpperFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes. 5. Click the REG_MULTI_SZ data type LowerFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes. 6. Quit Registry Editor, and then restart the computer.
3rd option is to format your computer and re-install windows.
Hope this helps.
Posted on Mar 25, 2011
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
You might try going into the control panel and selecting add hardware. If this doesn't do the trick, you may have a bad DVD drive or it isn't seated properly.
How to Enlarge Thumbnails in Windows Explorer?
Open the libraries folder. Or you can open another folder, such as the pictures, downloads, computer, etc. It doesn't matter which folder you begin on; all the Windows Explorer folders have the same method of enlarging the thumbnails.
Locate the taskbar near the top of the screen. On the upper right side of this, you'll see three icons. The first one on the left side, when rolled over with your cursor, should read "Change your view."
Click on the "Change your view" icon. A small menu will pop up with a list of different ways the Windows Explorer can present itself.
Select "Extra Large Icons". The icons will become large enough for you to see easily.
Repeat for all other Windows Explorer libraries.
Oct 19, 2016 | Computers & Internet
Tip
Set a new Windows Explorer launch folder When you run Windows Explorer, it...
Set a new Windows Explorer launch folder When you run Windows Explorer, it always opens to the Libraries folder. That's fine if you use Microsoft's default file organization, which designates Libraries as the overall container for your folders. But what if you don't? You might prefer to have Windows Explorer open to Computer or any other folder you choose. Here's how to do it:
1. Right-click the Windows Explorer icon on the taskbar (it's the one that looks like a folder), and then right-click the Windows Explorer icon from the context menu that appears and select Properties. The Windows Explorer Properties dialog box appears.
2. You'll have to edit the Target field on the Shortcut tab of this dialog box in order to change the default location at which Explorer opens.
If you want Explorer to open to a specific folder, simply enter the name of the folder, substituting your folder name for Folder, below, like this:
%windir%\explorer.exe c:\Folder
So to open Explorer to the folder named Budget, you would type this in the Target field:
%windir%\explorer.exe c:\Budget
If you want Explorer to open to special, pre-set locations, such as Computer, you'll need to enter special syntax in the Target field. Following is a list of three common locations and the syntax to use, followed by the syntax for the Libraries folder in case you ever want to revert to the default.
  • Computer: %windir%\explorer.exe ::{20D04FE0-3AEA-1069-A2D8-08002B30309D}
  • My Documents:%windir%\explorer.exe ::{450D8FBA-AD25-11D0-98A8-0800361B1103}
  • Network: %windir%\explorer.exe ::{208D2C60-3AEA-1069-A2D7-08002B30309D}
  • Libraries: %SystemRoot%\explorer.exe
3. After you've changed the Target field, click OK. Next time you launch Windows Explorer, it will open to the new location you've designated.
on Jan 12, 2010 | Computers & Internet
Lost my browser
LOL lost it how? You mean it is no longer on the Desktop? Have you clicked Start/Programs and see if it is in the Programs List? You can also click Start/My Computer then click the C: Local Disk and navigate down to the Program Files folder. Open it and look for your browser folder such as Internet Explorer. Open it and you will see the ICON that you normally click on to start your browser. Click on it and see if your browser starts, if it does you can move it to your desktop by Right Clicking on the icon and select Send To/Create Desktop Short Cut. Right Click on it again and select Pin to Start Menu. Now you'll have it in two different places.
Mar 19, 2012 | HP Computers & Internet
How do i update my Archos 504?
How to install firmware ..?(update)
Step 1. Download the firmware to your computer-->click HERE to download the update file When you download the update file, your browser may warn you that the file 'could be harmful'. This is normal because browsers are not familiar with files that have a .AOS extension and suspect that they could be malicious. These files are not harmful to your computer.
Step 2. Turn on your ARCHOS device and connect it to your computer with the USB cable
Step 3. On the ARCHOS, choose to connect and wait a few seconds for your device to be detected by the computer
Step 4. Copy and paste the downloaded firmware (.AOS file) to the ARCHOS device.
  • Case 1: logo_firm_hdd.jpg Your ARCHOS is detected by your computer as a Hard Drive (E: for example) in Windows® Explorer. Paste the update file directly onto the ARCHOS hard drive icon.
  • Case 2: logo_firm_g4.jpg Your ARCHOS device is detected as a 'Mobile Device' in Windows® Explorer (not as a hard drive) and you see just two folders Data and Media when you open it. Paste the update file into the folder called Data.
  • Case 3: logo_firm_g4.jpg Your ARCHOS device is detected as a 'Mobile Device' in Windows® Explorer (not as a hard drive) and you see Internal Hard Drive when you open it. Open this Internal Hard Drive icon and you will see the various ARCHOS folders inside (Video, Music, etc.). Paste the update file into this area but be careful not to paste it into any of the folders there.
Step 5. Disconnect the Device
Unplug the USB cable (for 'Mobile Device' connections) or use the "safe disconnect" green arrow icon (for Hard drive connection) in the system tray before unplugging the USB cable.
Step 6. On your ARCHOS device, click on "Update Firmware"
Click on the "tab" button to show the settings screen. Select the "System" icon and then click on the "Update Firmware" button. For the ARCHOS 104, 202, & 204, go to the settings and open the icon "System" where you can find the Update Firmware button.
Dec 31, 2010 | Archos 504 500870 Digital Media Player
HOW CAN I PUT A FOLDER AND THEN A FILE ON TO A SANDISK CRUZER USB 2.0 4GB FLASH DRIVE ?
When plugged on a computer running Windows, the SanDisk Cruzer appears as 2 icons: a CD-ROM and a regular hard drive. The drive letters for the two are consecutive (ex: E:CD_ROM, F:SanDisk.
Any file or folders that you have to store on the SanDisk drive must be stored on the second device.
If the folder already exists on your computer, point to it with mouse cursor and right click. In the menu options look for the one that says copy and select it.
Open the Windows Explorer, locate theCuruzer icon that represents the hard drive part, click on it to open it. Point somewhere where there are no icons and right click the mouse cursor. Select the submenu Paste.
To copy and paste you can also use the keyboard shortcuts CTRL-C and CTRL-V
You can also open 2 explorer windows side by side, one showing the folder you want to copy and another the contents of the SanDisk drive. You can drag the folder to copy from the computer hard-drive and drop
Aug 04, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Internet explorer is not visible on desktop
Find a Missing Internet Explorer Icon in Windows XP
  • Step 1 Click the "Start" button. Click on "All Programs." Look for an icon called "Internet Explorer." Right-click the icon. Select "Copy" from the menu.
  • Step 2 Find a blank space on your Desktop and right-click on it. Select "Paste" from the menu. You should see a new icon called "Internet Explorer." Double-click it to make sure that it works.
  • Step 3 Open "My Computer" on your Desktop if you were unable to find the Internet Explorer icon in "All Programs." Double-click the "C:" drive. Double-click "Program Files." Open the folder named "Internet Explorer."
  • Step 4 Select the "iexplore.exe" icon and right-click on it. Choose "Create Shortcut" from the menu. Scroll down to the bottom of the window. Right-click the "Shortcut to iexplore.exe" icon. Click "Copy."
  • Step 5 Paste the icon to your Desktop. Open it to make sure it works.
  • Step 6 Click the "Start" button and select "Search" from the menu if you are unable to find the "iexplore.exe" icon in your Program Files folder. Search for "iexplore.exe." Locate the file. Right-click it to create a shortcut. Paste the shortcut to your Desktop.
  • Find a Missing Internet Explorer Icon in Windows Vista
  • Step 1 Click the "Start" button. Select "Run." In the "Run command" box, type "regedit.exe."
  • Step 2 Look for the key ""HKEY_CURRENT_USER." Click twice to open it.
  • Step 3 Navigate to "Software" and open it. Open "Microsoft," "Windows," "CurrentVersion," "Explorer," "HideDesktopIcons" and "NewStartPanel."
  • Step 4 Open the "{871C5380-42A0-1069-A2EA-08002B30309D}" key on the right side of the screen. Change the value to "0" to show the icon on your Desktop.
  • Jul 14, 2010 | Microsoft Internet Explorer 8
    Startup fails to complete properly
    When on the screen, and you have no icons hold control(ctrl) down and shift key and press escape(esc) your windows task manager should appear, goto the applications tab, at the bottom goto the tab New Task and left click, another window should appear with a text bar, type in the text bar explorer.exe and click ok, all the icons and your normal screen should reapear.
    If your screen goes back to normal goto the start bar and goto run or search and type "regedit".
    When the regedit window appears left click the " + " sign next to Hkey_local_mechine the the plus sign on software, scroll down to Microsoft folder and click the plus sign, scroll down to Windows nt folder and click the plus sign, the plus sign on Current version folder, then scroll down to winlogon folder and left click on the folder icon, on the right hand side of the screen look for "shell" double click on the icon and delete everything in the text bar and type explorer.exe and click ok and exit out of the window, restart the pc and everything should be back to normal.
    pls post back and tell me what happens.cheers.
    Jan 30, 2010 | Computers & Internet
    1. how do i do a scan disk and defragmenter on vista? 2. how do i add to the tool bar, double space, print, etc.
    Start, Programs, Accessories, System Tools, then Disk Defrag.
    You can also right click on the My Computer icon on your desktop and click explore. This opens a divided folder. In the right hand column either right click the C: drive and choose Properties or depending on your settings I can single click that same icon and a Properties Icon will slide into view at the very top of the window near the Tabs area. When the Local Disk C: Properties window appears you can click the Tools tab which let's you pick either Disk Defrag or Scandisk. This is better since you can acces both of these utilities and the Backup utility from the same tab also. Scandisk will also run for about 5 seconds then tell you it cannot operate now but will allow you to schedule it for the next startup.
    Nov 12, 2008 | Gateway Computers & Internet
    My hard drive giving me problem
    1st - Right click the drive icon, i think you will find Autorun at First, if it is..
    2nd - Right lick and press explore
    Before that you have to enable Show Hidden files and Folders in Tools Menu, Folder Options.
    3rd - You will find some files, that is like command prompt icon and Autorun icon.
    4th - Delete both the files and reboot the computer..
    The problem is solved...
    or use USB Disk Security V5.0.0.85 - www.freshwap.net and install.... it will delete the files...
    Oct 03, 2008 | Vantec NexStar-3 External 3.5inch...
    How can i install icon pack in my windows xp sp2
    Change Folder Icon:
    1. Open Windows Explorer
    2. Right klick your folder of choice
    3. Choose Customize tab in the new window
    4. Choose a new folder image for Windows Explorer’s “thumbnail” and/or “icon” view
    5. Navigate to your new icon/image of choice and choose it
    Regards
    Balisonu79
    Feb 15, 2008 | Microsoft Windows XP Professional With...
    Computers & Internet Logo
    22 people viewed this question
    David Payne
    David Payne
