Question about Sylvania 6615LE LCD HDTV
Will this tv work with an antenna or does it need a converter box?
    Sergeant:
  • 324 Answers
All LCD tv's made in the last 10 years support digital tv out of the box and do not need a converter box. However if you want to pick up local stations over the air, you may need an external antenna. Otherwise if you have cable tv or other services, you can connect your service to your tv directly.
You may also want to call your service provider (if applicable) if you have issues connecting it to your tv.
Posted on Nov 17, 2014
2 Suggested Answers
joboo1
  • 257 Answers
SOURCE: Does my Trutech PLV16190 require a digital converter box?
Hi, Please don't shoot the messenger, you asked but unfortunately the answer is yes. Your tv has an NTSC tuner which is an analog tuner, Sorry. But this should answer your question.
Posted on Mar 25, 2009
I have an older Sharp Aquos TV - model # LC-32G4U. I am trying to connect a digital antenna but it doesn't work. Anyone know if I need a separate digital tuner for this TV? Or what else might be t
There is no difference between a "digital" and analog antenna. Either antenna will capture the signal. What you need is a digital converter box to convert the over air digital signal to the older analog type signal your TV needs. You connect the antenna to the digital converter box, and the digital converter box to the TV.
Several years ago, the US government forced peopel to buy digital converter boxes or newer TVs that could pick up the digital signal. Either get a digital converter box or a new TV.
Oct 29, 2012 | Televison & Video
RCA DTA800 TV Converter Box I need TV codes for the remote to work. The TVs are a GE, phillips magnabox
Good day,
I might be missing something, but you are describing a converter box that converts digital signals from an antenna to analog.
The converter box will be set to channel 3, and you should set your tv's to channel 3 as well.
Using the remotes that came with the tv's go into setup and if available as an option, you will find an option to select cable/antenna or automatic. Select automatic or antenna and save. If there is a selector switch on the back of the tv's, set to 3.
Connect antenna cable into input, and use supplied cable to connect from the output of the converter to your tv.
plug in power supply for converter box, tune tv to channel 3 then follow instructions to setup converter box including channel scan.
When done, the converter remote will control everything. However, the tv volume control will work even though the converter remote will have volume as well. The tv remote as well is needed to shut off or turn on tv. These functions can on most tv's be performed on the set as well.
No codes are required. The converter remote will work on any tv.
If you want to use both tv's then you will need a splitter on the output of the converter to send the signal to both tv's. Only one channel can be viewed at a time.
Viewing separate Chanel's requires a second converter box and a splitter connected to the antenna cable for viewing separate channels.
More options are possible, but I hope this helps you get started.
The converter box takes place of the tv's tuner and in essence disables it.
Nov 05, 2009 | Tablets & eReaders
JVC and the right converter box and antenna
If the tv got audio video inputs put the converter box on it,because any converter box got to work with all tv´s
Jun 30, 2009 | JVC AV-27230 27" TV
Has anyone figured out IF such a digital anntenna exist yet?
You don't need a digital antenna; any indoor UHF/VHF antenna will work. The antenna and the TV both connect to the converter box, not to each other.
A standard rabbit ears (UHF/VHF) antenna with flat wire (300 ohm) connections can be hooked up to the coaxial cable that goes to the Antenna (RF in) jack on the converter box by using a balun (Radio Shack catalog # 15-1297, about $8). If you have an antenna with coaxial cable already attached, you don't need the balun.
To connect the TV to the converter box, you need an adapter that has an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that goes to the TV (RF out) jack on the converter box.
Jun 08, 2009 | Casio TV-980 2.3 in. Handheld Television
How do I connect an analog VCR + converter box to a digital TV?
first of all does your television and/or vcr have a cable connector and/or a set of rca outlets? if they have a cable connection in the back all you have to do is hook the cable from the antenna to the "in from antenna" on your cable box and then connect a cable from "out to tv" to "in from antenna" on the vcr and a cable from "out to tv" on the vcr to "in from antenna" on the tv. then you need to make sure on the converter box and the vcr and look for a channel selector and see what channel they are on. most vcr's have a selector for either channel 3 or 4, look at what channel it is set to and if your converter box has the same thing then match it with the vcr. then tune your tv to that channel and you should be able to work your vcr as long as the vcr/tv button shows that you are on the vcr. now if your tv and/or vcr have rca outlets and your converter box has the same then just hook the cable from the antenna to the cable box and substitute the rca cable for the regular cable and tune your tv to video or line input.
Jan 01, 2009 | Televison & Video
Hooking up converter box when i have a dvd player and direct tv
Hook your Insignia box between your antenna and your television. You still need the antenna.
Jan 01, 2009 | Insignia Digital-to-Analog Converter for...
Cannot connect the coverter box
When you have your converter box hooked directly with coax to your tv, is your antenna then plugged into your converter box in the "antenna in" port? What do you mean by it doesn't work? Does it say no signal? If so, you just need a stronger antenna. If not, you may have a defective box, bring it back to the place you got it and see if they can help.
Dec 27, 2008 | Symphonic ST420FF 20" TV
GE Spacemaker TV/Radio combination Model #7-7650
Yes, you will need an external antenna to pull in the digital signals. It will not work with the built-in antenna on the GE. Alternately, you can use an external antenna (ie, rabbit ears), connect them to the converter box, then connect the converter box to the antenna jack on the back of the TV (I think it has one). Granted, not an elegant solution for a kitchen TV, but it beats not using it anymore.
Cheers
Nov 11, 2008 | GE Televison & Video
Converter Box / DVD Recorder
Here is a great article on differnet hook up options.
Click HERE
Jun 04, 2008 | Televison & Video
Hand held casio tv vs digital signal
I have my handheld Casio TV-980 up and running with a converter box. All I needed (in addition to the converter box and standard rabbit ears [UHF/VHF] antenna) was an adapter with an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that goes to the TV (RF out) jack on the converter box. The adapter would have been a little cheaper at my local, independent electronics store, but they were sold out.
If your antenna has flat 300 ohm wire connections, you'll need a balun (Radio Shack catalog # 15-1297, about $8) to connect it to the coaxial cable that goes to the Antenna (RF in) jack on the converter box.
I’ve tried 2 different converter boxes with the handheld TV, and they both work well: Insignia (Best Buy’s house brand, same as Zenith) and RCA (from Target, same as Venturer), so any government coupon-eligible converter box should work.
A few other tips:
1. I always turn on the converter box before I turn on the TV. The cpnverter box seems to take control better that way.
2. When I turn on the TV, the tuner doesn’t automatically go to channel 3 or 4 (where it should be set when using a converter box), and the picture quality is poor. If I use the tuner on the TV to get to channel 3 or 4, the picture quality is vastly improved. I have to do that every time I turn on the TV.
3. Placement of the antenna is very important. I like to watch my handheld TV when I'm on the computer, and the reception is better the further away from the computer the antenna is located. I'm actually using a 6' coaxial cable for the antenna, but I could also have used 2 shorter cables with a coupler that has an F jack at both ends (Radio Shack catalog # 278-304, about $3).
If your battery-operated TV does not have an external antenna jack, instructions for connecting it to a converter box can be found at
http://www.digitaltvtrainer.com/national/showme-battery-tv-converter
There are a few battery-operated converter boxes available, but for do-it-yourselfers, this web page also contains instructions for building a 12-volt converter box power supply.
Apr 29, 2008 | Televison & Video
Sylvania 6615LE LCD HDTV Logo
215 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
