Question about Brother IntelliFAX 1270E Plain Paper Fax
IN WHAT DIRECTION DO TO PUT THE PAPER IN TO FAX
    Novelist:
  • 129 Answers
Directly above the control panel you will see the tray where to put in the document you want to fax, load the document top edge first face down, lcd should change to enter fax no & press start.
Please rate if this helps
Thanks, vikroks
Posted on Mar 27, 2011
How do I unjam a fax machine 1010
to clear document jam:
1 Open the front panel.
2 Carefully remove the jammed document.
3 Close the front panel firmly until it clicks
into place.
If the fax paper jams while you are receiving or printing, Remove jammed paper and press
Cancel appears in the message.
if the paper is jammed in the printing area
1 Remove the jammed paper by pulling it out
smoothly in the direction of the arrow as
shown.
If the paper tears when it is being removed
check to ensure that no small pieces have
been left inside the machine.
2 Press Cancel.
3 If this was a fax, reprint the fax. For more
information, see reprinting faxes on
page 29.
if the paper is jammed in the paper feed
area
1 Remove the jammed paper as shown.
removed check to ensure that no small
pieces have been left inside the machine.
2 Reload new paper with the print side
facing toward you.
3 Press Cancel when finished.
May 04, 2012 | HP 1010 Plain Paper Inkjet Fax
CHECK 5100
Jams in the Document Tray
When a document jams or misfeeds in the Document Tray, CHECK 5100 are displayed on the LCD.
When CHECK 5100 is displayed
1 Check if any paper is jammed.
If jammed, make sure to take out all the jammed paper.
2 After taking out jammed paper, turn the fax off, then turn it back on with [ON/OFF].
Jams in the Multi-Purpose Tray
If paper jams in the Multi-Purpose Tray, CLEAR PAPER JAM is displayed on the LCD.
1 Gently pull any jammed paper out of the fax as
shown, then press [Stop].
Pull it gently in either direction.
If you cannot pull the paper out, continue with the steps below.
2 Open the Printer Cover.
3 Gently remove the jammed paper inside the fax.
4 Press [Stop].
The fax returns to standby mode.
Feb 20, 2012 | Office Equipment & Supplies
Paper jammed while trying to fax through the feeder. Help
turn it off slowly work the paper out by pulling it slowly from the direction you fed it or by whatever direction you find it will come out the easiest. If it tears you be patient and work out pieces you aren't the first person that ever jammed paper in a fax just take patience to get it all out.
Jul 04, 2011 | HP OfficeJet 7310 All-In-One InkJet...
Paper jam
The following is general advice that applies to removing paper jams in most printers, copiers, etc.
Switch off the printer at the wall and unplug it. Remove the paper tray from the printer. Check to see if the printer has an access door in the rear to allow you to see inside (open it). Open any other external flaps (eg. manual paper feed tray) that will allow you to see inside. Open any internal flaps or levers designed for user operation and usually indicated with a green or orange coloured tab.
Always remove jammed paper by pulling it in the direction of normal travel only. Don't try to pull it out against the direction that it entered the printer. Sometimes rollers inside the machine have a knob (usually coloured green or orange) that can be used to manually wind the page through the printer or fax. Always turn in direction of arrow indicated only.
After removing page, return all levers, flaps, doors, paper trays etc to original positions, reconnect power to the printer and test
Mar 08, 2010 | Brother Fax-1360 Plain Paper Inkjet Fax
Which direction do you put paper in for a m4500 fax machine
watch this little video on fax machines. helped me! hope it helps you
http://www.ehow.com/how_2059862_use-fax-machine.html
Feb 17, 2010 | Muratec Office Equipment & Supplies
How do I remove a paper jam? The paper is
Feb 04, 2010 | Brother IntelliFAX 4100 Laser Fax
In what direction to you put in the paper when sending a fax? Up or Down?Front or Back? Thanks
Up or down doesn't matter much, as the recipient can always turn the printout around :) But generally putting the documents upside down will make the fax scan the top of the page first.
As far as front/back is concerned, it depends on the construction - if you look at the document feeder you will see a symbol of a sheet with a corner bent, showing the back side. If there are stripes (symbolizing text) on that corner, you must put the document(s) face down; if the stripes are on the rest of "sheet" - put them face up.
In your case most probably it will be face down. You can always check that, and the quality of document scanning (whether the document is not too light for example) by using the "Copy" function of your fax.
Dec 21, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
To fax do you send paper through it or scan it to an e-mail
Assuming you have it hooked up to a phone line that is capable of dialing the number you want to fax to, you put your paper in the top tray, dial the number and hit send. The machine will pull through the paper and deposit it under that top tray. You will want to make a copy first so you know you are putting in the paper facing the right direction (it should be face up.) Put a single sheet face up in the top tray and hit copy. If what comes out of the bottom-most tray underneath is an exact copy of your original, then you're fine, if it's blank, then flip the orginal over and try again.
Nov 10, 2009 | HP Officejet 5610 All-In-One InkJet...
Brother IntelliFAX 1270E Plain Paper Fax Logo
47 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
