Question about Samsung Refrigerators
Fridge side affected, not freezer. Unit stops cooling. Fan noise gets louder, runs nearly constantly. Discovered ice behind the storage bins, so I set about defrosting it. This was in Late November, '10, first time it happened. Solution I found was to completely remove fan/cooling unit & housing, defrost it and reinstall it. Worked, but has happened 3 times since November. Each time it starts cooling again but soon re-freezes. Last time only lasted maybe 3 weeks, then box started not getting cold again.
  • loosedrag Mar 25, 2011
    Thanks WC. I have a Samsung RS267LBSH, which is a two-evaporator, twin-cooling system. If you happen to know where either the defrost timer or the defrost thermostat (refrigerator side, not freezer) is on this model, or can point me to a schematic, that would be great. I'll try to figure out whether I have an adaptive defrost control. I won't be able to try your suggestions until the weekend. Meanwhile, thanks much for your expertise.
  • loosedrag Mar 28, 2011
    WC:
    RO48 is listed as a "pcb case" ($6). RO47 listed as "pcb case assembly" ($36), and the two of them appear to clamp together to cover something called a "pba" (call for availability. No price given).
    I still can't tell from the diagram where to start hunting for this part. Is it in the box itself or on the outside? Do I access it from the gizzards of the fridge once I have the whole unit out of the fridge box? Is there some way I can send you a picture of the assembly I pull out? How do I send you more money for the help you're providing? email is loosedrag at gmail.
  • 4,070 Answers
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Post your model number for more specific information.
Posted on Mar 25, 2011
  • Charles T Nevin
    Charles T Nevin Mar 25, 2011
    Part RO48 is your defrost control or PCB in this DIAGRAM
  • Charles T Nevin
    Charles T Nevin Mar 28, 2011
    The parts shown in the diagram are in the area of the compressor which is on the back underneath the fridge/freezer. I think you will recognize the part from the diagram when you see it. You don't have to take a lot out to get to it.
    As far as money goes, when you accept the answer the payment is automatically processed. I'll help as much as I can till the problem is solved.
Noisy Fridge
sounds like the recirculating fan inside the unit is about to seize. Find it and lubricate it.
Apr 23, 2017 | Samsung RS2630SH Side by Side Refrigerator
Hi, My fridge ( 420 ltrs) Top Freezer making constant humming noise ( like a dieasl car engine)like the engine keeps running and try to cool the fridge. 1 year old. When I open the freezer or the...
The noise is the fan hitting ice build up on the coils... it is no defrosting properly...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 14, 2010 | Samsung Refrigerators
My fridge wont get cool
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Jul 12, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
My GE Fridge PSS26SGRD has a moaning howling
The fan is hitting on ice buildup...unit is not defrosting...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator side not cooling
Oct 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Motor stopped running but lights & ice maker OK
this is most likely a bad condenser fan motor. pull refrig from wall remove compartment cover on rear and inspect the fan that cools the compressor. it is either jammed or seized up and needs replacing. while your at it you may want to clean the condenser coils as well they most likely have dust and lint build up on them. this motor is fairly easy to replace yourself if your mechanicaly inclined the part number should be 833697blade and can be purchased online, at a local appliance parts supply house, or thru a sears parts and servie center near you.
to keep the unit working until you get it repaired you can put a house fan blowing on the compressor area to keep it cool and this will get temps back to normal and cool down that center frame as well.
Thanks Peyton..
Feb 24, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Bosch KGU32160 fridge freezer
The compressor behind the fridge should cycle on and off as the machine maintains temperature, but the evaporator fan inside the freezer will keep running, except when the fridge goes into defrost. If the noise is coming from the fan inside the freezer, there could be some ice on the frame of the fan and the blades are touching the ice. If the noise is coming from behind the fridge it could be the condensor fan motor. This fan is situated behind the fridge in front of or next to the compressor. It keeps the condensor cool by blowing air onto it. Check this fan. The blades could be touching the pipework or something.
Oct 31, 2007 | Bosch KGU32124 Bottom Freezer Refrigerator
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
