Question about Coby TF-TV1901 19 in. LCD Television
Antenna input broke off. - Coby TF-TV1901 19 in. LCD Television
Fixing the antenna cable input on a 2007 RCA
Disassembly will be required but you can replace the coaxial F connector on the rear.
Jun 25, 2016 | RCA Televison & Video
Broke radio antenna
Ive done that a few times over the years when I forgot to push the antenna down when going through the car wash. Depending on where the antenna is, you have to get behind the panel it is mounted on. IE/ The guard, roof, windscreen frame. This will mean removal of whatever panel is behind to get to it.
Apr 12, 2015 | Cars & Trucks
Antenna in broke off
Consider getting a box (cable or satellite) with video outputs and running those into the same type inputs on rear of set--bypass the connecter on the rear of the set.
Most modern sets the coax fitting is part of the tuner and if broken off the entire tuner would have to be replaced in most cases--not cheap and some models tuner is only available with a board.
Over 200 if the board has to be replaced or route signal into a rear audio/video input on the set?
Dec 22, 2012 | Televison & Video
Hello, my 25" Magnovox (#mt2501c)
Tv fell off about 3 feets or more?Yes,turn on the tv see if u getting any power to the unit?Might have broken main PCB board too.If unit still have power,check see if tv get statics screen have colors shaded in red or mutiples colors,mean the tv CRT(tv tube) yoke is dead and damages scrambles radiation.Or the tv getting power but have high pitch sqeeling noises or rattles noises,tv have the CRT-(tv tube) is crack by the neck or broken totally.CRT have damages problems or dead tv is worthless,beacause of CRT(tv tube) is dead,not fixable even that antena connector input is replaced.
Feb 17, 2011 | Philips Magnavox MT2501C 25" TV
The antenna inputon back of television broke off,
It is possible to fix it by de-soldering RF Tuner Block from signal board of your TV and installing new one. This repair need soldering skills.
Mar 10, 2010 | RCA HD52W59 HDTV Projection Television
Antenna analog input tunner broke off inside the box wondering if i could bypass it useing converter and the digetal input tunner
Yes, just make sure your converter box has composite and you're set to go. Your antenna will then plug directly into your converter box. If you end up needing more than one port (dvd player, gaming console, etc.), grab up an A/V switch which also works off of composite and you're all set to go.
May 12, 2009 | RCA D52W136D 52 in. TV/DVD Combo
RCA D52W17 ANTENNA/CABLE ANALOG INPUT
are you looking for this part?
http://www.partstore.com/Part/Thomson/RCA/264658/New.aspx?ModelMfgName=Thomson&ModelBrandName=RCA&ModelNumber=D52W17BYX1
if so, just make sure your model number is on the listed devices.
Nov 11, 2008 | RCA D52W23 52" HDTV CRT TV
No audio on components
Make sure your audio cable is not broke. Try another one to make sure.
Nov 13, 2007 | Mitsubishi WD-62725 62" Rear Projection...
Antenna hookup broke off
You have to re solder the connector. The other solution is to patch from the Direct TV box AV out to the AV input on the back of the TV. This will bypass the tuner and give you a cleaner picture. However, if your TV does not have an external input you must re solder the connector. As easy as it may seem, this should be done by a qualified technician. Its not as easy as it looks and requires good soldering skills.
Nov 12, 2007 | RCA F19207BC TV
That is an ITC222 chassis and one of the more dependable RCA units built. The "F" connector is the part you're referring to and it's not something that carries a specific part number for that unit. In the shop here we simply buy them by the box and the tuner will have to be removed to install a new connector. The new one will be soldered to the chassis of the tuner and less likely to break in the future. Not something you probably want to do yourself, but at least you'll know what to ask the shop when you're calling around for estimates.
Nov 05, 2007 | RCA D52W19 52" Rear Projection Television
Coby TF-TV1901 19 in. LCD Television Logo
35 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
